richm
When Will EgyptAir Get Rid Of Their 737-500's?
Wed Jan 25, 2006 7:44 am
I was just wondering, when do you *think* EgyptAir will get rid of their 737-500's? On their website, it states that their A300's (manufactured during same year as their 737-500's) will be removed during February this year. As EgyptAir's 737-500's are fairly dated, and lack onboard entertainment systems such as PTV's and in-flight radio, I was just wondering if anyone had any idea when EgyptAir would be likely to get rid of them? + When they do get rid of them, what do you think will happen to them? And what are they likely to replace them with?
http://www.egyptair.com.eg/docs/inside/fleet.htm
Thanks.  Smile
bennett123
RE: When Will EgyptAir Get Rid Of Their 737-500's?
Wed Jan 25, 2006 8:29 am
IMO you are making a fundamental mistake here.
You assume that because they are selling the A300-600 that they will also retire the B737-500.
However, the A300 is operated on different routes and are being converted for FedEx. I do not think that they would be retiring them yet if re sale was not an available option.
I think that an update to the IFE is possible, however given that most are used on shorthaul often with little or no competition, this is by no means inevitable.
Given that MS seem to be opting for Airbus on it's shorthaul routes, I suspect that the eventual replacement will be A319/A320.
richm
Wed Jan 25, 2006 11:38 am
Quoting Bennett123 (Reply 1):
Nowhere did I state that I thought EgyptAir planned on withdrawing their 737-500's just because they are removing their A300's from their fleet. I simply pointed out that their A300's of the same age were being removed from the fleet in due course. I am not the one making assumptions here, I was just stating facts and asking questions.
Thanks for the reply anyway.
md90fan
Wed Jan 25, 2006 12:53 pm
What routes are the 735's on? TLV? are they still almost all white operated by Air Sinai?
http://www.devanwells.blogspot.com/
bennett123
Wed Jan 25, 2006 7:05 pm
RichM
My understanding was that you were making a link, sorry if that assumption was incorrect,
Copied from the thread about UA 735
Actually, on hops less than app 1.5 hour, the old Boeing uses less fuel due to it much lower OEW. Even if the engines are less efficient, the less weight causes the engines to burn less fuel on short trips
An example of this is that BU did not want 736 from SK as a replacemet for the 735, they were simply less efficient for the typical mission profile.
MD90fan
CAI LXR
ABS ASW
I am sure that there are other routes.
bennett123
Wed Jan 25, 2006 7:08 pm
The quote was from Mikkel777
Actually, within its range profile (About 1500-1600nm and less) the 737Classic is more efficient than either the 737NG or the A32S. In fact, this is a major reason that WN used the 733 on MSY-LAX as opposed to the 73G (except when 10/28 was closed)
There was another from N1120A
Horus
Thu Jan 26, 2006 7:07 am
Quoting RichM (Thread starter):
The decision to retire the B735s has been put on hold several times. Back in 1999/2000 the airline ordered 5 A318s to replace the 5 B735s (one was lost in TUN in 2002) but the problem with the P&W engine meant this ordered was changed to the larger A320, which in turn was used to expand rather than renew the fleet.
Several MS pilots I have spoken to have expressed their dislike of the B735 as they are getting on in terms of age however they all agree that there is no current aircraft that can economically replace the Baby Boeing. The A320s (which the airline has 12 of) and the B738 (which the airline has on order) represent an extra 50% in capacity compared to the B735 so are not realistic replacements. Also the A318s/B736s are too heavy despite offering a similar seat capacity. Like Air New Zealand's dilemma with the B733, MS cannot find a good enough replacement with low fuel burn.
The most likely scenerio is that MS's subsidiary, Air Cairo, will take over the former's entire domestic network within a few year (which is where the B735s are mainly deployed) using a fleet of turbo props which would allow a high frequency, comfortable service on the domestic trunk routes (MS did lease 6 ATR-42s back in 2003 to test the feasability of such actions).
