fly_yhm
Flight Plan YVR-taipei Tiawan-BNE
Sat Jan 28, 2006 11:28 am
Hey im mostly wondering what interesting things my friend might see (Alaska)?
Thanks for the input.
Where will you spend eternity? He,s more real then you think!!!!!
MarshalN
RE: Flight Plan YVR-taipei Tiawan-BNE
Sat Jan 28, 2006 12:02 pm
Well, depends on what time your flight leaves, you may or may not see anything over Alaska as it might be dark by the time you get over there with the long winter nights. It's mostly a long ride over the ocean (and you might not cross Alaska at all, but only scrape the Aleutian Islands). It will most likely fly over Japan at some point, which is probably the only bit of land before hitting Taiwan.
Not sure about the BNE leg.
