CVG72
DL's Online Check-In. A Little Help Please.
Sat Mar 11, 2006 11:12 am
Can someone tell me how easy DL's online check-in is, and do they let you print paper tickets. I'm flying CVG-ATL-SXM on Monday.
CVG72
Roll Tide // Next: UA/EV/LH CVG-EWR-FRA-DUS-MUC-EWR-CVG
B4REAL
RE: DL's Online Check-In. A Little Help Please.
Sat Mar 11, 2006 11:13 am
It is easy for domestic routes. However, I don't know if that SXM end destination is valid for online checkin.
B4REAL, spelled like it sounds
Alitalia744
Sat Mar 11, 2006 11:15 am
I'll echo B4real's comments and say I find DL's online check-in to be the easiest of the legacies...
Not sure if it would work for SXM
Some see lines, others see between the lines.
GSPITNL
Sat Mar 11, 2006 11:19 am
You cannot check in online for International flights. You MUST check in at the Airport. Sorry  Sad
Fly Delta - The Only Way To Fly! Silver Medallion Baby :)
CVG72
Sat Mar 11, 2006 11:24 am
Quoting GSPITNL (Reply 3):
But can I check in for the CVG-ATL leg online?
CVG72
skibum9
Sat Mar 11, 2006 11:30 am
And you cannot use the kiosk at the airport. The check-in staff will need to make sure you have the proper requirements fulfilled for immigrations, i.e., passport, etc.
Tailwinds!!!
B4REAL
Sat Mar 11, 2006 11:40 am
Quoting CVG72 (Reply 4):
CVG72
Not if the two routes are married and bags would be checked through.
GSPITNL
Sat Mar 11, 2006 11:41 am
No you cannot. You will have to check in at CVG in the International Departures line. Reason being they have to check your passport and everything to make sure your valid to travel internationaly
jumbojet
Sat Mar 11, 2006 12:16 pm
Quoting GSPITNL (Reply 7):
according to delta, that is soon changing and you will be able to check in via a kiosk for international flights. I forget where i read it but its coming soon.
dairbus
Sat Mar 11, 2006 7:23 pm
Quoting Jumbojet (Reply 8):
That rings a bell. A couple of weeks ago I noticed the kiosks in ATL had been upgraded recently with scanners for the machine readable strip on the information page of passports. This might be in preparation for kiosk check-in for international flights and may also be related to the new baggage sorting system coming on line soon which may allow mixing of domestic and international bags in the same system.
"I love mankind. It's people I can't stand." - Charles Shultz
CVG72
Sat Mar 11, 2006 10:06 pm
Thank you guys all for you help, but unfortunatley, I now have to wake up a half hour earlier, for my 7:00 AM flight.  bomb
CVG72
B4REAL
They mention it for JFK's added features recently. No mention officially for other stations/hubs.
Alitalia744
Sun Mar 12, 2006 12:02 am
Quoting B4real (Reply 11):
ATL/CVG are on the list. Not sure about SLC.
