UN_B732
What Does "V" Mean In A Check-in Systems Seating?
Sun Mar 05, 2006 5:41 pm
Hi:
I'm here in Kiev, getting ready for an AeroSvit flight. I asked for a bulkhead, and she said nothing was available, the best she could do was middle seats in 24.
Lots of seats were green and showed "V". She said that means reserved. How does "V" mean reserved? I'm not doubting her, I just think that "R" would be more appropriate.
-Mr. X
What now?
HS748
RE: What Does "V" Mean In A Check-in Systems Seating?
Sun Mar 05, 2006 6:38 pm
Why would you assume that English was the language being used in a check-in system in Kiev? Perhaps the local language is used and perhaps the local word for 'reserved' starts with the letter v. There is life outside the English speaking world you know!
[Edited 2006-03-05 10:39:17]
spencer
Sun Mar 05, 2006 6:46 pm
If the seats (on the diagram) were green and showed a "V" then surely that meant they were vacant?
Spencer.
7LBAC111
Sun Mar 05, 2006 6:57 pm
You are all assuming a letter is used to represent seat availability.
In some cases (in Sabre) vacant seats are marked with a ' * ' or a ' . ' and sometimes with just the seat letter.
7L
Debate is what you put on de hook when you want to catch de fish.
captaink
In some ACS, V is one of codes used for airport blocked seats, meaning that that they can be released only during checkin. What may have been the case with the checkin agent, is that she didnt have the authority to release the seats (her agent sine was not high enough). She could have checked with a supervisor to do it though.
I can't say for sure that this was the case in this ACS.
There is something special about planes....
lamedianaranja
Sun Mar 05, 2006 7:20 pm
V might mean Last Vacant (at least it does in the system I use) and are the seats that have to be given out only if the aircraft fills up completely. FR's variant of the red/white tape  Wink It maybe seats that do not recline or that the crew uses to rest if possible or even have to do with the weight & Balance of the a/c.
I wish that all skies were orange and blue!!
DavidT
Sun Mar 05, 2006 8:00 pm
Quoting UN_B732 (Thread starter):
Given you're in the Ukraine, I'm pretty sure that the letter is from a foreign language- probably Russian - perhaps even in the cyrillic alphabet.
UN_B732
Tue Mar 07, 2006 4:17 am
V could not mean occupied in Russian (perhaps in Ukrainian, but I can't construe it in Russian) and it was a latin V (nothing similar used in Russian)
"Airport Blocked" could make sense, but this was most of the economy cabin. It's an interesting system, whatever they use.
-Mr. X
The reason I ask this all is because I was Seq #80 (out of ~ 200 coach seats in their configuration), and there was nothing available beyond row 26 (barring two middle seats in row 24) (which makes sense, but there were two empty seats in row 11 when we left -- which arguably, could have been no shows, and perhaps there really was nothing available in front of row 26.. not calling anyone a liar)
[Edited 2006-03-06 20:18:16]
[Edited 2006-03-06 20:21:54]
[Edited 2006-03-06 20:22:56]
[Edited 2006-03-06 20:23:34]
What now?
asqx
Tue Mar 07, 2006 4:39 am
V, Q, R, Z, U, L, B, I, X and H are just a few of the seat types I have seen in various reservations systems. Genearally they go something like this (although there is some variation with different systems):
V - Pre-Reserved, Frequent Flyer Program Member (Usually Elites)
Q - Prefered for Frequent Flyer Program Members (Usually Elites)
R - Pre-Reserved, General Passenger
Z - Airport Assign Only
U - Undesireable (Such as non-reclining)
L - Prefered for Unaccomanied Minor
B - Blocked
I - Infant Block (usually a lap infant sitting in an adjoining seat)
X - Inoperable
H - Prefered Seating for Disabled or Special Needs Passengeres
UN_B732
Tue Mar 07, 2006 4:44 am
THAT makes sense. (Pre-reserved w FFP)
The only thing I won't know, is why it was V.
What now?
asqx
Tue Mar 07, 2006 4:56 am
Quoting UN_B732 (Reply 9):
Since "R" is used for Reserved for General Passenger, "V" could stand for Reserved for VIP Passenger, but that's only a best guess.
DeC
Tue Mar 07, 2006 5:01 am
That's the thing Asqx, thanks a lot!
DEC
ramerinianair
Tue Mar 07, 2006 5:21 am
V means you've been Medallion upgraded!!! That's a fare thing though, not a seat thing.
SR
W N = my Worst Nightmare!!!!!
AirScoot
Tue Mar 07, 2006 5:25 am
The VV seat map looks like Amadeus. I pulled a map for today.. and there was a key at the bottom...
A B C D E F G
. AVAILABLE WW WING F GEN FACI K GALLEY E EXIT C CO
‡ OCCUPIED - LAST OFF H HANDICAP Q QUIET G GROUPS P PE
/ RESTRICTED B BULKHEAD V PREF.SEAT X BLOCKED L TOILET U UM
SS SMOKING D DEPORTEE UP UP-DECK Z NO FILM I INFANT R RE
Looks like V is for Preferred Seating (elite).
PA110
Tue Mar 07, 2006 5:28 am
Asqx spelled it out pretty well, but sounds like there is still a little confusion.
  • Don't look for any correlation between the code used and its meaning. They are often arbitrary.
  • The codes used are often unique to the airline and/or system used.
  • It's been swell, but the swelling has gone down.
    asqx
    Tue Mar 07, 2006 5:44 am
    Every system is different, although I have found that after three versions of Sabre, Shares, and OpenSkies, that they are generally close to each other, although OpenSkies was the simplest, having R (reservered), I (lap infant), E (exit row), B (blocked), - (open) and * (occupied) as the only options, at least in the version I used.
    captaink
    Tue Mar 07, 2006 7:30 am
    Quoting Asqx (Reply 8):
    B - Blocked
    X - Inoperable
    I think this is pretty much the answer here, no need for guessing. This is def. the case with Sabre.
