AlitaliaMD11
First A330-200 For Air Europa Painted!
Thu Mar 09, 2006 12:23 am
Here is the first picture of the first Air Europa A330-200!
http://www.skyliner-aviation.de/photos/01ecjpf.jpg
Looks stunning!
No Vueling No Party
767-332ER
RE: First A330-200 For Air Europa Painted!
Thu Mar 09, 2006 1:01 am
Interesting...their colors look good on just about anything.
So what does their fleet plan look like?
Boeing 737-800s to stay, considering they've just placed an order for 15 or so recently, correct?
How about their long-haul?
A340 to stay?
A330-200 to replace 767-300s or to supplement them?
Anyone have any info on this great carrier?
Twinjets...if one fails, work the other one twice as hard!!!
egnr
Thu Mar 09, 2006 1:12 am
Quoting 767-332ER (Reply 1):
A340 to stay?
The shorthaul fleet will be built around the B737NG family, mainly the 737-800. The longhaul fleet will consist of 4 leased A330-200s, and a leased A340-200, until the A350s start to arrive from 2010.
AEA firmed up an order for 10 A350-800 + 2 options on Jan 25th - Airbus press release
7late7, A3latey, Sukhoi Superlate... what's going on?
solnabo
Is this 332 fresh from TLS factory, or leased?
Looks great!
Micke//SWE Big grin
Airbus SAS - Love them both
gkirk
Thu Mar 09, 2006 1:13 am
Quoting Solnabo (Reply 3):
Judging by the reg, I'd say it's brand new
767-332ER
Thu Mar 09, 2006 1:16 am
Quoting EGNR (Reply 2):
Geez...I can't believe I had forgotten that they were the first customer to place the letter of intent and subsequently I suppose the first customer for the A350. Thanks for refreshing my mind!!
RAFVC10
Thu Mar 09, 2006 4:25 am
Which routes will the 332 fly??
El dia que los gilipollas vuelen, no podremos ver la luz del sol!
IberiaA319
Thu Mar 09, 2006 4:32 am
It's the first widebody operated by a Spanish Airline that will have PTV's in Economy!!  Big grin  Big grin Congratulations, Air Europa!!
Saw some pictures of the cabin in the International Tourism Fair in Madrid, looks really nice!!
Magyarorszag
Thu Mar 09, 2006 4:40 am
Right above the rego, there's a number. Seems to be 733. Most of the time with factory fresh Airbuses, this number is the C/N. According to airlinerlist, C/N 733 is an A330-203 intended for... UX, and its testreg is F-WWKU as in the picture.
CHeers.
M.
AlitaliaMD11
Thu Mar 09, 2006 5:11 am
Quoting IberiaA319 (Reply 7):
I was going to ask if there was any improvments in the cabin. I guess there will be!
Hopefully the PTV's will put some pressure on Iberia to upgrade their economy class!
No Vueling No Party
krisyyz
Thu Mar 09, 2006 5:27 am
It looks okay, pure euro white paint scheme.
Are those GE CF6-8E's or PW 4000s ?
KrisYYZ
raggi
Thu Mar 09, 2006 5:34 am
Quoting KrisYYZ (Reply 10):
GE CF6
raggi
Stick & Rudder
egnr
Thu Mar 09, 2006 5:44 am
This A330-203 has GE engines. The '0' in the -203 part of the aircraft model indicates GE engines. A '2' (e.g. A330-222 or A330-223) would indicate PW.
The GE engines have the long, very pointed cones at the rear (see the Qatar A330 below), the PWs have shorter, less pointed visible cones (see the LTU A330 below).
Photo © Robert Budde
Photo © Jid Webb
[Edited 2006-03-08 21:45:09]
krisyyz
Thu Mar 09, 2006 6:03 am
Quoting EGNR (Reply 12):
This A330-203 has GE engines. The '0' in the -203 part of the aircraft model indicates GE engines. A '2' (e.e. A330-222 or A330-223) would indicate PW.
A little off topic, so a RR powered would be A330-242?
A330-2(0)2 -GE
A330-2(2)2-PW
A330-2(4)2-RR
and the last digit is the airline ?
Boeing has airline codes correct? like most B767-333, 375 are -300s for AC
KrisYYZ
A342
Thu Mar 09, 2006 6:34 am
Quoting KrisYYZ (Reply 13):
No, the MTOW version. 3 stands for 233 tons, 2 and 1 for less.
