FA4B6
B6 Announces January Results
Tue Feb 07, 2006 3:00 am
"Leap! And the net will appear."
lightsaber
RE: B6 Announces January Results
Tue Feb 07, 2006 4:53 am
JetBlue’s preliminary completion factor was 99.8 percent and its on-time 1 performance was 70.7 percent.
Great completion factor... B6 needs to get the on-time back up.
Does anyone know if enough of the E190 pilots have sufficient (100+ hours) experience in the airframe to eliminate some of the prior delays? How about the HUD activation?
11,196 departures in a month. Wow.
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
jetbluefan1
Tue Feb 07, 2006 4:56 am
The Jan 05 LF was very high, so I guess a 1.2% decrease isn't anything too disastrous. Their completion factor is decent but I'd really like to see them start pulling up that on-time percentage. For some reason I think we'll see the high 70s/low 80s this month. The E190s, which caused many delays in January, have started to work out their kinks.
JetBluefan1
jetblueatjfk
Tue Feb 07, 2006 6:42 am
Well the completion factor is great like normal and load factor is great too. On-time, well you know the markets they serve so there you go but as someone said above, the E190 problems contributed to a lot of that so I think it will climb up to about 80 soon enough.
Hopefully this is a start to a better year in 06.
 airplane jetBlueAtJFK airplane
