gunsontheroof
Upper Deck Of 747 Freighters
Fri Feb 03, 2006 9:34 am
I couldn't find any answers by searching, so I'll poke your collective brains. The thread title says it all...what are the upper decks of 747 freighters used for? Space for smaller cargo? Crew rest areas/cigar lounges? I would imagine it varies from carrier to carrier, so specific examples would be great.
*Edit*
Didn't think to do a photo search...I've got some answers now, but maybe we can still squeeze a discussion out of this.
[Edited 2006-02-03 01:41:28]
UpperDeck79
RE: Upper Deck Of 747 Freighters
Fri Feb 03, 2006 11:02 am
As you already found out, it's basically crew rest and seats for people who travel with the cargo (on special occasions).
AY and ANA rock!
sllevin
Fri Feb 03, 2006 11:47 am
Has anyone ever attempted to market those seats? After all, it would be less than 19 people, so no flight attendant needed. Just business class seats, a self-serve bar (obviously, no alcohol) and buffet, and *poof* you could perhaps make some decent money at it.
Steve
levent
Fri Feb 03, 2006 11:48 am
I've been in the upper deck of a Martinair 747-200F. It's a crew rest area with business class seats, a galley, and a large tv with a nice collection of videos.
ups757
Fri Feb 03, 2006 11:49 am
The top deck on the old UPS747 (100/200) still have the First class seats in them for extra crew members or jumpseaters. I have not heard of us using the top deck on the New 747-400F. They may add some crew rest areas as the new 747-400 will be flying longer flights.
MX757
Fri Feb 03, 2006 3:55 pm
Don't forget the bunk beds. I saw them on an AF 747-200F.
Is it broke...? Yeah I'll fix it.
PhilSquares
Fri Feb 03, 2006 4:06 pm
Quoting UPS757 (Reply 4):
The standard configuration from Boeing on the 744F is 6 J seats and two bunks. Remember the 744F doesn't have the same stretch as the 744 pax. The 744 conversion takes a large part of the upper deck and removes the floor to accommodate 3 meter pallets on the main deck.
Fly fast, live slow
A342
Fri Feb 03, 2006 10:56 pm
Quoting PhilSquares (Reply 6):
Do I get this right, there is no more floor in the aft part of the upper deck ? Is there some sort of separating wall installed (in order not to fall into the maindeck... Smile ) ?
Exceptions confirm the rule.
ehho
Fri Feb 03, 2006 11:11 pm
Quoting A342 (Reply 7):
Not speaking out of experience, but I'd guess it's a pressurized bulkhead similar to 74M/E.
"Get your facts first. Then you may distort them as much as you please" -- Mark Twain
lotsamiles
Fri Feb 03, 2006 11:49 pm
Quoting EHHO (Reply 8):
I believe it is simply a physical bulkhead to finish out the compartment that also blocks any potential smoke from the cargo compartment.
The 744 combi barrier separating the cargo from the passengers provides a restraining wall for cargo and also a smoke barrier.
In each case the entire aircraft is pressurized (at least everything forward of the rear pressure bulkhead).
Lotsamiles
whitehatter
Sat Feb 04, 2006 12:02 am
Quoting Gunsontheroof (Thread starter):
Generally crew rest, a small galley and toilet. Many have Business Class equivalent seats fitted and some form of IFE, with extra seats above those needed for the crew in case company staff are deadheading on the flight.
They are actually quite nice in general! More space than a standard 742 upper deck as the staircase is missing, main deck access being via an aluminium ladder and hatch in the floor. There is also usually a desk of some form for the loadmaster position, to do the freight paperwork.
Lead me not into temptation, I can find my own way there...
dtwclipper
Sat Feb 04, 2006 12:13 am
Here is one from NW.
I know there are more in dB, but don't have time to do a wider search.
Photo © Nick Onkow
And Cargolux
Photo © Jonathan Rankin
[Edited 2006-02-03 16:19:57]
Compare New York Air, the Airline that works for your Business
Sat Feb 04, 2006 1:49 am
JL -400F is similar to Cargolux in the previous post, 6x Business Class seats, and behind the door, 4 beds. And a galley between the seating area and flightdeck.
JL -200F original freighters and some ex pax have only 3 Economy seats (1 row), 2 beds, and a galley on the UpperDeck.
