TacSupport1
JetBlue CEO Cites Hiccups In Embraer Plane Debut
Fri Jan 27, 2006 11:10 am
These planes are awesome. Once they get the kinks worked out, and more people get to fly these and the routes they fly on, it will catch like wildfire....
"JetBlue CEO cites hiccups in Embraer plane debut"
http://asia.news.yahoo.com/060126/3/2erps.html
No URL in signature please
Tbird
RE: JetBlue CEO Cites Hiccups In Embraer Plane Debut
Fri Jan 27, 2006 11:14 am
A buddy of mine is an IT manager for them and was saying the onboard computers were giving them some issues, Embraer was up for weeks working with them. They also had some EMI issues with the PTVs and the FAA certification. Nothing major he said all part of a new type of airliner.
airfoilsguy
Fri Jan 27, 2006 11:18 am
I was at the bar at CMH and watched an Embraer go on to the taxiway, sit for 20 minutes, taxi to takeoff position, do an aborted take off, sit on the taxiway for another 10 minutes, then taxi back to the gate. He then took off 1 hour later with no apparent problems. It wasn't Jet Blue though. I wonder what went wrong to cause him to do this??
[Edited 2006-01-27 03:19:20]
It's not a near miss it's a near hit!!
FLYACYYZ
Fri Jan 27, 2006 11:38 am
Bear in mind that the dispatch reliability of these aircraft are probably being benchmarked against B6's fleet of A320's--an aircraft which has graced the skies for 20 years, with B6 being a latecomer to this type.
I remember with the introduction of the A320's there were LOTS of kinks that needed to be worked out to improve dispatch reliability. The EMB's are an awesome little aircraft.
Above and Beyond
S5FA170
Fri Jan 27, 2006 11:43 am
The Embraer 170 you saw at CMH was either Shuttle America or Republic Airlines (was it DL Connection, UA Express or US Express?)
The computers on these aircraft are finicky. A lot of "error messages" the pilots receive are fixed by simply turning the airplane off and restarting it. Much like your home computer. This is probably what happened to the one you saw - an unnecessary warning of some kind.
-Tony
Prepare doors for departure and cross-check.
skyyblue
Fri Jan 27, 2006 12:02 pm
Quoting S5FA170 (Reply 4):
I was working a flight that got this "error message"...problem was it happend on our takeoff roll. We aborted and returned to the gate. It caused a delay of over an hour. I hope these kinks are worked out soon, because it really is a great airplane to work. I've only had a handful of customers that were LIVID about the TV's not working. Most people are very understanding.
My only "complaint" about the 190 is the "height" of the overhead bins...Yes..the smaller bins give more space per customer...but, the thicker bags can't fit and have to be gate checked. I'm told this is something that is being looked at.
airfoilsguy
Fri Jan 27, 2006 12:22 pm
I think it was a DL Connection. Thanks for the info it kind of gave me chills to see him abort the take off. I have never seen that before
Tbird
Fri Jan 27, 2006 12:25 pm
So does these things have Crtl Atl Delete keys? Could you imagine at 35,000 feet getting the blue screen of death, lol.
aerostar
Fri Jan 27, 2006 12:27 pm
a restart at 20,000 feet?? looks like they are using Windows as the OS  Smile
DLKAPA
Fri Jan 27, 2006 12:34 pm
"End Task- Airplane not responding?" What the f... does that mean???
planespotting
Fri Jan 27, 2006 12:43 pm
Quoting DLKAPA (Reply 9):
"No I don't want to send an instance of this problem to Embraer!...'Don't Send!'"
Do you like movies about gladiators?
jetbluefan1
Fri Jan 27, 2006 12:44 pm
According to the presentation, the reliability is supposedly improving quickly. Just looking at today's numbers, 8 of 10 flights on JFK-BOS were on-time. IAD-BOS-IAD wasn't as good - I'm assuming because of winds.
JetBluefan1
roseflyer
Fri Jan 27, 2006 1:25 pm
This is really unfortunate. The Embraer 170 series of airplanes had a lot of new design elements incorporated in them. The E170 is the first plane ever (that I know of) to have a single contractor design the entire electrical system. Hamilton Sundstrand designed it all.
I have also been on a flight where problems were found while taxiing out to the runway. They were all solved by doing a full restart of the airplane at the gate, which took about an hour. It amazes me how complex an airplane can be, yet something like restarting it can solve problems. It isn't supposed to work that way.
cricket
Fri Jan 27, 2006 4:40 pm
Every new type has eething problems, I'm sure in 12 months time this board will be filled with stories of troubles the A380 has during EIS or in 2007-08 people will be writing about the problems the 787 might face during EIS.
