IceTitan447
Connecting In LHR To Other London Airports
Thu Jan 19, 2006 8:09 am
I am planning travel through London in April. I have connected to LGW from LHR but never the other ones( LTN,STN)
Out of those 3 airports, LGW,LTN,STN What airport is easiest to transfer to?
I have a choice to fly Ryan Air, Or EasyJet, The others are pretty high price wise, any Ideas?
Between the others it doesn't matter train, bus, or tube.
BDKLEZ
RE: Connecting In LHR To Other London Airports
Thu Jan 19, 2006 8:22 am
By far the easiest and most cost effective way will be by bus using the National Express Airport service. Personally, I've done LHR-LTN which was relatively painless and quite inexpensive. Check out all the times/fare etc on their website which I've posted below.
http://www.nationalexpress.com/destinations/airports.cfm?t=air
 wave
Trespassers will be shot; survivors will be shot again!
lehovec
I think that the easiest way (and almost sure the quickest way) is by coach.
It takes 1 hr LHR-LGW (up to 6 departures per hour), 1,5 hr LHR-STN (every 30 mins) and 1 hr LHR-LTN.
You can also take a train but you have to then combine it with tube...
I would certainly take a bus.
I personally would chose EZY over FR.
Maybe you can have look before you decide:
http://www.airlinequality.com/Forum/easy.htm
http://www.airlinequality.com/Forum/ryan.htm
BTW, if I were you and you decide for EZY over FR, fly out of STN (less delays).
BDKLEZ
Thu Jan 19, 2006 8:25 am
Quoting Lehovec (Reply 2):
I personally would chose EZY over RYR
I wonder why? Hhhhhmmmm.....  scratchchin   sarcastic   scratchchin   sarcastic
Ps., Thanks for the RR.
474218
Thu Jan 19, 2006 12:41 pm
I done a STN-LHR by motor coach with no problem, so I am sure it runs the other direction.
IceTitan447
Fri Jan 20, 2006 2:41 am
Thanks all, I have to try and get 5 adults and 4 children between the two airports. Thanks for all the help.
