OPNLguy
Something New On Southwest...
Mon Feb 06, 2006 1:10 pm
Today (Feb. 5th) was the first day of SWA flights being able to conduct extended overwater operations. The old limit was no more than 50nm offshore, and the new one is no more than 162nm. This will allow fuel-saving shortcuts on flights to/from Florida...
http://i34.photobucket.com/albums/d143/OPNLguy/FLLBWIoverwater.jpg
[Edited 2006-02-06 05:37:11]
wedgetail737
RE: Something New On Southwest...
Mon Feb 06, 2006 1:12 pm
Perhaps we could see additional services in and out of FL in the near future.
777wt
Mon Feb 06, 2006 1:21 pm
Isn't this related to ETOPS operations?
OPNLguy
Mon Feb 06, 2006 1:24 pm
Quoting 777WT (Reply 3):
No, ETOPS is another thing entirely. The 162nm limit doesn't get one very far if they were going, say, LAX-HNL...  Wink
2H4
Mon Feb 06, 2006 1:29 pm
What other 737 operators are approved for extended overwater ops?
I imagine this will make it a lot easier to deal with wx in and around the Gulf region...
2H4
Intentionally Left Blank
charlipr
Mon Feb 06, 2006 1:30 pm
Did they get rafts in there planes to do this route?? I know that any time a plane wants to fly on an "AR" route, for example AR16, operators require rafts on board. FAA recommends to use AR routes more often, as to minimize departure delays when operating to/from the NE and Florida and vice-versa.
OPNLguy
Mon Feb 06, 2006 1:35 pm
Quoting Charlipr (Reply 6):
Some ARs require liveVESTS only; those further than 162nm require both lifeVESTS and lifeRAFTS...
No rafts on SWA aircraft, just vests...
charlipr
Mon Feb 06, 2006 1:37 pm
Quoting OPNLguy (Reply 7):
Cool!!! I learn something new everyday in this forum!!!
OPNLguy
Mon Feb 06, 2006 1:42 pm
Quoting 2H4 (Reply 5):
Amen to that. The increased flexibility for weather-re-route will be significant...
Quoting Charlipr (Reply 8):
It'll be a bit odd for me, as I haven't operated via the ARs since I left Air Florida in 1982.
The 162nm figure originally came from an old exemption that National Airlines requested (and was approved for) eons ago so they could get between Florida and the NE, and vice versa.
charlipr
Mon Feb 06, 2006 1:51 pm
I work for a company that does international flight plans for a well-known fractional aircraft operator, and we use AR routes all the time as long as we have a raft on board for everybody. If you start using the AR routes you will see that your aircraft will be cleared by ATC quicker, during bad weather, and those filed using the land route will be ground stop much longer. Many of the pref routes out of the New York area to the Bahamas, and Florida go on the AR routes.
2H4
Mon Feb 06, 2006 2:01 pm
And to think.....earlier today, over in one of the Wright threads, someone was claiming "Southwest's options to improve productivity are very limited".
 rotfl
2H4
OPNLguy
Mon Feb 06, 2006 2:05 pm
Quoting 2H4 (Reply 11):
They don't know us very well, dooooo they...?
When a solid line of thunderstorms cuts Florida in half, the new flexibility for re-routes will save hours of time...
MX757
Mon Feb 06, 2006 3:10 pm
All of CO's 737NG fleet are approved for 75 min ETOPS diversion authority.
Is it broke...? Yeah I'll fix it.
mandargb
Mon Feb 06, 2006 4:15 pm
Aloha makes Hawaii to OAK / SJC / SFO area in their 737s.
satx
Mon Feb 06, 2006 4:59 pm
Wouldn't the title of this thread be more accurate if it said "Something New UNDER Southwest?"  Wink
I guess all aircraft now have the vests? I think you mentioned that this was a requirement in WN's view, if not a true legal requirement on its own. I'm still waiting for the 'earth shattering' thread about some new intl. destination or a new aircraft type. Well, at least I can always hope.  Smile
Open Season on Consumer Protections is Just Around the Corner...
johnboy
Mon Feb 06, 2006 5:51 pm
Funny you should mention this...I was on #1314 from PHX to OAK tonight, and lo and behold, during the safety demo the F/A's whipped out the vests and demonstrated how to use them.
