aircanada014
What Makes DL And Atlanta So Big In Pax #?
Sat Feb 11, 2006 9:27 am
Hello all
I was just wondering what makes Delta Airlines and Atlanta Harts Field so big in passenger volume? bigger than UA and ORD and AA and DFW. But then DL is not in the greatest conditions right now regarding bankruptcy protections, pilots might go on strike. What is the secret to get so much volume of pax on plane and at the airport.
srbmod
RE: What Makes DL And Atlanta So Big In Pax #?
Sat Feb 11, 2006 9:50 am
Location Location Location...........
ATL sits in a very good area geographically and has also been an important transportation hub since before the Civil War. The airport has been one of the busiest in the US since the late 1930s.
Delta grew in Atlanta due to the collapse of Eastern in 1991. Prior to that, both airlines were of similar size and had around the same marketshare. DL grew very fast @ ATL during the next 5 years and most attempts by other airlines to establish any sort of hub operations @ ATL were met by failure (TWA, Air South, Kiwi International, Private Jet). When Eastern folded, a third of their gates were taken over by Delta, eventually two-thirds when you throw in ASA's takeover of part of C.
DLPMMM
Sat Feb 11, 2006 9:57 am
For your information, it is Hartsfield/Jackson International Airport... Not Harts Field.
To answer your question, Geography!!
Atlanta is hub geographically well situated to connect the notheast and the southeast. The 2 biggest air travel markets in the USA.
I it also well positioned to serve the southeast to most all points west.
Atlanta Hartsfield/Jackson International Airport is also probably the most logically efficient airport ever designed in terms of layout for a hub and spoke type airport.
aircanada014
Sat Feb 11, 2006 10:01 am
Quoting DLPMMM (Reply 2):
Oops your right sorry about that. I couldn't remember exactly. Yeah I guess the geographically is very good. Who is the 2nd largest airline in terms of passenger volume carried?
dalb777
Sat Feb 11, 2006 10:07 am
Quoting AirCanada014 (Reply 3):
In ATL? Probably AirTran.
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
kkfla737
Sat Feb 11, 2006 10:08 am
Quoting Srbmod (Reply 1):
I think Delta finally caught up with EA at ATL around 1987 or so, but prior to that I am almost positive EA had a slightly larger marketshare even though Delta was the hometown airline and EA was based in Miami, where it operated a smaller hub.
It's interesting that when Frank Lorenzo drove EA into bankrupcy, some of his leadership at Texas Air felt EA should dump the Atlanta hub and focus on north-south flying and int'l routes. Lorenzo rejected that suggestion, instead selling off the Miami hub, Latin American operation, and most of the slots EA owned at LGA, DCA and ORD. Lorenzo was convinced EA could fight a one front war against DL with a lower (non-union) cost structure at ATL and win.
But the point is Atlanta's location meant that it was the ideal hub and that EA was willing to dump the rest of the airline to stay in Atlanta, something that may end up happening to DL sooner or later if things don't change. (DL's current JFK operation is somewhat similar to EA's Miami hub which was largely based around int'l traffic.)
Alitalia744
Sat Feb 11, 2006 12:33 pm
If you're goin to nitpick on proper name/spelling, than PLEASE nitpick the below first for god sakes...
Quoting AirCanada014 (Thread starter):
Delta Airlines
it's Delta Air Lines.
Some see lines, others see between the lines.
ckfred
Sat Feb 11, 2006 2:16 pm
There is a saying that whether you're going to heaven or hell, you have to change planes in Atlanta.
Although there are people who credit Bob Crandall of AA with creating the hub-and-spoke system, it was really Delta.
Back in the 1970s, Delta had their first arrivals in Atlanta from small cities across the Southest timed that so a passenger could be at any Delta city east of the Mississippi for a late breakfast meeing, and any city in the entire system for lunch.
Thus, someone leaving Athens, GA at 6 am could be in downtown Chicago by 9:30 am or downtown San Francisco by 11:15 am.
One other thing to remember is that Delta kept flying widebodies on domestic routes out of ATL long after the other major carriers put their widebodies on trans-con and international flights.
In the late 90s, DL was still flying L-1011s and 767s between ORD and ATL.
SESGDL
Sat Feb 11, 2006 4:04 pm
Quoting Kkfla737 (Reply 5):
Nope. DL has always been the largest airline in ATL. In 1983, when the new terminal was built (I believe), DL had 335 daily departures to EA's 240; at this time DL's hub at ATL was already the single largest airline hub in the world. After the demise of EA, DL grew even further and built the hub substantially.
