Ruscoe
How Wide 737/320 Replacement?
Wed Feb 22, 2006 6:27 am
I have been thinking about what fuselage width A&B will go for with the 733/320 replacement craft.
B have stated just about every possibility and now saying could have 3 different fuselage widths. I think this is unlikely.
My first guess is that the next generation "narrow body" will be about 20" wider than the current 737.
This would allow the option of either single or twin ailse.In twin aise mode seats would be roughly the same as to-day but with 2 ailes and 2x2x2.
In single ailse mode the carrier could either have wider seats or a wider ailse. I think most would go for a slightly wider seat and a much wider ailse to make boarding and deboarding easier.
Second guess is that the fuselage width will stay approx same as at present, to keep weight down.
Any thoughts?
Ruscoe
redflyer
RE: How Wide 737/320 Replacement?
Wed Feb 22, 2006 6:47 am
I think Boeing is more likely than Airbus to change the barrel diameter of their fuselage, even if they stay with a single aisle concept. The 320 is pretty successful - and, for that matter, more comfortable - as is. Boeing has to revamp their 737 fuse. It is, after all, based on a 40+ year old design.
My other home is in the sky inside my Piper Cherokee 180.
Oykie
Wed Feb 22, 2006 2:55 pm
"We could do three different fuselages. Five abreast; six abreast; we could even do a twin-aisle," Mulally said. "We're looking at all those opportunities."
According to Mulally they could do 3 different fuselage width.
I wish that this means they could offer more than just one fuselage width, although no one has agreed to this yet.
http://seattletimes.nwsource.com/htm...aerospace/2002803880_boeing14.html
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
flydreamliner
Wed Feb 22, 2006 3:08 pm
Airbus doesn't like to change anything that works. Of the aircraft numbered A300 to A350, only one doesn't share the same fuselage.
I would expect their already nice and wide A320 fuselage to continue.
As a result, Boeing, I'm sure, will make one wider, maybe even by a foot. So long as they are changing it, they might as well make it worthwhile, right?
"Let the world change you, and you can change the world"
zvezda
Wed Feb 22, 2006 3:22 pm
Boeing need to cover the market space up to the B787-8. That rules out a 5 abreast size. Given the need for 6 abreast seating and any given cabin width, one aisle is more efficient for embarkation/disembarkation than two aisles. One wide aisle will rarely be blocked. Two narrow aisles will frequently be blocked.
The B787's composite fuselage technology obviates the most of the weakness in a non-circular fuselage cross-section. Boeing can easily make Y1's fuselage greater in height than width. This would allow it to accomodate LD3 containers single-file.
Oykie
Thu Feb 23, 2006 1:55 am
Quoting Zvezda (Reply 5):
In my opinion Boeing could do 2 fuselage width. Just like the 757 and 767 just much more commonality. That way they are optimising the 75-250 seat range.
This would allow it to accommodate LD3 containers single-file.
That would be of a huge advantage.