I thought, "Now wait a minute...I've never seen THAT before on Southwest."
OPNLguy
Mon Feb 06, 2006 6:28 pm
Quoting Johnboy (Reply 15):
Hence, why I started this thread...  Wink
Quoting SATX (Reply 14):
As I said earlier, it was to attain fuel savings from more direct routings to/from Florida, and get additional flexibility when re-routing for weather. The previous 50nm limitation was, quite simply, too limiting, and the new 162nm limit will make for a better operation. This has nothing to do with ETOPS, although I'm sure people will be confusing extended overwater operations with ETOPS for quite some time...
satx
Mon Feb 06, 2006 7:09 pm
Quoting OPNLguy (Reply 16):
So does that mean not all WN aircraft have them yet? That's all I was really curious about. I thought I remember you stating that all aircraft would get these vests, though I couldn't remember if this was due to a specific requirement stating the whole fleet must be so equipped or was simply a business decision on WN's part.
Thanks to your previous posts I'm well aware that this has nothing to do with ETOPS. When I mentioned international destinations I was merely thinking along the lines of Mexico and Canada. I understand that ETOPS is a far more intensive process than simply adding life vests and that it requires additional certification of both the carrier's aircraft and maintenance programs.
OPNLguy
Mon Feb 06, 2006 8:48 pm
Quoting SATX (Reply 17):
No, all have them. They started the installation process about a year ago (once the -200s were retired), and didn't "switch on" the new procedures until all remaining aircraft were equipped, all crews had been trained, and all seatback cards had been changed.
LongbowPilot
Mon Feb 06, 2006 9:58 pm
Quoting Wedgetail737 (Reply 1):
Just because they have a new route, does not mean an increase in Gate Capacity.
sbworcs
Mon Feb 06, 2006 10:22 pm
Sorry to sound so stupid but could someone explain for me what an AR route is?
Stephen
The best way forwards is upwards!
OPNLguy
Mon Feb 06, 2006 10:31 pm
AR = Atlantic Route, a Jet Airway (one of several) off the east coast..
SPREE34
Mon Feb 06, 2006 11:35 pm
Quoting OPNLguy (Reply 21):
It should be noted that these offshore routes threaten the very existence of the DFW airport and the North Texas economy....................
Sorry. I couldn't resist.
I don't understand everything I don't know about this.
txagkuwait
Mon Feb 06, 2006 11:49 pm
And every time Southwest uses as AR, American cuts a flight between DFW and ILE, GGG, TYR, ACT, ABI, & SJT.
Ohhhhh the humanity....
surfdog75
Mon Feb 06, 2006 11:57 pm
Almost every other carrier has been doing these routes for years.
nateDAL
Tue Feb 07, 2006 12:08 am
Quoting MX757 (Reply 12):
What about the 737s out of GUM?
Some of those routes need more than 75 minute ETOPS, like GUM-MNL, GUM-HKG, GUM-Japan
Set Love Free
3201
Tue Feb 07, 2006 12:16 am
Not just the AR's, but the Q's across the gulf as well.  thumbsup
7 hours aint long-haul
Continental
Tue Feb 07, 2006 12:48 am
Sweet! Never would have known that! What was keeping them from the 162nm limit in the first place?
incitatus
Tue Feb 07, 2006 12:57 am
Quoting 2H4 (Reply 10):
Yes I made that claim. And it stands. It's possible that Northwest or United improve productivity by a large amount because their operations are relatively inneficient. That's not possible for Southwest. But if you think that's possible, go ahead and suggest a way for Southwest to improve productivity by 10%.
