rjpieces
Delta In Las Vegas
Sun Jan 15, 2006 2:03 pm
I was wondering what cities Delta flies to from Las Vegas...
What else besides the usual ATL, CVG, and SLC...Song has JFK, BOS, MCO, and FLL. Is that it for Delta there?
Thanks.
"Millions long for immortality who do not know what to do with themselves on a rainy Sunday afternoon"
rjpieces
RE: Delta In Las Vegas
Sun Jan 15, 2006 2:06 pm
Btw, the reason I ask is because a friend is flying LAS-CVG on the 7AM departure tomorrow morning...I'm trying to figure out where the plane is coming from and it doesn't appear to be CVG or any of the above cities.
N1120A
Sun Jan 15, 2006 2:14 pm
Quoting RJpieces (Reply 1):
Won't it be an RON then? I am betting that the 738 will be coming off DL1767, which arrives from CVG at 20:27. Odd that DL doesn't try to squeeze some utilization out of the LAS strong LAS redeye market.
rjpieces
Sun Jan 15, 2006 2:19 pm
Quoting N1120A (Reply 2):
That's what I thought at first...But DL1767 arrived at gate D40 tonight...DL 642 is leaving LAS tomorrow morning from gate D42.
altairF28
Sun Jan 15, 2006 2:23 pm
They used to have redeyes to all the Song cities (before Song existed) plus TPA.
A detour is a choice between two tasks, each with its own pros and cons
Sun Jan 15, 2006 2:24 pm
If by "tomorrow" you mean 15JAN, that aircraft came into LAS as flight 1767 from CVG. It will RON and turn as flight 642 16JAN.
B
rjpieces
Sun Jan 15, 2006 2:26 pm
Quoting NonRevKing (Reply 5):
Sorry for the confusion, I was looking for where the aircraft is coming from that will operate DL642 on January 15th.
N1120A
Quoting RJpieces (Reply 3):
Well, they will probably just move it over in the morning or change the gate prior to departure. I had an OO FA tell me on my OXR-LAX flight that my LAX-BOS flight would leave from T6 (a long walk) then I looked 10 minutes later at the departure screen and we were going from T7. Also, did they op-sub a 738 into LAS from ATL or something? That is the only thing else I can think of. Also, I still don't get why they would have that airplane sit for almost 11 hours
N1120A
Sun Jan 15, 2006 2:30 pm
Quoting RJpieces (Reply 6):
Yeah, same thing. I took a look at the LAS timetable and the only 738's DL is bringing in are from CVG (odd that DL is sending out a 738 to ATL but has none coming back in, must triangle from CVG)
dalb777
Sun Jan 15, 2006 3:01 pm
Download the Delta timetable from their website and check that out. It may help you.
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
DL4EVR
Sun Jan 15, 2006 3:20 pm
Quoting AltairF28 (Reply 4):
USED to? They still do. My body clock was screwed up for a week after taking their LAS-JFK flight in December '04!
We Love To Fly And It Shows.
Sun Jan 15, 2006 4:57 pm
Ok. It's the same routing either way. It comes in from Cincy as 1767.
Hope this helps,
B
FLAIRPORT
Sun Jan 15, 2006 11:10 pm
WRONG!
Pre-Song DL had no redeyes from FLL, not even LAX!!!
NEXT FLIGHT: FLL-ATL-HPN on FL
United_fan
Mon Jan 16, 2006 2:13 am
Well,here's a list of DL arrivals for today.
Atlanta, GA Delta Air Lines 841 04:51 PM Arrived
Atlanta, GA Delta Air Lines 417 06:54 PM Arrived
Atlanta, GA Delta Air Lines 785 07:52 PM Arrived
Cincinnati, OH Delta Air Lines 1767 08:19 PM Arrived
Fort Lauderdale, FL Delta Air Lines 2097 09:09 PM Arrived
Salt Lake City, UT Delta Air Lines 1413 09:18 PM Arrived
Atlanta, GA Delta Air Lines 1279 09:48 PM Arrived
Orlando, FL Delta Air Lines 2056 10:55 PM Arrived
Atlanta, GA Delta Air Lines 1009 11:54 PM Arrived
New York, NY Delta Air Lines 2061 11:55 PM Arrived
Atlanta, GA Delta Air Lines 114 10:31 AM In Flight
Atlanta, GA Delta Air Lines 1689 11:39 AM In Flight
Cincinnati, OH Delta Air Lines 784 11:44 AM In Flight
Salt Lake City, UT Delta Air Lines 362 01:12 PM Scheduled
Atlanta, GA Delta Air Lines 224 02:25 PM Scheduled
Cincinnati, OH Delta Air Lines 1421 09:46 PM Scheduled
Boston, MA Delta Air Lines 2047 10:08 PM Scheduled
Champagne For My Real Friends,and Real Pain For My Sham Friends
MAH4546
Mon Jan 16, 2006 2:16 am
Quoting FLAIRPORT (Reply 12):
WRONG!
Delta launched FLL-LAX non-stops in the 1990s. They ended in mid-2002, at which point it was a daily 757 via TPA.
a.
stirling
Mon Jan 16, 2006 2:47 am
Quoting N1120A (Reply 8):
I've noticed that about Delta flights...for 40 years. Flights operated by certain aircraft types would serve a market one-way, but not the other. And since DL has always operated so many fleet types, and hubs/focus cities...it was always easy to spot.
The 747 was an example...without checking, I seem to remember a DAL-LAS flight that operated with the jumbo westbound but not eastbound.
Since then, the timetables are rife with examples of the same happening with 757s, 767s, DC8s, and L10s.
Delete this User
TWA902fly
Mon Jan 16, 2006 3:15 am
Quoting Stirling (Reply 15):
United does this also... ive noticed the following
ORD-SLC
1 CR7
1 737-300
2 A319
SLC-ORD
1 737-300
2 A319
1 A320
so as you see... on each day of the week there has to be more people leaving Salt Lake than going to Salt Lake....  Smile
'902
life wasn't worth the balance, or the crumpled paper it was written on
