N723GW
Question About Flight Numbers
Wed Jan 18, 2006 12:18 pm
Back when I was a ramprat watching flightrax, I remembered seeing a few NWA flights that had letters in them. For example, NWA1689A. I was told this was because the flight was carrying body parts. Is this true?
The dude abides
TimRees
RE: Question About Flight Numbers
Wed Jan 18, 2006 10:13 pm
Don't know about that, but here in Europe many flights have alphanumeric callsigns now to avoid ATC confusion.
Back in Pan Am's days they added 'A' in multisector and change of equipment flights...eg PA103 LHR-JFK but if it originated on a 727/737 in say FRA the FRA-LHR flight was PA103A. Until recently UA did similar on their flights through LHR (don't think they have any transitting these days).
BDKLEZ
Wed Jan 18, 2006 10:38 pm
Quoting N723GW (Thread starter):
NWA1689A
Could be that flight's particular ATC callsign which may or may not be the same as the commercial flight number. Which in this case it obviously isn't, if that's what it is, if you know what I mean...???
 footinmouth
Trespassers will be shot; survivors will be shot again!
IAHFLYR
Wed Jan 18, 2006 10:47 pm
I believe the reason is if as example NWA1800 had a stop and equipment change in MSP on a from DTW-MEM-SEA and continues to SEA using another aircraft which is common.....if the company determined the DTW-MEM was late inbound and the MEM-SEA portion was ready to go, rather than wait they will dispatch the MEM-SEA segment as possibly NWA1800A for ATC purposes as the HOST computer will not accept 2 flights with the same call sign in the air at the same time. I am sure there are other reasons as well but I know that one sticks out in my fading memory!
BDKLEZ
Wed Jan 18, 2006 10:53 pm
Quoting IAHFLYR (Reply 3):
Plausible indeed, but I've just remembered some additional info. Dunno about the US, but here in Europe a callsign can only consist of maximum 4 characters, ie NWA"1800". A NWA"1800A" would be rejected by the ATC authorities as it consists of 5 charachers in addition to the 3 ICAO operator identifier characters. Is that the same in the US?
Newark777
Wed Jan 18, 2006 10:54 pm
AZA7C1 is a regular visitor to EWR.
Harry
N723GW
Wed Jan 18, 2006 11:44 pm
Quoting BDKLEZ (Reply 2):
BDKLEZ From Ireland, joined Jun 2005, 686 posts, RR: 5
Reply 2, posted Wed Jan 18 2006 14:38:21 UTC+1 and read 38 times:
NWA1689A
I know what you're talking about. Comair, ASA and Eagle all do that in a way. If the flight number is like Comair 1234, so the pilots aren't saying all of that, they will just say Comair 234. But, like I said before, I seen this on flightrax (moving map flight tracker) and the identifier on the program had a letter in it. But when it came in, ATC just called it something like NW1689. No letters.
The dude abides
IAHFLYR
Fri Jan 20, 2006 5:04 am
There could be some sanitising of aircraft on those systems that ATC does or doesn't use for the call signs......
In the US there is a max of 7 characters in call signs
RAFVC10
Fri Jan 20, 2006 5:16 am
Most british summer charter flights from some cities in GB to Spain has letters in its flight numbers.
El dia que los gilipollas vuelen, no podremos ver la luz del sol!
FlyKev
Crew
Fri Jan 20, 2006 5:39 am
Generally most airlines in the uk are odd numbers east, even numbers west.
DP use letters (c out, d back) and I know other charters do the same.