As they said in during the Roman Empire - Stercus Accidit!
been there, flown that
supa7E7
Fri Jan 27, 2006 6:22 pm
The E-170 seems pretty rock solid now. Why would the E-190 be different? Same cockpit and systems.
"Who's to say spaceships aren't fine art?" - Phil Lesh
antoniemey
Fri Jan 27, 2006 7:19 pm
Quoting RoseFlyer (Reply 12):
First step in computer troubleshooting is usually a full restart. This analogy is a bit off-topic, but I think it fits... When I worked in retail we had fancy new registers installed, touchscreens, thermal-printed receipts, built-in check readers & Printers, the works.
So, the supervisors (most of whom had worked for the company for 30 years or so) were all petrified when the slightest problem came up with them. Personally, as a lifelong computer user, I shrugged and if the problem caused the register to have major issues, flipped down the cover, pressed the little white button twice, waited two minutes, and problem solved.
Granted, an aircraft IS more complex, but it's still being RUN by a computer. Same as your car, same as a grocery store register, and same as your ISP's connection network.
Make something Idiot-proof, and the Universe will make a more inept idiot.
SNATH
Fri Jan 27, 2006 7:30 pm
Quoting SKYYBLUE (Reply 5):
I've been on an AC E175 a couple of times (I love them! great little planes!) and, as you can see, the bins are fine for the "approved" carry-on size:
MyAviation.net photo:
Photo © Tony Printezis
Are you saying that JetBlue actually installed smaller bins on their E190s?
Tony
Nikon: we don't want more pixels, we want better pixels.
thehangarcat
Sat Jan 28, 2006 1:21 am
Quoting Planespotting (Reply 10):
PC Load Letter?! What the F**k does that mean?
http://www.imdb.com/title/tt0151804/quotes
If it Ain't Boeing, I ain't Going!
ti717
Sat Jan 28, 2006 1:30 am
Sales pitch on the E190:
"Let me put it this way, Mr. Amor. The 9000 series is the most reliable computer ever made. No 9000 computer has ever made a mistake or distorted information. We are all, by any practical definition of the words, foolproof and incapable of error. "
(I am not going to give the movie)
[Edited 2006-01-27 17:34:45]
Sir, don't you think we should turn on the runway lights?" "No, that's just what there expecting us to do!"
jayspilot
Sat Jan 28, 2006 1:33 am
Behind the scenes jetblue has had their fingers crossed on this plane since usairways first started getting deliveries of the E-170 2 yrs ago. The E-170 quickly go the name E-180 for all the gate returns required and the software still has some minor glitches left. The plane is so freaking complicated that it has virtural circuit breakers instead of regular ones. Meaning for a simple icas message that you would have to pull circuit breakers in a boeing, airbus,crj or erj you now have to have a tech come hook up a lap top and diagnois it.
ChiGB1973
Sat Jan 28, 2006 1:41 am
I worked for TZ and have had to sit there while the flight deck crew "restarted" the system on a 738 and 752. It was only a few times, but it will be something that has to be done on occasion even when the E-190 is years old.
M
Sinlock
Sat Jan 28, 2006 2:06 am
Quoting Jayspilot (Reply 19):
It's seen written in many of our 170s..... I've also seen...
Hurry up and load it, Before it brakes
RiddlePilot215
Sat Jan 28, 2006 2:59 am
Quoting Ti717 (Reply 18):
Great movie btw.
Think about it this way, at least these are just simple 'software' faults and not hardware, and they're being caught now, or perhaps it's just a matter of each indiviual company tweaking with the software for their own performance characteristics?
God is good, all the time. All the time, God is good.
United787
Sat Jan 28, 2006 3:04 am
This happened to me on a UA A320 at SFO, ready to take off. The pilot said he needed to restart the plane. Got an uneasy laugh from everyone onboard.
Quoting Tbird (Reply 7):
Quoting Aerostar (Reply 8):
Hilarious!!!!!
 rotfl
skyyblue
Sat Jan 28, 2006 3:13 am
Quoting SNATH (Reply 16):
No, thats not what I said. I'm saying that people are (accidentaly?) being allowed to carry on bags that would otherwise fit in our A320 bins. At the end of boarding, I always have 3 or 4 bags in the aft galley that have to be checked because they dont fit in the overhead.
kyair
Sat Jan 28, 2006 4:00 am
Quoting pilot "Now DQI, I'm going to have to shut you down."
