COERJ145
CO Gate Assignments At BOS
Fri Feb 10, 2006 5:13 am
Hi,
Which gates does CO use at BOS?
-Jeff Moran
9KBOS
RE: CO Gate Assignments At BOS
Fri Feb 10, 2006 5:21 am
HI COERJ145,
CO uses Gate 27, for early morning IAH flts and all CO Connect flts. For all other flight, serving EWR, CLE and other IAH's, they use 40, 41 and 42 (These gates are in the same terminal, but different TSA checkpoint.
Hope this helps.
Ryan
ScottB
Fri Feb 10, 2006 8:55 am
Quoting 9KBOS (Reply 1):
CO uses C-25 for most, if not all departures to IAH. But I think CO's gates at BOS are 25, 27, 40, 41, & 42.
Cory6188
Fri Feb 10, 2006 10:42 am
That little mini-gate area (40, 41, and 42) has to be one of the more bizarre setups I've seen in the various airports I've been to. It's randomly stuck off to the side, separate from everything else, it has one TSA checkpoint (accompanied by the 5+ obligatory screeners), and a pathetic excuse for a snack stand.
COERJ145
Fri Feb 10, 2006 2:55 pm
Quoting Cory6188 (Reply 3):
If it were connected to B37/B38(the old HP area), It would make more sense by adding restrooms to the B area, and would gain 2 gates for C.
