farmenta
JetBlue (B6) Time Performance BOS-JFK
Tue Jan 31, 2006 9:19 am
Hello to all the Gurus,
I need a very specific information about B6 time performance for flight
#1001 which runs from BOS-JFK and very specific to Mondays and Tuesdays!
I need to make a connection on JFK to SJC and the 1st flight out of BOS to JFK is 1001 at 6:05 and the 1st flight from JFK to SJC is at 8:05.
According to B6 the BOS flight arrives to JFK at 7:20 a.m. and the SJC flight departs at 8:05. That means I have 30/35 minutes to connect.
So here are my questions?
1. How is the time performance for the BOS-JFK flight 1001 on Mondays and Tuesday
2. Does 30/35 minutes is enough time for connection?
3. Does flight 1001 and 169 depart from the same terminal?
If anyone can help me out with this info. I would really appreciated.
Thanks you Gurus,
-Fer
Jerseyguy
RE: JetBlue (B6) Time Performance BOS-JFK
Tue Jan 31, 2006 9:23 am
Quoting Farmenta (Thread starter):
Yes, all Jetblue flights depart from Terminal 6 at JFK.
Provided you flights are on-time. It should be. But maybe a crewmember who frequents JFK might be able to confirm
Webmaster of an unoffical TTN page see profile for details
jetblueatjfk
Tue Jan 31, 2006 11:48 am
Well I think 30 mins is cutting it close. I look at the JFK-BOS-JFK flights a lot and it is hard to tell. You should also look at the night time flight but so far 1001 seems like an ok flight for ontiome. You should look into the BOS-SJC flight that is nonstop that is later on, it departs BOS at 3:20pm and arrives in SJC at 7:10pm Local. That would probably be a better choice if you can do that because dealing with ontime into JFK gets risky. I would se
 airplane jetBlueAtJFK airplane
bond007
Tue Jan 31, 2006 12:00 pm
These are LANDED times, not gate times (EST):
| 2006-01-02 07:57:00 |
| 2006-01-03 06:58:00 |
| 2006-01-04 06:50:00 |
| 2006-01-05 07:31:00 |
| 2006-01-06 07:01:00 |
| 2006-01-07 06:52:00 |
| 2006-01-09 07:02:00 |
| 2006-01-10 06:53:00 |
| 2006-01-11 06:55:00 |
| 2006-01-12 08:01:00 |
| 2006-01-13 06:53:00 |
| 2006-01-13 12:56:00 |
| 2006-01-14 07:57:00 |
| 2006-01-16 06:55:00 |
| 2006-01-17 06:55:00 |
| 2006-01-18 07:04:00 |
| 2006-01-19 07:03:00 |
| 2006-01-20 06:58:00 |
| 2006-01-21 07:05:00 |
| 2006-01-24 07:16:00 |
| 2006-01-25 07:17:00 |
| 2006-01-26 07:09:00 |
| 2006-01-27 06:57:00 |
| 2006-01-28 06:55:00 |
| 2006-01-30 06:55:00 |
Credit http://www.red1aviation.com
Jimbo
farmenta
Thu Feb 02, 2006 4:58 pm
Thank you guys for the info.
-F
