kevin
737 Overruns Runway In BKK
Mon Feb 06, 2006 4:58 am
Apprently a Nok Air 737-400 overran runway at Bangkok International. The plane was headed to Phuket when pilots reported a trouble with the engine. They decided to come back to BKK and that is when the incident happened.
I wonder if they landed on the golf course?
dogfighter2111
RE: 737 Overruns Runway In BKK
Mon Feb 06, 2006 5:06 am
Ohh, second in one day. Pilots aren't all that luck are they  Wink
After saying it was an engine problem, i wonder if this is a bad accident or something?
Any injuries etc.?
Mike
N908AW
Mon Feb 06, 2006 5:27 am
One night in Bangkok and the world's your oyster...
Hmm...where were the news helicopters? Where were the pessimistic CNN reporters? Where were the 'analysts' trying to link the event to the Greek aircraft crash a few months ago?
'Cause you're on ATA again, and on ATA, you're on vacation!
B742
Mon Feb 06, 2006 5:50 am
As smooth as silk
levent
Mon Feb 06, 2006 11:27 am
I don't know what happened exactly, but the information given is contradictory. First it says that the plane made an emergency landing, and then it says that it failed to lift off the runway. You can't have both, can you?
One version says that they lost an engine during the take-off roll and skidded off the runway, and the other that they did lift off at 1.48pm and executed the emergency landing at 2.00pm.
The plane was HS-TDD, still in Thai Airways colours but without THAI titles and with a sticker "Operated by Nok Air"
levent
Mon Feb 06, 2006 2:55 pm
This is Nok Air's press release, confirming that the plane did take off and return to the airport:
Press Release: Nok Air Flight in Emergency Landing
Bangkok, 5 February 2006 – Nok Air Flight DD7506 was forced to make an emergency landing this afternoon at Bangkok ’s Don Muang Airport. All 110 passengers and 5 crewmembers are safe, with only two minor injuries incurred during the emergency disembarking procedures.
The Nok Air flight left Bangkok at 13:48 for Phuket. All take off procedures were normal and without incident. Upon reaching an altitude of 1500 feet a noise was heard from the right wing, which required investigation. The right wing engine then lost power and the Captain made the decision to return to Bangkok.
Following set guidelines and procedures the Captain climbed to 3000 feet and then brought the plane down for a smooth landing. Upon touch down there were apparent issues with the brake system and the plane went off the end of the runway as it came to a stop. At this point the Captain turned the plane to the left so that it would come to rest on a grassy area, thus insuring the safety of the passengers. Following safety procedures the plane was evacuated via the door slide. The plane was undamaged and the causes of these technical issues are under investigation.
satx
Mon Feb 06, 2006 4:38 pm
Quoting Levent (Reply 5):
Never heard of that one before. Any truth to this?
A300 A319 A320 A321 A332 A333 A388 B727 B732 B733 B735 B737 B738 B739 B742 B743 B744 B752 B753 B763 B764 B772 B77E B77L B773 B77W B788 B789 C200 C700 C900 DHC2 DC9 E145 E170 E175 E190 F100 MD81 MD82 MD83 MD87 MD88 MD90
levent
Mon Feb 06, 2006 9:52 pm
The plane landed on 21R. BKK has a strip of grass between 21L and 21R (with the famous golf course) so by turning left it ended up in the grass. The other side has all kinds of buildings. Whether the pilots intended to turn the plane onto the grass I don't know.
Tue Feb 07, 2006 12:25 am
Was it Turbine Damage.Guess we'll need to await the Investigation report.
regds
MEL
haj96
Tue Feb 07, 2006 1:05 am
Two almost identical incidents in one day. Was the runway also slippery because of snow like at AAR?  silly
Guess not, eh  no
haj96
BG777300ER
Tue Feb 07, 2006 1:48 am
Quoting N908AW (Reply 2):
Haha, good song...
