Broocy
Terminal Changes At LHR When Terminal 5 Opens
Fri Mar 10, 2006 3:47 pm
I saw on BA's website that flights to Australia and Spain will operate from Terminal 3 when Terminal 5 opens in March 2008. This is being done to ensure cohesion between codeshare partners QF and IB.
Does anyone know where one can find out which airlines are switching to which terminal when Terminal 5 opens?
Tristarsteve
RE: Terminal Changes At LHR When Terminal 5 Opens
Fri Mar 10, 2006 11:19 pm
Ba are operating out of T5 and T3 until the T5 second satellite is opened..
Skyteam are going to T4,
Star Alliance to T1
Concorde001
Sat Mar 11, 2006 1:13 am
Quoting TristarSteve (Reply 1):
Star Alliance to T1
Correct - The following terminal arrangements have been discussed (though subject to change).
T1 = Star Alliance
T2 = demolished. The area currently being used for T2 along with T1 will be used to implement BAA's Heathrow 'Master Plan' which is basically the construction of a brand new terminal.*
T3 = Virgin Atlantic, non-aligned carriers and oneworld carriers.**
T4 = Skyteam and non aligned carriers
* Subject to CAA approval. Details of the plan can be found here:
BAA Heathrow Master Plan
** When T5 opens in 2008, only the main terminal building and one of the two satellites will be operational. The third satellite will open in 2011. Consequently in 2008, 90% of BA's operations will be in T5 with the remaining 10% in Terminal 3. I know T3 can be quite dreary to say the least, it is scheduled for a major facelift. For example Virgin's area of the terminal is being completely renovated and refurbished by the designers of Hong Kong airport. BA and oneworld decided on T3 because it is closer to T5 making connections easier. It looks like BA's Spanish and Australian flights will operate from T3 with the IB/QF which is quite strange as it was reported in 'Business Traveller' that QF and BA had signed an agreement which would allow QF into T5 - maybe thats in 2011?
Broocy
Sat Mar 11, 2006 3:52 am
Thanks for your help all.
The only reason I can think that QF is moving into T3 would be for the extra A380 gates. With the Star move to T1, will T1 be getting A380 gates too as SQ will be an early user of the A380 at LHR?
BMIFlyer
Sat Mar 11, 2006 3:56 am
Quoting Concorde001 (Reply 2):
T1 = Star Alliance
How the hell?
T1 is no way near big enough....
Lee
kaitak744
Sat Mar 11, 2006 10:21 am
Um, not really. There is the main T5 building and 2 satellites. The Second satellite is set to open 2 years after the actual terminal opens.
Also, ALL CONSTRUCTION what so ever, is scheduled to be finished before 2012.
Quoting BMIFlyer (Reply 4):
T1 = Star Alliance
How the hell?
Well, there is no way BMI can fit anywhere else. And plus, T1 will eventually have added area from T2, so it will be big enough.
ScottB
Sat Mar 11, 2006 11:04 am
I was wondering the other day if it wouldn't make sense to build parallel runways on the north and south sides at LHR in a layout similar to ATL, LAX, and DFW -- especially given that the new Terminal 5's layout is not dissimilar to ATL's layout. It certainly seems that this would be less disruptive than the plans to build the third runway far north of the current terminal complex, and it would allow for significantly more capacity.
Terminal 4 would have to be demolished as part of that sort of redesign, along with relocating roads and parking areas (and perhaps additional structures to the north), but it seems like the most effective way to allow for growth.
cloudyapple
Sat Mar 11, 2006 11:48 am
Quoting Kaitak744 (Reply 5):
Which was exactly what Concode has said above...
Quoting ScottB (Reply 6):
No we can't do very close parallel runways because we don't do close staggered visual approaches here. The small airspace doesn't allow you to sequence arrivals that close. PRM will be required which the UK dont have any experience (and is expensive to implement).
If the approach wasn't a problem, I supoose without demolishing T4 this can only happen on the north. You will need the runways to be approx the same length and slightly staggered (to achieve the required vertical separation and minimise transverse separation on final) which is not possible because of the infrastructure around (M25). RETs will be required for the "inner" (existing) runway which will be difficult to manage because of the heavy usage of taxiway alpha. Missed approaches are also a problem. I can think of many more reasons but i suppose that's enough to make that idea a non starter. I wish we had the airspace and land they have in atlanta to allow all this to happen...
That's unlikely to happen. I agree it can do with some sort of updating but before T5 opens it is still the newest terminal so the least priority.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
UAL777UK
Sun Mar 12, 2006 12:32 am
T2 is going to be demolished and rebuilt in time for the 2012 Olympics and thats earmarked to be the Star Alliance terminal.
