AviationAddict
Help With A.net Aircraft Designations
Mon Feb 06, 2006 12:30 am
Hi all, I'm still a little new to all of this so please bare with me while I sound like an idiot. What do the last two digits of the aircraft type designations mean? For example: 747-4H6, what does the H6 signify? Also, how do you folks know when all the various aircraft featured in the database were built, is there someplace online where I could look this stuff up? (I've yet to find anything on any of the manufacturer's websites.) Any help would be much appreciated!
srbmod
RE: Help With A.net Aircraft Designations
Mon Feb 06, 2006 1:04 am
In Boeing a/c designations, the last two places in the series represent the customer code. For example a 737-700 series a/c delivered to AirTran would be a 737-7BD (Unless it's one of the ones leased from G.E. Capital Aviation Services, which would make it a 737-76N). Here is a site that lists all of the Boeing customer codes:
http://www.airlinecodes.co.uk/
Just click on the tab that says "Boeing Codes"
AviationAddict
Mon Feb 06, 2006 1:18 am
Does the same apply to other manufacturers? I was just using the 747 as an example, but I've seen similar designations on Airbuses and other types as well. For example, Airbus A319-111. Does the 11 represent the customer code too (which in this case I would assume would be Frontier)?
[Edited 2006-02-05 17:22:35]
jorge1812
Mon Feb 06, 2006 1:35 am
Quoting AviationAddict (Reply 2):
No. It's for the engine version...but I don't understood the system. IIRC LH and DE have the same engines on their A-320 but LH has the -211 and DE the -212.
Georg
PanAm747
Mon Feb 06, 2006 2:07 am
To AviationAddict and all other interested parties:
The Boeing production code list is available on-line at various places; however, I have a complete list available I can send. Let me know!!  bigthumbsup
Pan Am:The World's Most Experienced Airline - P(oor) S(ailor's) A(irline): San Diego's Hometown Airline-Catch Our Smile!
OB1504
Mon Feb 06, 2006 2:25 am
Quoting Jorge1812 (Reply 3):
The -212 has higher-rated engines. The A320-211 has CFM56-5A1 engines, the A320-212 has CFM56-5A3, and the A320-214 has CFM56-5B4/P engines. The same is true of the A320-231, -232, and -233, with V2527-A1 , V2527-A5, and V2527E-A5 engines, respectively.
For clarification, the Boeingcustomer code does not change if the owner changes. In some instances, an airline may cancel an order and the aircraft could be delivered to another airline, but the aircraft would keep the code of the airline that originally ordered them. This is the case with some of Virgin Atlantic's Boeing 747-400s. These are 747-443s, originally bound for Alitalia, until they cancelled the order so the aircraft were delivered to Virgin instead.
BTW, welcome to Airliners.net!  airplane
[Edited 2006-02-05 18:30:46]
AviationAddict
Mon Feb 06, 2006 4:42 am
Quoting OB1504 (Reply 5):
Thank you very much! Thank you for the clarification as well!
Gr8Circle
Mon Feb 06, 2006 4:50 am
I'm sure Boeing has a reason for this, but can anyone explain why its so? Doesn't it make sense to use the code of the airline to whom the brand new aircraft is delivered.....?
lincoln
Mon Feb 06, 2006 5:27 am
Quoting Gr8Circle (Reply 7):
The only thing I can think of is to reflect options/customizations chosen by an owner, i.e. flight deck configuration, etc. (For example, I read somewhere that [some of] TWA's aircraft have switches that flip the opposite direction AA's aircraft)... Hypothetically speaking, if TWA had an order in prodution when they were acquired by AA and those aircraft were built with the 'reversed' switches and then delivered to AA, it would make sense to me to use TW's customer code.
It could also be some sort of compliance thing (once it starts being built as a 737-7H4 it stays a 737-7H4) but that makes a little less sense to me.
I would appreciate it if someone sets me straight  Smile
Lincoln
egnr
Mon Feb 06, 2006 5:46 am
Airbus model numbers are decyphered as follows...
A3XX-ABC
Obviously, A3XX is the model - e.g. A320, A330, A340, A380, etc.
'A' denotes the series of that model - e.g. A340-200, A340-300, A340-500, A340-600, etc.
'B' denotes the engine manufacturer as follows:
'0' = General Electric,
'1' = cfm International,
'2' = Pratt & Whitney,
'3' = International Aero Engines,
'4' = Rolls Royce,
'6' = Engine Alliance
Examples:
A320-111 - an A320-100 fitted with the first variant of the cfm powerplant made available on the A320.
A300-605 - an A300-600 fitted with the fifth variant of the General Electric powerplant made available on the A300.
A330-342 - an A330-300 fitted with the second variant of the Rolls Royce powerplant available on the A330 model line up.
Note: ('5' is not used - not sure why, maybe the joint venture for the engines on A400M was assigned the '5'?).
'C' denotes the variant of that engine, e.g. on the A340-500 and A340-600. Both use the Rolls Royce Trent 500, but the A340-600 uses a higher thrust variant, so we have A340-541 and A340-642.
MyTravel, Thomas Cook and Monarch all fly A330-243s with high seating capacity for IT charter work. Emirates, bmi, Etihad also fly A330-243s but with far fewer seats.
Airbus's numbering system is more like that of a car manufacturer - everybody has the same model designation (badge on the trunk), but picks their own options (configures their own interior - seat numbers, etc.).
Whereas Boeing give each customer models with their own unique numbers, e.g '7X7-X36' for British Airways, '7X7-X38' for Qantas, '7X7-XH4' for Southwest.
7late7, A3latey, Sukhoi Superlate... what's going on?
jorge1812
Mon Feb 06, 2006 7:04 am
I understand that a B 747-430 stays a B 747-430 whatever happens to it. But what's with an Airbus? Can an A 320-211 be converted to an A 320-212 or even an (e.g.) A 320-232?
Georg
breiz
Mon Feb 06, 2006 8:09 am
Quoting Jorge1812 (Reply 10):
Certainly. And it has happened a number of times.
The Airbus system is in fact very simple.
You get an airframe with its weight characteristics symbolized by the first digit (for ex. -2xx) and engines symbolized by the following two digits
(for -x12).
If the airframe or the engines are modified, the three digits are modified accordingly.
egnr
Mon Feb 06, 2006 8:43 am
The first A380-861 will be converted to an A380-841 for onward sale to Etihad I believe.
Also, the first A318 has had PW engines (A318-121), then it flew with cfm engines (A318-111) and is now flying again with PW engines (A318-121). However, all of the photos in the database here list A318-121 despite the different engines (in some cases, the designation on the photos is different to these two - the only designations avaialble on the A318).
bohica
Mon Feb 06, 2006 9:25 am
My guess is it has a lot to do with paperwork, and there is lots of paperwork. Once a plane is ordered and cancelled, then someone else picks up the order, it would be a nightmare to change the customer number on all that paperwork.
Devilfish
Mon Feb 06, 2006 10:27 am
Quoting EGNR (Reply 12):
Could just have been missed by the caption writer. Frontier's aircraft carry -111 designation.
474218
Mon Feb 06, 2006 12:55 pm
Quoting Bohica (Reply 13):
It has little or nothing to do with paperwork. There are structural differences between operators, one operator may have a galley in one location the other airline may have a lavatory there. The structural attachments are there for a galley or a lavatory, to convert from one to the other could take considerable time and money. One may have structural up grades to increase the GTOW and the operator doesn't. There are any number of differences between customer models.
Another thing to consider is that if an order is cancelled the manufacture my try and collect money from the canceling airline. They could say the airframe was built for them and had to be sold at a discount to another operator because of configuration differences.
