MSYtristar
DL To Add More MSY-MCO Service
Mon Jan 23, 2006 8:58 am
Hot off the presses for those who care.
New flights effective 3/2/06 using ERJ-145 aircraft.
MCO-MSY DL6227 1130a - 1224p
MSY-MCO DL6227 1255p - 350p
Interesting to see that this is the same flt number for both segments of the trip.
iowaman
RE: DL To Add More MSY-MCO Service
Mon Jan 23, 2006 9:23 am
Good news to see more service even if it's only an ERJ.. I wonder why it's the same flight number both ways?
ExpressJet_ERJ
Mon Jan 23, 2006 9:25 am
Same flight number is pretty common on Delta. CMH-BDL is same both ways, as is BOS, LGA, and other pairs. Glad we are getting some more flying back finally!
ETOPS...Engines Turn Or People Swim
DAL767400ER
Mon Jan 23, 2006 5:47 pm
That's the standard procedure on most Delta Connection flights that return to their origin airport within the same day. With all the RJ flying and constantly more codeshares on Skyteam and other airlines, DL was slowly but steady running out of flight numbers, so they started using this method.
On the topic:
Nice to see DL continue their MSY build-up. It might only be a small step, but these small steps come at regular intervals, so that DL can't do much wrong.
ConcordeBoy
Tue Jan 24, 2006 3:38 pm
What's the current total on MSY-MCO, for both DL and WN?
N1120A
Tue Jan 24, 2006 3:48 pm
Quoting MSYtristar (Thread starter):
Makes sense given that it is a quick turn, same day return. United does it with their Express props in CA
AV8AJET
Wed Jan 25, 2006 1:48 am
SLC-MSY starts in Feb. with a roundtrip flight on a ASA CR7.
"To fly or not to fly there is no question!"
dalb777
Wed Jan 25, 2006 4:39 am
Quoting AV8AJET (Reply 6):
Didn't this route used to be on an MD-90? I guess the demand is not back yet.
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
DAL767400ER
Wed Jan 25, 2006 4:50 am
Quoting Dalb777 (Reply 7):
Indeed, used to be an MD-90 prior to Katrina, and even was twice daily on 757/762/72S's over the years.
md90fan
Sat Feb 04, 2006 4:15 pm
Good to see service slowly coming back to MSY  Smile
http://www.devanwells.blogspot.com/
