panam330
Can I Visit Other JFK Terminals When Flying B6?
Fri Mar 10, 2006 10:49 am
Just a simple question about terminals at JFK. I have a 4 hour layover with B6 in the beginning of April, and (since I've never had more than an hour there before) I was wondering if anyone knows if I could visit other terminals at the airport, like T4 or the AA terminal, even though I'm flying on B6. This is probably a stupid question to ask, but I've never actually been able to explore an airport like this before because I avoid long layovers.
Any input would be nice. Thanks to those who reply  Smile!
EMBQA
RE: Can I Visit Other JFK Terminals When Flying B6?
Fri Mar 10, 2006 10:56 am
I don't see why not, but you will not be allowed beyond the security check point as you are not ticketed for the terminal. I'm not sure about acess between the terminals.. but I don't think you can walk between them....
AlitaliaMD11
Fri Mar 10, 2006 11:03 am
You can take the Air Train around to visit each terminal.
I would recomend you visit Terminals 1 and 4 because they are the nicest (IMO) and offer the most for passengers not flying out of that specific terminal.
Terminal 2, 3, 7, 8, and 9 don't offer much for passengers not travelling out of those terminals.
[Edited 2006-03-10 03:13:33]
No Vueling No Party
FlightShadow
Fri Mar 10, 2006 11:07 am
I can't speak for JFK, but at SLC and ATL after you're thru one of the security checkpoints, you can to all of the terminals/concourses.
Also at ORD and IAH, where I've had layovers, I've been able to go all over without having to go thru any security.
[Edited 2006-03-10 03:08:29]
"When the tide goes out, you can tell who was skinnydipping."
TomTurner
PanAm330, you can walk between most (probably all) of the terminals, although its not set up to be easily done. You can take the AirTrain though.
Terminal 1 and Terminal 4 have considerable space/shops/restaurants accessable I believe before you get to the security check point.
Last I knew though a couple of the terminals did not have much to offer and the check point was not far from the entrance. Hopefully someone more up to date on that will post.
Tom
worldtraveler
Fri Mar 10, 2006 11:16 am
The Airtrain at JFK is outside the security checkpoints. You cannot enter terminals without a valid ticket for a flight inside that terminal.
DFW has become much more "visitor friendly" now that their train operates inside the security checkpoint. I just recently had the opportunity to visit the new int'l terminal at DFW although I didn't have a flight there thanks to the new train.
AirAmericaC46
Fri Mar 10, 2006 1:23 pm
Yes, you can get out from B6 terminal, take the AirTrain (which is free) and go first to Terminal 1, and go to the fast food area eatery on the 2nd floor and you can eat and get a great view!! Then proceed to Terminal 4 but the view here is not as nice as Terminal 1----you don't pass through security on both terminals.
hawk44
Fri Mar 10, 2006 1:58 pm
Stupid question but which terminal would be best for spotting the heavies?
Or which terminal has the most international departures?
Hawk44
Never under estimate the power of US
FlyDeltaJets
Fri Mar 10, 2006 2:06 pm
If you are a B6 crew member you have guranteed access to terminals 2,3,4,6,7,8 and 9 but at Terminal 1 they act a little funny to persons not belonging to any of thier airlines
With acess I mean beyond the checkpoint
[Edited 2006-03-10 06:14:04]
The only valid opinions are those based in facts
prosa
Fri Mar 10, 2006 2:10 pm
Quoting WorldTraveler (Reply 5):
 Confused
You certainly can enter the terminals without holding tickets. As with any airport, you cannot go past the security checkpoints, and not all of the terminals offer much to see, but entry into the terminals is possible.
"Let me think about it" = the coward's way of saying "no"
FlyDeltaJets
Fri Mar 10, 2006 2:15 pm
Quoting Hawk44 (Reply 7):
The most heavies would be at Terminals 1 and 4
panam330
Sat Mar 11, 2006 1:25 am
Thanks for all of the replies, I appreciate it! I'll be checking out T1/T4 then! Any chance I can walk past T5, or not, because of the construction?
vtnyc
Sat Mar 11, 2006 1:40 am
Quoting PanAm330 (Reply 11):
T5 is cordoned off to the general public but the Air Train is elevated and you can get an semi-aerial view of all the terminals. I suggest that you pick up something to eat at T4 and stay on on the train inter-terminal train. Don't even get off the train for T2 and T4 as the security check point is right by the entrance to terminals.
VT-NYC
First Flight, PA001 DEL-FRA-LHR-JFK; Dream- JFK-COK on a B6 787
AlitaliaMD11
Sat Mar 11, 2006 2:30 am
Quoting VTNYC (Reply 12):
Oh yeah, that is true. All though it is still worth checking T4 out for the massive and beautiful check in area. You can also get a semi view of the T4 apron from the check in area.
No Vueling No Party
FlyDeltaJets
Sat Mar 11, 2006 3:05 am
Quoting AlitaliaMD11 (Reply 13):
jetBlue Operates from Terminal 4, so that means any jetBlue crew or employee have acess to the area beyond the checkpoint.
AlitaliaMD11
Sat Mar 11, 2006 3:11 am
Quoting FlyDeltaJets (Reply 14):
Again that is true. Although most of us sadly don't have that type of access beyond the check point areas. Although luckily enough for me tommorow I am flying Jet Blue to SJU out of T4 so I do get to go beyond the check point.
[Edited 2006-03-10 19:14:26]
No Vueling No Party
vtnyc
Sat Mar 11, 2006 4:40 am
Sorry, meant to say T2 and T3. You get to quite a bit of T4 but the actual gate area is beyond security. Nice food court though.
VT-NYC
jfklganyc
Sat Mar 11, 2006 9:47 am
"If you are a B6 crew member you have guranteed access to terminals 2,3,4,6,7,8 and 9 but at Terminal 1 they act a little funny to persons not belonging to any of thier airlines "
Good! I'm glad they give you a hard time! JetBlue Terminal 6 is the only terminal I have ever been too that they required me to get a non-rev boarding pass to get through security.
They hassle crewmembers from every other airline except jetBlue. Nobody does that! It's inconvenient and unnecessary to hassle commuters like that.
PJ
Mir
Sat Mar 11, 2006 1:26 pm
Quoting PROSA (Reply 9):
Not T3, where the security is at the door (last I remember). You can get into T2, but the area outside security is so tiny it isn't really worth it.
-Mir
N1120A
Sat Mar 11, 2006 1:29 pm
Quoting FlightShadow (Reply 3):
JFK is set up similarly to LAX and BOS where it is more set up for O&D traffic and less so for connections. The terminals are independant of eachother and have seperate sterile areas.
Users browsing this forum: 815Oceanic, Alsatian, B747forever, Baidu [Spider], Bricktop, CrimsonNL, Dutchy, edmountain, FAST Enterprise [Crawler], Google Adsense [Bot], haynflyer, Iemand91, jmchevallier, journeyperson, kalvado, KarelXWB, mafaky, MD80MKE, mercure1, Mimark06, MSNbot Media, Newbiepilot, Nimish, philabos, PW100, PWAB, Revelation, RL777, Roadcruiser1, shamrock350, StTim, TVNWZ, usflyer msp, windian425 and 12 guests