Jeremy
DAL767400ER
Sun Feb 12, 2006 4:53 am
Another thing to factor in when looking at its size is the whole airport layout:
2 sets of parallel runways, allowing 4 parallel movements, with the whole terminal complex in between, with easily the most simple terminal/concourse layout of all large airports out there (though people still manage to get lost there  Yeah sure ).
OttoPylit
Sun Feb 12, 2006 5:10 am
For your information, it should be Atlanta Hartsfield International Airport. If your from ATL, you would know how the mayor went beyond her abilities to force Jackson's name onto the airport, against the wishes of the airport and the airport committee that SHE formed to solve the dispute. Not to mention the fact that she dishonored Mayor Hartsfield's legacy in the city and at the airport that he basically created from scratch just so appease Jackson's widow. And they say Atlanta is too busy to hate. Ha!!!
But other than that:
Your right on the money!
Quoting Ckfred (Reply 7):
Actually, didn't Delta start the hub-and-spoke system in the late 50's? I could be wrong on that, but I'm almost sure it was earlier than the 70's.
Another thing which makes Delta so large is their successful use of widebodies. They can use widebodies on many routes that other airlines cannot. And fill them up, not just to MCO either. Delta is a Southern airline with a large Southern following, so if your from the Southeast, at least 1 out of every 3 will choose Delta from loyalty, just as the people of the midwest would choose UA or NW and just as the people of the great state of Texas choose AA.
OttoPylit
I don't have a microwave, but I do have a clock that occasionally cooks shit.
kkfla737
Sun Feb 12, 2006 5:49 am
Quoting OttoPylit (Reply 10):
Exactly. That's why when I was in India and was explaining to the folks there why I think the Indian aviation boom will turn into a bust, because all the airlines are focusing on the same routes and markets, I cited that traditionally in the US while we have national carriers, each carrier had a strong region. In fact AA was more of a Northeastern and Midwestern carrier large at Chicago and New York prior to invanding Dallas in the 1970s, Delta has always been strong in the south and after 1972 in the NE as well, and Northwest has always been more or less a strong carrier in upper midwest and across the pacific. Eastern was the largest airline in the free world in the early 1980s but was yet a purely regional carrier, something that contributed to its ultimate downfall. Delta will always have a market base because of the loyalty of Southern passengers. period.
lightsaber
Crew
Sun Feb 12, 2006 6:17 am
Best note of the whole thread.
Note that most of the big hubs are located near early railroad hubs or historical major ports.  Smile There are very few exceptions, but not many.
Lightsaber
MD-90
Sun Feb 12, 2006 7:18 am
Also because it's the most convenient.
And while ATL is efficiently laid out, would it have killed them to add a few more windows to the terminals?
And Atlanta historically was the Chicago of the east, where several important railroad lines converged. That's the biggest reason why Atlanta was expressly targeted by the North in the Civil War.
atmx2000
Sun Feb 12, 2006 10:59 am
Quoting MD-90 (Reply 13):
Also there are no other cities as large as Atlanta anywhere nearby in all directions, making it a natural center of commercial activity in the Southeastern US and a logical location for hub operations.
soundsfishy
Sun Feb 12, 2006 12:22 pm
You could make an argument that PIT (in its heydey, not the hallowed shell that remains today) is probably more efficient. No silly trains (except for O&D), quick transfers and short walks, and great shopping. Despite a snowy location, US used to have very smooth ops through PIT.
If I recall, PIT and MCO regularly got rated the best airports in the country, but of course MCO is almost all O&D.
srbmod
Sun Feb 12, 2006 12:29 pm
You have to remember the airport was designed in the 1970s, so things were designed along lines of the typical 70s industrial design. Simplicity rules the design, and also allowed easier redesigns of the interior spaces (adding/removing gates, waiting areas, retail spaces, offices) to best suit the concourse. This is why there is not a lot of windows in many areas.
OldAeroGuy
Sun Feb 12, 2006 1:27 pm
As we Southerners of a certain age say, "When you die, it doesn't matter if you're going to Heaven or Hell, you still have to change planes in Atlanta".