Photo © Eric Meijer
Converted freighters (like JA8161/8193) have a 6 very roomy Business Class seats, lots of space, and 2 beds. Those are the best upperdecks in JL's cargo fleet.
legacyins
Sat Feb 04, 2006 3:59 am
Quoting Sllevin (Reply 2):
I remember a couple of years ago, Cargolux filed an application to carry passengers on top deck of thier cargo flights. Nothing became it.
tsnamm
Sat Feb 04, 2006 6:35 am
The 747-200's actually have more space than the 747-400's for some reason...not really sure why...
GQfluffy
Sat Feb 04, 2006 8:46 am
Quoting Tsnamm (Reply 14):
Are you talking about the 744's that have been converted from pax to cargo? If so, the upper deck goes back farther, hence lowering the capacity on the main floor....
This isn't where I parked my car...
jeffry747
Sat Feb 04, 2006 9:14 am
The upper decks of a few UPS 742's. IIRC, the seats are actually quite comfortable.
Photo © Tim Lane
Photo © Dmitry Kudryn
C'mon Big B, FLY!
FLY777UAL
Sat Feb 04, 2006 9:27 am
Quoting Legacyins (Reply 13):
Did Cargolux drop the ball on this, or was it because of some regulatory issue?
F L Y 7 7 7 U A L
patroni
Sat Feb 04, 2006 9:36 am
The 400F has two more 3m high main deck pallet positions than the 200F, so the floor of the upper deck is shorter, even though the "hump" ha sthe same size when looking at it from the outside. You can also see it at the windows: The third cabin window on the 744F upper deck is the crew rest, with a bulkhead behind it. The position of this window is much further forward than the position of the rearmost window on a 200(F) upper deck.
I think that up to the 1980s, CV could carry passengers on board the 200F. There was even a flight attendant on board. I strongly doubt that CV ever filed an application for pax carriage on the 400F though.
JAM747
Sat Feb 04, 2006 1:02 pm
A little off the topic , but what is on the upper deck of the Air Force 1 747?
USAFHummer
Sat Feb 04, 2006 1:20 pm
Quoting JAM747 (Reply 19):
Communications gear...and the cockpit of course
Greg
[Edited 2006-02-04 05:20:36]
redflyer
Sat Feb 04, 2006 1:25 pm
I believe it's the communications center. I spoke with a retired MSgt at Oshkosh a few years ago who worked the old 707 Air Force One and he said all the comm center activities were moved up there when the 747 was put into service.
My other home is in the sky inside my Piper Cherokee 180.
legendDC9
Sat Feb 04, 2006 1:26 pm
Very weak... the UPS cargo seats look just like the Maxjet seats... Old...
Photo © Michael F. McLaughlin
Actualy, the UPS ones look wider...
Stitch
Sun Feb 05, 2006 2:59 am
Well the 767 has 19" wide seats, vs. 20-21" on the 747.
N521UP has UA's last-generation of Business Class seats. Wonder if she was an ex-UA 742 or UPS got a good deal on them.
imatams
Sun Feb 05, 2006 3:56 am
LY's 742F,s have a couple of old business class seats, a little galley for getting drinks and heating meals etc. and in the rear 4 matrasses on the floor with blankets and pillows. So there's enough opportunity for the crew to relax when able..
IM
BrowntailWhale
Sun Feb 05, 2006 7:38 am
Quoting Stitch (Reply 23):
521 is ex-Singapore. No idea where we got the seats from.
UpperDeck79
Fri Feb 10, 2006 11:33 pm
How about the -300 converted freighters with their long upper decks:
Photo © Magnus Trippler
Photo © GSR
Anything special up there?
AY and ANA rock!
CV747
Mon Feb 13, 2006 8:32 pm
Very simple, The upper deck is shorter on the 744F to accomodate two more "high" palets on the main deck. Palets loaded through the nose of a 747 are lower then the one which can be loaded through the rear cargo door.
Quoting Patroni (Reply 18):
Cargolux had 14 fist class seats on their 747-200's. They sold tickets to passengers, but only to Asia. It was the FAA which stopped that passengers could be carried on freighters to and from USA. In the end only staff and their families could fly, I think that is astill the case.