Quoting DQI "I'm sorry Capt Smith, but I can't let you do that."
10 points for decoding "DQI".  Smile
Don't cry because it's over, smile because it happened - Dr. Seuss
bohica
Sat Jan 28, 2006 4:13 am
Whatever happened to the good ole days where you could just kick it?  Smile
kyair
Sat Jan 28, 2006 4:23 am
Quoting Ti717 (Reply 26):
ERJ???
Well crap, it only took 10 minutes, 23 seconds - that was too easy! And here I thought I was the only one with so much nearly useless knowledge. Good job, Ti 717.
lightsaber
Crew
Sat Jan 28, 2006 5:03 am
Quoting KYAir (Reply 25):
 rotfl  For HAL was one step ahead of IBM...  rotfl
I have another thread on the telcon where Neeleman mentioned these issues. Jetblue Talk At Raymond James (by Lightsaber Jan 27 2006 in Civil Aviation)
Neeleman says that a lot of the issues were self inflicted. e.g., the HUD isn't certified (will be in 30 to 60 days), not enough pilots with > 100 hours experience on the E190 (required for flying in conditions with < 1 nm visability, delivery delays (Embraer is meeting contract, but Jetblue planned on nominal deliveries, etc.), etc. They even have two E190's flying without the IFE due to how tight the schedule is.
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
Crosscountry
Sat Jan 28, 2006 5:16 am
Had the same thing on a VS A340-600
Thankfully it was just one small system that needed to be reset not the whole plane.
Would probably still have been at JFK now!!!
sparkingwave
Sat Jan 28, 2006 6:40 am
Quoting Cricket (Reply 13):
I hope not, for all the Airbus bashers will never let us hear the end of it.
SparkingWave~~~
Flights to the moon and all major space stations. At Pan Am, the sky is no longer the limit!
Arrow
Sat Jan 28, 2006 7:03 am
Quoting Lightsaber (Reply 29):
I think I can see the problem here. Behind every IBM computer lurks the evil, Darth Vader clone -- DOS. They should have installed Macs in the Embraers. Then all the pilot has to do is click twice -- once for go, once for stop. Simple.
Never let the facts get in the way of a good story.
planespotting
Sat Jan 28, 2006 7:08 am
if anyone doesn't know what movie that is, I'm here to help.
2001: A Space Odyssey
aztec01
Sat Jan 28, 2006 8:04 am
"Daisy...........Daisy........give..................... me....................... your.........."
"Now that our Embraer has come to a complete stop, you may exit the plane. Please be sure to take all of your carry on possessions with you and thank you for flying HAL-Air."
JRodriguez136
Sat Jan 28, 2006 9:18 am
Here's an answer to what the airticle said:
What the article failed to report is that the first six months of operating a brand-new aircraft type are expected to be less reliable as crews gain operational and maintenance experience. The article also did not quote David saying, “We love this aircraft, and our Customers do, too.”
Reuters
The sky is not the limit...
ChiGB1973
Sat Jan 28, 2006 10:29 am
Quoting Bohica (Reply 27):
ERJ toolbox:
Ball peen.
Claw.
Sledge.
What else do you need?
M
wjcandee
Sat Jan 28, 2006 1:53 pm
The pilot inexperience is, in my view, a really big concern. They don't have enough guys and gals with ONE HUNDRED HOURS in the type? Yikes.
jetbluefan1
Sat Jan 28, 2006 1:55 pm
Quoting Wjcandee (Reply 39):
I'm pretty sure it has to be 100 hours on a revenue flight. Flight simulator and test runs don't count.
Am I correct?
JetBluefan1
srbmod
Sat Jan 28, 2006 11:51 pm
Quoting Bohica (Reply 26):
Fonzie worked on the ramp?
Any new a/c will have teething issues for the launch customer(s). AirTran and TWA went through similar tech issues with the 717 (Mostly computer and avionics related, but they had a few mechanical issues as well that were due to bad planning in the location of some items like the APU inlet.). After the first 3-4 months of service, most of the issues that pop up will have been fixed and some issues may pop up later on in service (Some issues aren't known until the first major maintenance check.).
Jeff G
Sun Jan 29, 2006 12:30 am
Quoting Wjcandee (Reply 36):
Well if it's a new airplane, nobody has experience in type. They are experienced in other aircraft - we're not talking green pilots here. They also have extensive simulator training, but that doesn't count towards the 100 hrs in type requirement for lower landing minimums. It takes a little over a month of line flying to gain that experience, so this isn't a long term concern. As more pilots are trained on the aircraft, the percentage of sub-100 hr pilots will drop significantly and improve bad weather limitations across the fleet.