Conservatives against Trump
txagkuwait
Tue Feb 07, 2006 1:34 am
>>Yes I made that claim. And it stands. It's possible that Northwest or United improve productivity by a large amount because their operations are relatively inneficient. That's not possible for Southwest. But if you think that's possible, go ahead and suggest a way for Southwest to improve productivity by 10%.<<
Many, many, many things that can be done. Not all are really attractive, and let's hope they don't become necessary. But they "can" be done.
1. A 10% chop on employee wages. Obviously, the unions are not gonna like it. And it probably won't become necessary. And even with a 10% slice, you'll find WN employees better paid than their counterparts.
2. A 10% increase in aircraft utilization. Yes, WN has decent utilization...somewhere in the 11 hr per day range. You could kick that on up to 12.2 hrs a day. Thrown in some red eye transcons. That will have the double edged effect of increasing your utilization AND increasing your average stage length, which will further reduce the CASM.
3. Put two rows of seats back in the 737s, reducing pitch to something around 30 or 31 inches. That gives you 149 seats per aircraft. Congratulations - that, by itself, just reduced your CASM by almost 10%
4. Reducing staffing at the Res centers. Southwest's typical call answered within 20 seconds seems sort of funny when you hear the USAirways Dividend Miles Chairmans Preferred members griping about being on hold for 2 hrs.
I didn;t say my suggestions were particularly good ones, or even desirable. All I promised is that these suggestions would all increase efficiency by 10% or greater when taken together.
IceTitan447
Tue Feb 07, 2006 1:59 am
Quoting TxAgKuwait (Reply 29):
Off topic, do you know what WN's CASM is? Currently.
2H4
Tue Feb 07, 2006 2:22 am
Quoting Incitatus (Reply 28):
It most certainly IS possible. As TxAgKuwait points out, the options may not be attractive, but they're there. Furthermore, it's safe to assume there are options none of are privy to.
This a a perfect illustration of one very important difference between WN and many other carriers. The attitude of "It's not even possible" common at other carriers has not helped those carriers to avoid their current financial woes.
Conversely, encouraging management and employees to think outside the box, and cultivating the idea that anything is possible has proven to work well for the more successful carriers, WN in particular.
The key? Never define the impossible. The second you label a goal as impossible to achieve, people will stop striving for it. Sure, the end goal ultimately may not be realized, but if you get halfway there, that's a gain your pessimistic philosophy would never have seen.
Personally, I would introduce a Six Sigma methodology/Kaizan competition. Every department would be eligible to participate. The department or person that, over the course of a year, streamlined their processes, demonstrated continuous improvement, and cut costs where appropriate...without adversely affecting the end product or service...would be awarded a healthy sum of money. Of course, there would be all kinds of details to sort out, but I think a 10% gain in productivity would be very workable.
Incitatus, I'm sure you'll argue that I'm dreaming, or that I have no concept of the realities of business. The fact is, I simply don't resign myself to mediocrity.
2H4
OPNLguy
Tue Feb 07, 2006 2:39 am
Quoting Continental (Reply 27):
The fact that we didn't have liveVESTS onboard. Seat-bottom cushions only get you out to 50nm max...
txagkuwait
For Q4 2005, CASM was 8.42 cents. Ex-fuel it was 6.57 cents.
For the whole year, it was 7.94 cents, ex-fuel was 6.37 cents.
Need to keep in mind, too, when comparing to the CASMs of other carriers, that is on an average stage length of 607 miles.
atrude777
Tue Feb 07, 2006 3:34 am
Cool, I will have to look out for the safety demo on my STL-FLL flight as im think the route takes us over the gulf will have to check it out.
Alex
RyGuy
Tue Feb 07, 2006 6:06 am
Quoting 2H4 (Reply 4):
In December of 2005 WestJet WS got their ETOPS in order for their flights to Hawaii from Vancouver. Very Cool, they are now permetted to fly for 3 hours over water in their Boeing 737-800 series aircraft.
Photo © Danny Fritsche - Airplanespotters
Photo © Kazim Alikhan - t.dot photography
WS is the Airline Operating the youngest fleet in the World.
