JoeCattoli
Still No Winglets For 777s
Mon Feb 27, 2006 9:19 am
Hi A-netters, I checked in the past threads about the viability of winglets on the 777. There is something but not a proper answer to what I'm gonna ask.
Since I've heard that winglets are always saving-fuel especially on long-haul (and I don't wanna teach to anyone that 777s are actually long-haul airplanes) why there's not even one model that offers this improvement?
Is Boeing waiting on the next move of Airbus to propose than a winglet that keeps the T7s life longer? (or... since the T7 program has no problem in orders I should say even healthier...).
Or the reason is is simply that the winglet doesn't improve significantly the characteristics of the larger twin-jet on earth?
Thanks in advance
Ciao
Joe
DfwRevolution
RE: Still No Winglets For 777s
Mon Feb 27, 2006 9:25 am
Quoting JoeCattoli (Thread starter):
Aviation Partners, the manufacture of the 737NG and 757 winglets, are considering a winglet retrofit for the non-LR 777 variants. They are currently running performance and economic projections before offering the product for sale.
Boeing will not likely get involved with winglet production for the 777 series, it will be an aftermarket product.
Winglets are typically used as a "band-aide" to add performance to a wing, a properly optimized wing does not need winglets.
When building the 777, Boeing considered winglets. They discovered, however, that increasing span 5/4 the hight of the winglet produces the exact same aerodynamic result with less structural weight. Remember that vertical winglets requires substantial wing reinforcement while a minor span increase does not.
There are few aircraft designed with winglets in mind. If they are, it is because increasing span would yield logistic complications like hampering gate clearance: A388, 744, 783, E170/E190, etc. Nearly all other aircraft recieved winglets midway through design or on the aftermarket to boost performance: MD11, 737NG, etc. The A340 only recieved winglets when it was discovered the CFM56 would not yield the performance of the IAE Superfan.
http://airtransportbiz.free.fr/Technique/Thewinglet.html
N160LH
Mon Feb 27, 2006 9:58 am
I wonder why we have not seen more aircraft's getting motified with the racked wingtips like the 767-400's....?
N160LH
"I do alright up in the air, its down on the ground that I tend to mess up..."
kaitak744
Mon Feb 27, 2006 10:27 am
But, Boeing's philosophy is that for short haul flights, blended winglets. For long haul, raked wingtips. So, if anything, older 777s would be refitted with raked wingtips.
lehpron
Mon Feb 27, 2006 10:30 am
Quoting N160LH (Reply 2):
Your question was answer in the previous post:
Quoting DfwRevolution (Reply 1):
Essentially, raked wingtip devices are better at taking load off of the wing, but they increase span.
levg79
Mon Feb 27, 2006 10:33 am
I remember reading that B777's wing is efficient as it is, therefore the winglets are not required. Don't forget that winglets weight a lot so there are soome disadvantages involved, especially on short and medium haul flights. An example of this would be B744D. Remember that when Boeing designed the 777, winglets were already widely used therefore they must have been considered (I'm not a Boeing engineer, just a guess). And I've never heard anyone complain about the 777's performance, so I guess there's no need to work on its efficiency.
Leo.
A mile of runway takes you to the world. A mile of highway takes you a mile.
AvObserver
Mon Feb 27, 2006 10:35 am
The raked wingtips on the -300ER and -200LR perform the same function as winglets and Boeing jusged them to be more effective the 777's aft-loaded wing. No doubt that many older 777's will eventually be retrofitted with these.
Mudboy
Mon Feb 27, 2006 11:31 am
What would happen if one of the winglets broke off in flight?
cloudyapple
Mon Feb 27, 2006 8:44 pm
Given you stay within a box of 65m span for a Code E aircraft it's more efficient to stick with a simple span extension. That's why the span went up from 60.9m on the B772 to 64.8 on the B772LR. That's very close the maximum you can fit on a Code E stand. Airport compatibility is a huge issue if you go any wider.
Interesting fact that the B748 is going outside the 65m span box at 68.4m. It's a "narrow" Code F aircraft which means it can park at a Code E stand with restriction on the span of neighbouring aircraft (up to 61.6m span - B772/B773 "classics", B789/A333/A343/A358) if both centrelines offset to 1 side.
[Edited 2006-02-27 12:46:20]
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
JoeCattoli
Mon Feb 27, 2006 10:16 pm
I didn't know about raked wingtips and adding wingspan to avoid the extra weight of a winglet. Thanks
It's a pity that we will almost surely never see one of those marvellous T7s with winglets... It should be quite impressive.
Ciao
Joe
levg79
Tue Feb 28, 2006 12:37 am
Quoting JoeCattoli (Reply 9):
It would look something like this:
Modified Airliner Photos:
Design © Joe Perez
Template © Pete Bennett
Leo.
viv
Tue Feb 28, 2006 12:39 am
Not always.
STARalliance24
Tue Feb 28, 2006 12:40 am
Quoting Levg79 (Reply 10):
SWEET! The T7 looks awesome with winglets!
Quoting Mudboy (Reply 7):
All aircraft with winglets are certified to fly without one on a wing. Like the B747 and A340.
Glom
Tue Feb 28, 2006 1:11 am
I'm not so keen. They work sometimes, like on the A340, but I think the 777 looks better with raked wingtips.
DfwRevolution
Tue Feb 28, 2006 1:18 am
Quoting Viv (Reply 11):
Not always.
Maybe on a positioning flight under 30 minutes, but most winglet packages break-even in under an hour of flight time.
The benefit of winglets is more dramatic as the flight goes on, but the effects of winglets are felt even on the take-off roll.