NW305
Sun Feb 12, 2006 5:32 pm
Here are the routes from Atlanta for Delta and Eastern in 1977, the last year before the deregulation act of 1978
DELTA AND EASTERN ATLANTA SERVICE JUNE 1977
DELTA (SERVICE TO 46 AIRPORTS)
AUGUSTA,GA 8
BALTIMORE,MD 6
BATON ROUGE,LA 3
BIRMINGHAM,AL 8
BOSTON,MA 5
CHARLESTON,SC 5
CHARLOTTE,NC 7
CHATTANOOGA,TN 8
CHICAGO,IL 7
CINCINNATI,OH 7
COLUMBIA,SC 8
COLUMBUS,GA 6
COLUMBUS,OH 4
DALLAS/FTWORTH,TX 9
DAYTON,OH 6
DETROIT,MI 4
FT LAUDERDALE,FL 7
HOUSTON,TX 6
INDIANAPOLIS,IN 4
JACKSON,MS 4
JACKSONVILLE,FL 7
KANSAS CITY,MO 3
KNOXVILLE,TN 6
LAS VEGAS,NV 1
LEXINGTON,KY 3
LOS ANGELES,CA 4
LOUISVILLE,KY 6
MACON,GA 4
MEMPHIS,TN 7
MERIDIAN,MS 1
MIAMI,FL 7
MONROE,LA 1
MONTGOMERY,AL 8
NEW ORLEANS,LA 8
NEWARK,NJ 4
KENNEDY IAP,NY 3
LA GUARDIA, NY 6
ORLANDO,FL 7
PHILADELPHIA,PA 7
SAN DIEGO,CA 1
SAN FRANCISCO, CA 4
SAVANNAH,GA 7
SHREVEPORT,LA 2
TAMPA,FL 8
WASH/NATIONAL 8
WEST PALM BEACH,FL 5
EASTERN (SERIVCE TO 54 AIRPORTS)
BALTIMORE,MD 6
BIRMINGHAM,AL 6
BOSTON,MA 5
BUFFALO,NY 3
CHARLOTTE,NC 8
CHATTANOOGA,TN 1
CHICAGO,IL 8
COLUMBUS,GA 4
CORPUS CHRISTI,TX 1
DALLAS/FTWORTH,TX 6
DAYTONA BEACH,FL 6
EVANSVILLE,IN 1
FT LAUDERDALE,FL 5
FT MEYERS,FL 6
GAINESVILLE,FL 4
GREENSBORO,NC 6
GREENVILLE/SPARTANBURG,SC 6
HARTFORD,CT 4
HOUSTON,TX 7
INDIANAPOLIS,IN 5
JACKSONVILLE,FL 8
LOS ANGELES,CA 3
LOUSIVILLE,KY 4
MACON,GA 3
MELBOURNE,FL 4
MEMPHIS,TN 5
MEXICO CITY, MEXICO 2
MIAMI, FL 7
MILWAUKEE,WS 3
MINNEAPOLIS,MN 4
MOBILE, AL 4
MONTEGO BAY, JAMAICA 1
MONTGOMERY,AL 5
NASHVILLE,TN 6
NEW ORLEANS,LA 5
NEWARK,NJ 3
LA GUARDIA,NY 5
KENNEDY, NY 3
ORLANDO,FL 7
PENSACOLA,FL 5
PHILADELPHIA,PA 8
PITTSBURGH,PA 5
PROVIDENCE,RI 2
RALIEGH/DURHAM,NC 8
RICHMOND,VA 5
ST.LOUIS,MO 7
SAN ANTONIO,TX 4
SAN JUAN, PUERTO RICO 2
SARASOTA,FL 6
SYRACUSE,NY 3
TALLAHASSEE,FL 5
TAMPA,FL 7
WASH/NATIONAL 5
Jumpseat70
Sun Feb 12, 2006 10:03 pm
Having CNN and Coke in Atlanta doesn't hurt either, along with a few thousand other large corporate accounts that Delta controls.
"Up, Up and away with TWA"
N1120A
Sun Feb 12, 2006 10:17 pm
Um, I think the California Corridor would like to have a word with you
Actually, New Orleans holds at least as much railroad importance as Atlanta
srbmod
Sun Feb 12, 2006 10:47 pm
Quoting N1120A (Reply 20):
Atlanta also had important manufacturing facilities for the Confederate Army during the Civil War, which was also one of the reasons why it was targeted. New Orleans was and still is an important port city (The only city that more coffee beans and tea leaves come through is New York City), but the railroad has not played as much of a role like it has in Atlanta. New Orleans has relied on boats more than anything. The Mississippi River is why New Orleans is where it is. The fact that via the Mississippi River and it's tributaries, a large number of cities can be accessed. The railroads helped with the transit of goods out of New Orleans, but where did most of those trains end up at? Atlanta.