Exceptions confirm the rule.
raggi
Thu Mar 09, 2006 6:45 am
A330-2(0)2 -GE
A330-2(2)2-PW
A330-2(4)2-RR
Yes, that is almost correct. Take for instance a QR A330.
A330-302. The 3 is the fuselage-variant (300), the 2 is the engine (GE), and the last is the weight, or submodel. Generally the higher the last number, the higher the gross weight.
Airbus don't have customer codes. An A340-600 made for LH, and a A340-600 made for VS are both called A340-642s. The HGW-600 will be called the -643 if I'm not mistaken.
AC's Boeing-code is 33, so their new 777s will be 777-333ERs and 233LRs. The 767-375 are ex-Canadian ones.
raggi
Stick & Rudder
egnr
Thu Mar 09, 2006 7:03 am
A330-2(0)2 -GE
A330-2(2)2-PW
A330-2(4)2-RR
Airbus model numbers are decyphered as follows...
A3XX-ABC
Obviously, A3XX is the model - e.g. A320, A330, A340, A380, etc.
'A' denotes the series of that model - e.g. A340-200, A340-300, A340-500, A340-600, etc.
'B' denotes the engine manufacturer:
'0' = General Electric,
'1' = cfm International,
'2' = Pratt & Whitney,
'3' = International Aero Engines,
'4' = Rolls Royce,
'6' = Engine Alliance
'C' denotes the variant of that engine, and or the takeoff weight (usually linked to the engine option).
Examples:
A320-111 - an A320-100 fitted with the first variant of the cfm powerplant made available on the A320.
A300-605 - an A300-600 fitted with the fifth variant of the General Electric powerplant made available on the A300.
A330-342 - an A330-300 fitted with the second variant of the Rolls Royce powerplant available on the A330 model line up.
Note: ('5' is not used - not sure why, maybe the joint venture for the engines on A400M was assigned the '5'?).
'C' denotes the variant of that engine, e.g. on the A340-500 and A340-600. Both use the Rolls Royce Trent 500, but the A340-600 uses a different variant (different thrust output), so we have A340-541 and A340-642.
MyTravel, Thomas Cook and Monarch all fly A330-243s with high seating capacity for IT charter work. Emirates, bmi, Etihad also fly A330-243s but with far fewer seats.
Airbus's numbering system is more like that of a car manufacturer - everybody has the same model designation (badge on the trunk), but picks their own options (configures their own interior - seat numbers, etc.).
Whereas Boeing give each customer models with their own unique numbers, e.g '7X7-X36' for British Airways, '7X7-X38' for Qantas, '7X7-XH4' for Southwest.
IBERIA747
Thu Mar 09, 2006 7:10 am
Wow it looks stunning!!.
It seems that Air Europa is set to become a great Spanish international airline in the future.
Yup...they were great, but they were not showing Air Europa's cabin design but a generic Airbus' cabin mock up.
Anyway, after seeing those nice leather seats Air Europa has installed on the newer 737-800s I can imagine that the cabins on those A330s will be awesome.
It's great to see a Spanish airline growing like this.
Quoting AlitaliaMD11 (Reply 9):
Hopefully indeed, but I bet it won't happen. Not at least under IB's current management...sad but true.
In fact, IFE has been completely cancelled on short/medium flights and even the safety instructions are not shown on the screens anymore but performed manually by the cabin crew members. The new A319s/320s/321s that will soon join the fleet won't have LCD screens installed below the overhead bins.
This said, the A340s will be the only aircraft in Iberia's fleet featuring video screens...but those will be just the normal screens hanging from the central overhead compartments or installed on the bulkheads as happens now.
¡¡VIVA ESPAÑA!!
md90fan
Thu Mar 09, 2006 8:33 am
Good to see that Air Europa isnt going completely Airbus and finally A330's are there now.
http://www.devanwells.blogspot.com/
JBOND
Thu Mar 09, 2006 9:03 am
Now on A.Net
http://www.airliners.net/open.file/1013923/L/
A332 for AEA s/n :
733 EC-JPF ILFC
745 EC-JQG GECAS
749 GECAS
814 ILFC
YANN/FFAS
A388
Thu Mar 09, 2006 1:19 pm
Wow, nice. I just love the A330-200, it's the most elegant aircraft I've seen so far. After the A330-200 my favourite goes to the 777!