DL4EVR
Sun Jan 29, 2006 12:54 am
Gee....I guess they're gonna have to take down all the billboards on the Van Wyck Expwy. (the main route to JFK) that say "A Better Way to Boston"  Smile
We Love To Fly And It Shows.
jetbluefan1
Sun Jan 29, 2006 1:42 am
Quoting DL4EVR (Reply 40):
Actually, the flights have been running mostly on-time this month. I think all the major kinks have been worked out.
BTW, I never saw that billboard. But on the Belt upon entrance to the JFK Expwy, I always see that DL advertisement that says "NYC to Nassau. Today-o. Day-o." I still don't understand it...why would they use such prime location to advertise for a 1x daily CR700 flight? In addition, I don't even understand the advertisement itself. I personally think that their advertisements touting the online check-in were much better.
JetBluefan1
BOAC911
Fri Feb 03, 2006 8:52 am
Wasn't there a thread some time ago about Alitalia have so many problems with their small fleet of E70s? I heard that they are considering replacing them with new A318s. Their E70 are going tech too often and has been the cause of a lot delays and even cancellations. Could someone confirm? Thanks.
crogalski
Fri Feb 03, 2006 9:00 am
Ok, so I flew to and back from BOS yesterday, and on the flight up there, I was speaking to the FA about our E190s.. And he told me the rumor that he heard from up above was that if the problems on the E190's continue, that they will scrap the entire "project" and go with A318's or A319's from another airline. I can't remember which one he said, but it wasn't FlyI.
He also said that one of the main problems is, that the computer is too sophisticated for the airplanes system, he said it something like that.
He also told me that the Embraer Reps are very embarrased about the entire situation, and that this plane has got off to this kind of start, and he said that they have never had a new a/c type start like this...
So it will be interesting to see what happens, and this is only a rumor that's been going around..
A319 A320 A321 A330 B717 B727 B737 B747 B757 B767 CRJ200 CRJ700 CRJ900 DC9 E145 E190 MD88 Q400 | AA AB B6 CO DL EI FL NK
ChiGB1973
Fri Feb 03, 2006 9:39 am
Quoting Crogalski (Reply 43):
They can't do that unless they stipulated it in the initial contract and I highly doubt that EMB would have allowed it. I don't know that there is a "lemon" law for airplanes, but I kind of doubt it. They would still have to take delivery of the replacement. Besides the fact the B6 will have to keep most of the E-190s they have firm orders for, at least without substantial penalties, then they are going to add a 318 or a 319. Now they have 3 aircraft types. You just sent them further down the tubes.
Of course they are. But Neeleman has also said that B6 implemented the plane too quickly. It is not entirely a EMB problem. Airbus is embarrassed over the A-380 delay, but I doubt anyone is able to cancel without substantial penalties. Of course, the initial contract is the kicker. If it were a couple of years, there would be a problem.
M
MidnightMike
Fri Feb 03, 2006 10:52 am
The Jetblue pilots that were the first one to fly the 190's, more than likely received a high number of simulator training & in turn probably assisted in writing the training program for Jetblue.
The Checkairmen or Senior pilots will in turn, check out/train the other line pilots.
Having less than 100 hours on the 190 is a "non-issue, or any reason for concern.
NO URLS in signature
ChiGB1973
Fri Feb 03, 2006 11:33 am
It's an FAA requirement for low visibility. I flew with a 757 captain at TZ that had upgraded and finished his 100 hours during our trip. We lucked up on the weather in TZL a day or two before his milestone, had it been a little worse we would have diverted, not because of his ability nor because of the capability of the aircraft (757-33N), but because of his captain hours. Not to say I disagree with it. I am not sure of his right seat hours, but since he upgraded to 757 captain at TZ, I am relatively sure he is quite experienced.
This was one of my last trips prior to furlough and I also credit this captain, the first officer, international officer and the cabin crew with one of the best trips I ever had at ATA. Just thought I would throw that in since I was thinking about it. Thanks Mark and crew!
M
MiCorazonAzul
Fri Feb 03, 2006 12:25 pm
Sorry man but looks like our fellow crewmember must of been on something because that can't be true. First off, the A318 and A319 are NOT replacements for the E190. Of those two, maybe the A318 but it is STILL not the same as the E190. The problems with the E190 will be solved since they are only minor glitches. Afterall, if there were SERIOUS problems with the plane, do you honestly think they would be flying right now?  no
Live for Today.....tomorrow is NOT guaranteed.