RyGuy
From somewhere out there...
planespotting
Tue Feb 07, 2006 6:29 am
Quoting SPREE34 (Reply 22):
hahaha. Perhaps Pete Sessions (North Texas GOP Congressman) can add a rider onto some bill "The Sessions Amendment" prohibiting any aircraft registered to a company based at DAL from being able to fly more than one mile over water.
Do you like movies about gladiators?
2H4
Tue Feb 07, 2006 6:33 am
Quoting Planespotting (Reply 36):
Well, it would only be fair, right?  Wink
2H4
OPNLguy
Ssshh!  shhh
mtnwest1979
Tue Feb 07, 2006 6:46 am
So how does a paycut count as an increase in PRODUCTIVITY? That just cuts costs, not increase in any output.
"If it ain't broke, don't fix it!"
hoosiercfi
Tue Feb 07, 2006 8:17 am
I just flew the ISP-BWI flight last night and remembered thinking that they normally didn't do lifevests. They either didn't do it on my Friday BWI-ISP flight, or I just didn't remember it.
On a side note, does this new 162 nm rule open up the possibility to fly any Caribbean routes (not that WN will go international anytime soon)?
OPNLguy
Tue Feb 07, 2006 8:25 am
Quoting HoosierCFI (Reply 40):
Old procedures in effect on Friday. New procedures went into effect on Sunday.
luvfa
Tue Feb 07, 2006 8:31 am
Quoting OPNLguy (Reply 41):
Bear with us when we do the "new" safety demo. This is new for us too, LOL.
Cactus739
Tue Feb 07, 2006 8:40 am
For all those that hate the comedy routines on Southwest beware, they now have something new they can joke about in the safety demo....
Quoting OPNLguy (Reply 3):
When are you guys starting HNL?
ps - my 1500th post!
[Edited 2006-02-07 00:40:37]
You can't fix stupid.... - Ron White
OPNLguy
Tue Feb 07, 2006 8:41 am
Quoting Cactus739 (Reply 43):
Just as soon as you guys start running the 757s LAX-SYD...  Wink
Silver1SWA
Crew
Tue Feb 07, 2006 8:54 am
Quoting OPNLguy (Reply 6):
That would explain why I saw a F/A putting a vest on while I was provisioning a flight at SAN last night...
It looked like she was going to use it during the safety demo. Either that or she was just playing with it during her down time between flights to get ready for today. Is it a required part of the demo now? And if so, on all flights? Or just those that will be flying the offshore routes?
scxmechanic
Tue Feb 07, 2006 9:07 am
They are doing them on all flights to practice and be consistent... That's what I read in one of the publications down in our MX office...
incitatus
Tue Feb 07, 2006 10:46 am
Do I have to read past that? All these suggestions have a big hurdle to cover either with employees or customers. You might as well have suggested productivity can be enhanced by having people work for free. And the last one on call centers, if it was a significant source of savings, it would have been already done. Also the pitch wouldn't be 31 or 30. It would be 30 only.
Quoting 2H4 (Reply 31):
Unfortunately I've had a scientific education that prevents me from being swayed by pretty writing.
Too easy to see the distinction between substance and fluff.
Yes, there always is.
Go do it then. 10% productivity improvement is worth a fortune to Southwest or any company. For so much, they will pay you in airplanes instead of cash. But... what's your track record?
dagolden1
Tue Feb 07, 2006 1:11 pm
I noticed this as the flight attendant stumbled through the life vest spiel on my way to TUL from DAL today. I guess they have to give the speech every time no matter what even when they don't travel over large bodies of water. It was kind of odd.
swatpamike
Tue Feb 07, 2006 1:37 pm
Hello all
If you all don't think 162nm vs 50nm makes a difference, ask the passengers today that where on average 15 minutes early arriving in TPA today.
From a ramp point of view, its nice to have the extra time to make that turn. I hope the time gains carries through into the 6 week spring break period.
swatpamike
