1337Delta764
Delta - Which Aircraft Will Get The Song IFE?
Thu Jan 26, 2006 5:57 am
Does anyone know which aircraft in Delta's fleet will get the Song IFE?
I know the 757s will be getting it. Also the 737-800s and 767-300 (non-ER) may get it. The 767-300 especially needs an IFE upgrade as its system is sooo out of date. I also hope the domestic 767-400ERs gets it.
AV8AJET
RE: Delta - Which Aircraft Will Get The Song IFE?
Thu Jan 26, 2006 6:04 am
Quoting 1337Delta764 (Thread starter):
Also the 737-800s
I don't know if anything will change on these, especially since they already have the overhead LCD screens. I wouldn't think they'd change and
take out the original LCD IFE system but I could be wrong.
"To fly or not to fly there is no question!"
1337Delta764
Thu Jan 26, 2006 6:15 am
Quoting AV8AJET (Reply 1):
Those screens however are NOT PTVs. To have the ability to change video channels, PTVs are required.
SESGDL
Thu Jan 26, 2006 6:24 am
I presume that all of the non-ER 767-300s will get them, as well as the 737-800s. Of course the 757s will get them as well. That way the only DL aircraft without IFE are 737-200/300s and MD-88s.
Jeremy
hiflyer
Thu Jan 26, 2006 7:15 am
The DAL announcement specifically stated only that 50 more 757 would get the IFE to give DAL approx 100 B757 in 2 class arrangement with TV. No mention was made on any other portion of the fleet at that time or since.
http://news.delta.com/article_display.cfm?article_id=9941
IMHO given their current financial situation any continued speculation here on additional aircraft/fleet types may be specious.
panamair
Thu Jan 26, 2006 7:23 am
Quoting Hiflyer (Reply 4):
Actually, if you read it carefully, it says the 48 existing 757s will be converted, but then it says "Converting an additional 50-plus Delta aircraft to two-class Song service"; it doesn't specify which aircraft those 50-plus are. Other types will be converted as well because some of these longer-than-1,750 miles-routes cannot fully support a 757 (e.g., the recently announced LAX-CMH and LAX-RDU flights).
DAL767400ER
Thu Jan 26, 2006 7:28 am
Quoting Panamair (Reply 5):
Which points to the 738 as the prime candidate for 'Songisation', particularly the ex-Shuttle planes, IMHO. Though a few 763ERs might also be a good option, seeing as those are also being used on quite a few routes longer than 1,750mi.