Anyway, to get back on topic. Which routes will the A330-200 be flying for UX? Will it fly to the Caribbean too? I hope they will go to CUR in the future. We need more airlines at our airport!!! Just kidding, it's just wishful thinking I guess... I don't know how popular CUR is in Spain, but I don't thoml we are that well known in Spain even though CUR has a Spanish background and very well connections to South American neighbouring countries such as Venezuela and Colombia
[Edited 2006-03-09 05:22:30]
AlitaliaMD11
Thu Mar 09, 2006 1:26 pm
Quoting A388 (Reply 20):
I am guessing that the A330-200 will fly the routes that the 767-300 flew in the past. I bet when EC-JPF is delivered it will start flying first on routes to the Canary Islands and maybe a few Puente Aeros from MAD to BCN to get the crew familiar with the aircraft type.
I am sure that the A330-200 will fly to the Caribbean.
No Vueling No Party
LTU932
Thu Mar 09, 2006 5:12 pm
Quoting Raggi (Reply 15):
Would be logical, but last thing I heard, the HGW is going to be designated A340-642X, not -643X.
That aircraft looks pretty cool, despite the Eurowhite. Though I wish they would have rather opted for Trents instead of the CF6-80E1, but then again, since they operate CFMs on the 737NGs and A340s, going GE makes sense.
Owleye
Thu Mar 09, 2006 8:11 pm
Air Europa has one of the poorest liveries. Cheap red, cheap blue, white combination with a lack of imagination nor creativity...and a poor, unreadable logo (to me it's more 'oe' than 'ae'). The text 'Europe' is too high positioned on the tail fin. Pitty!
anxebla
Fri Mar 10, 2006 9:55 am
UX on a medium-term will have single-aisle aircraft from Boeing and an Airbus' long-haul fleet.
A340 to stay?
No. The current 340-200 has its days numbered on Air Europa metal.
Anyhow, last rumor inside UX tells A342 could continue on in order to serve PEK and to be flown by pilots as a post-training after simulator and prior to a definitive incorporation to the 330's fleet ...but this is just a rumour. No more.
only B738's
Photo © Ander Aguirre
According to UX they don't want a quad when the first 332 arrives. No longer. See above.
Quoting RAFVC10 (Reply 6):
The Air Europa's typicals one on long-haul: Cancún, Caracas, Punta Cana/Sto. Domingo, La Habana and Salvador (Brazil). And maybe PEK is included if this last destination is not, at the end, withdrawn.
Naïve!  Wink IB is immutable, unchangeable and invariable. Doesn't matter how its competition is doing things. IB has an unmistakable own-style ...always.
Rather informative. Thanks!
Quoting OwlEye (Reply 23):
Where's your imagination? Big grin Anyway, agree with you UX colors are not great but others are even more boring ...I'm thinking in the newest LAN's and Thai's liveries, for instance.
Finally, Air Europa has got a very good deal from Airbus as they was the first A350 launch customer. A very good movement because of the comprehensive discounts from Airbus and because to become in launch customer from a manufacturer is always important specially for a carrier which is not very known worldwide.
It's clear: Air Europa is consolidated like the Spain's second airline. But they are, still, far from the first Spanish airline: IB
If UX wants reinforce competition with IB, is key to get more slots in South America/intercontinental destinations and also the Air Europa's membership in SkyTeam.
AIRBUS 320 The world's most advanced single-aisle aircraft
miamix707
Fri Mar 10, 2006 11:08 am
Air Europa has one of the WORST/UGLIEST liveries hands down.
Why ugly? That logo is simply awful. Besides it takes some time to realize the blue letters don't read OE, but actually ae! Their livery makes the A330 look terrible. Well, it does that to the rest of their fleet as well.
PS: AIR EUROPA (hope your paying attention to how others perceive your brand)
LTU932
Fri Mar 10, 2006 4:23 pm
Quoting Anxebla (Reply 24):
Another key to reinforcing competition with IB would be for UX to also start entering into Central America. If UX enters SkyTeam, they can team up with CM from PTY and codeshare to places, where demand for nonstop service from MAD or BCN is rather low and at the same time, offer a different (maybe even better?) product in places such as GUA and SJO, along with PTY. IB has pretty much a monopoly here in Central America, and NM has little to no presence down here except at SJO and PTY even though I recall there is the posibility of them starting up flights to GUA and MGA, but as a more established airline than NM, UX could start fighting IB's monopoly in the region if they fly with their own metal and/or codeshare.
acelanzarote
Fri Mar 10, 2006 6:22 pm
Anyone know when this first A330 is due for handover to Air Europa?
from the Island with sun and great photo's.. Why not visit Lanzarote
JBOND
Fri Mar 10, 2006 6:53 pm
FOR DELIVERY, END OF MARCH 2006
