BosCollJetBlue
BOS - SLC: What Plane Does DL Fly?
Sat Feb 25, 2006 3:21 am
Quick question: What plane does delta fly between BOS and SLC and then SLC to SFO?
Thanks for the reply in advance.
OOer
RE: BOS - SLC: What Plane Does DL Fly?
Sat Feb 25, 2006 3:25 am
Depending on the season BOS-SLC will be either a 752 or a 738. Depending on the time of day SLC-SFO will be either a DLC RJ or a 733/8 or MD90.
litz
Sat Feb 25, 2006 4:36 am
Quoting OOer (Reply 1):
on the SLC-SFO leg, you can delete the 733's, as soon as DL finishes retiring the 732s and 733s ... My guess is it would standardize on a 738, RJ, or MD90 at that point ...
Would the RJ, in this case, be one of the new ERJs or a CRJ ?
(isn't SLC a Skywest hub, hence more likely a CRJ ?)
- litz
ScottB
Sat Feb 25, 2006 4:37 am
Quoting Boscolljetblue (Thread starter):
And if you really want the answer quickly, checking the schedule on delta.com is probably a lot faster (and fewer keystrokes) than asking here.
WidgetBoi
Sat Feb 25, 2006 5:21 am
Quoting Litz (Reply 2):
Skywest CRJs.