I for one will surely miss MS's B735s and hope to see them in the air for much longer. Yes they are old, but they are sturdy aircraft and look great in MS's c/s.
The AB6 replacement had been on the cards since 2000 but 9/11 and lack of financing put the order for the A332 on fold for 3 years. As for the converted AB6s they are destined for both Egyptair Cargo and FedEx. Irish operator Aer Lucht originally planned to take 3 but that airline folded before the first aircraft was delivered.
It's also important to bear in mind that the AB6 were operating on lucrative routes to the Middle East and Europe offering inferior onboard services, so it was paramount to find a replacement...in this case the A332s.
Agreed
You seem to forget MS have 12 B738s on order.
Quoting MD90fan (Reply 3):
Egyptair operate 4 B735s including the one operated by subsidiary, Air Sinai:
SU-GBH 04/1991 (blue tail and engines)
SU-GBJ 11/1991 (full MS c/s)
SU-GBL 05/1992 (full MS c/s)
SU-GBK 05/1992 (blue tail and engines) Air Sinai aircraft
The B735s mainly fly domestic routes as well as to DAM, ALP and sometimes ATH and IST.
Air Sinai fly CAI-TLV on a twice weekly basis and a 1x weekly SSH-TLV flight. When not flying to TLV the aircraft is used on MS's own route network.
Horus
EGYPT: A 7,000 Year Old Civilisation
garpd
Thu Jan 26, 2006 7:12 am
EgyptAir have a history of preffering a mixed fleet. And I think they have 738's on order.
EDIT: Ah, Horus beat me to it with that info...
[Edited 2006-01-25 23:13:43]
arpdesign.wordpress.com
bennett123
Thu Jan 26, 2006 8:28 am
Sorry, I missed out on the B737-800 order.
That clearly puts a new slant on my comments.
WesternA318
Thu Jan 26, 2006 12:53 pm
Now why does every nrowbody operator have to hve IFE again?
Check out my blog at fl310travel.blogspot.com!
ETStar
Thu Jan 26, 2006 1:02 pm
Quoting WesternA318 (Reply 9):
Thank you! Unless that bloody narrow body is used on a long trip such as Kenya Airways' 73Ws trekking all the way to West Africa, why would we really need IFE's on short hauls? This just tells me that people are so addicted to the rays of light that come from these lil' gadgets, and have no way of keeping themselves entertained (no pun intended)! Try reading. Try having a conversation with the totally unknown person sitting next to you. You might learn something new, and broaden your horizons.
And those rays are bad for your eyes, eat more carrots.
Horus
Fri Jan 27, 2006 9:39 pm
WesternA318, ETStar I completely agree with your sentiments but with today's fiercely competitve market passengers tend to have high expectations. Just look at AC or B6 who have installed PTVs on their Embraer RJs. I personally don't see the need for such an enhanced entertainment system on narrowbodies operating short haul flights as it's costly and not truely beneficial.
Horus
md90fan
Sun Jan 29, 2006 5:02 pm
What routes will the 738 go on?
viasa
Sun Jan 29, 2006 9:15 pm
A year ago (or more...) Aerolineas Argentinas sign a deal with MS to take over the B735. But about a month later AR sign also a deal with CZ.
So the MS/AR-contract was cancelled.
The first two former CZ B737-500 are now in service with AR and seven will be go to Argentina shortly.
After that MS search for a new operator for her B735s and found that in Canada with Canjet Airlines. But untill today no MS B735 was delivered to this airline.
I'm not sure if this deal is still around or if is canncelled...
Horus
Sun Jan 29, 2006 11:27 pm
Quoting MD90fan (Reply 12):
They've been earmarked for European and Middle Eastern services. Expect to hear more information this summer.
Quoting Viasa (Reply 13):
Viasa, in all honesty I heard unsubstantiated rumours regarding the MS/AR deal but it's the first time I've heard of a Canjet agreement. I doubt MS will get rid of their B735s until they start receiving the B738s and Air Cairo receive their A320s. Having said that a deal with Canjet (an all B735 operator) would make sense for both airlines.
Horus
