rjpieces
Question About JetBlue Crew Rest
Sat Mar 18, 2006 1:27 am
So I was looking at their new service announced today and wondered how they do this:
JFK-JAX:
8:20am – 11:05am
1:30pm – 4:10pm
7:55pm – 10:45pm
JAX-JFK:
6:20am – 8:45am (eff. 6/16)
11:45am – 2:10pm
4:50pm – 7:15pm
Does the crew that arrives at 10:45 fly out at 6:20 AM? If so, isn't that less than the minimum overnight hours (by the time they get to the hotel, and waking up early to get to the airport)?
Or do the overnight two crews for ~12 hours each?
"Millions long for immortality who do not know what to do with themselves on a rainy Sunday afternoon"
B6JFKH81
RE: Question About JetBlue Crew Rest
Sat Mar 18, 2006 1:32 am
Good question on that one! I don't have the foggiest on that. I give our crew schedulers a lot of credit for figuring that stuff out. I haven't even received confirmation that a/c will RON at JAX yet but I am guessing they will based on that schedule.
crogalski
Sat Mar 18, 2006 1:55 am
they'd go out on either 11:45am – 2:10pm
4:50pm – 7:15pm
unless they're off
atleast that's how it is from TPA here..
They'll come in on flight 29, and leave on 856 (when its active) or now, 60, the following day.
[Edited 2006-03-17 18:14:18]
A319 A320 A321 A330 B717 B727 B737 B747 B757 B767 CRJ200 CRJ700 CRJ900 DC9 E145 E190 MD88 Q400 | AA AB B6 CO DL EI FL NK
NASBWI
Sat Mar 18, 2006 2:13 am
I'm more inclined to agree with Crogalski. I believe the crew that arrives in JAX at 11.05am will overnight and take the first flight back at 6.20am, and the last crew to arrive will take the second flight out at 11.45am...I might be wrong, but that's usually how it happened at the carrier I worked for previously.
Fierce, Fabulous, and Flawless ;)
rjpieces
Sat Mar 18, 2006 6:09 am
Quoting NASBWI (Reply 3):
Don't you mean the crew that arrives in JAX at 4:10 PM? It must be very costly to overnight two crews at many of these cities that have 6AM flights out...
NASBWI
Sat Mar 18, 2006 12:09 pm
Quoting RJpieces (Reply 4):
Nope. If you think about it (I know, it seems confusing; I gotta give props to crew scheduling lol), the second flight out of JAX is actually the first flight out of JFK on a return. Therefore, the crew that gets off that flight will overnight, and the second flight out of JFK that leaves around 4pm is just a turn, no crew change. So essentially, the first crew in from JFK takes the first flight out, and the last crew in takes the second flight out. The 4.50pm (last) departure from JAX would therefore be a turn.
I dunno how expensive it is to get a few more hotel rooms on a contract (that's a whole 'nuther department lol), but I'm sure it's cheaper in the long run than letting a plane sit for hours in JFK. By overnighting another crew, you can have more utilization of the aircraft (i.e. add another flight to the schedule). However, since the 6.20am JAX-JFK isn't supposed to start till June, my guess is that there might only be one overnighting crew to begin with.
rjpieces
Sat Mar 18, 2006 12:41 pm
Quoting NASBWI (Reply 5):
Thanks for the info...So why make the 4:50 departure from JAX a turn? Wouldn't it make sense to have a turn on the first flight?
InTheSky74
Sat Mar 18, 2006 12:55 pm
They will probably do the first flight of the day as a turn. Most cities have the first flight of the day with the same crew in/out, and they do layovers for the remaining flights (hotel costs are lower, etc).
In regards to layovers, it would probably be cheaper to have layovers in JAX than in NY, so if the crew isn't based in NY, they could have them spend a night in JAX and it would be a lower cost to the airline.
Rob
NASBWI
Sat Mar 18, 2006 1:19 pm
Quoting RJpieces (Reply 6):
Perhaps, but then one has to consider other legs of that trip. Scheduling has to take all this into account; so the seemingly senseless early overnight (morning till morning) might actually work really well with the rest of the pairing. I'm sure underneath the surface there's a method to their madness  smile . Then again, I could be waaay off base.
rjpieces
Sun Mar 19, 2006 1:31 am
Quoting NASBWI (Reply 8):
Perhaps, but then one has to consider other legs of that trip. Scheduling has to take all this into account; so the seemingly senseless early overnight (morning till morning) might actually work really well with the rest of the pairing. I'm sure underneath the surface there's a method to their madness . Then again, I could be waaay off base.
Nope, that sounds right...Are you a jetBlue F/A?
I wonder how scheduling decides which flights/routes to put together....Is it all done by computer these days?
jjbiv
Sun Mar 19, 2006 1:59 am
Does B6 have stand-up (or high-speed) overnights where a crew is technically on duty all night (albeit at a hotel most of the time)? If they do, this would allow the last inbound crew to work the first outbound flight back home.
Joe
NASBWI
Sun Mar 19, 2006 3:38 am
Quoting RJpieces (Reply 9):
I am, but I was formerly with DH, and scheduling kinda did the same thing with our JAX overnights (we had 3 daily flights there as well). Thing was, the JAX overnight was only one part of a pairing, which is why I figured B6 might be doing the same thing (with regard to scheduling).
NASBWI
Sun Mar 19, 2006 3:46 am
Quoting Jjbiv (Reply 10):
I'm not sure if B6 has stand-ups, but they do have reduced rest overnights at times (usually due to a delay on the inbound flight).
jfklganyc
Sun Mar 19, 2006 8:45 am
Stand up would be pushing it.
7:55pm – 10:45pm
6:20am – 8:45am
You have a show time for the 755pm flight at 705pm. You would not be off duty until 9 am at JFK . . . block-in time +15 minutes for postflight/debrief.
That's 13:55 on duty with 4hr 15 flight.
Can be scheduled up to 8 flight hours . . . so that's not a problem.
But they can't schedule you to go over 14 hrs flight time. You can go up to 16 hrs due to weather if in the air.
Either way, 13:55 minutes is pushing it and doesn't leave much room for error. If that outbound flight is delayed even 1 hr, the crew will time out and the flight will cancel.
Stand-ups are tricky and usually reserved for shorter flights with even shorter overnights.
PJ
rjpieces
Sun Mar 19, 2006 9:14 am
Could somebody explain standups and what routes jetBlue does this on?
NASBWI
Sun Mar 19, 2006 9:57 am
Quoting RJpieces (Reply 14):
A standup is where a crew works the last flight in, then the first flight out, leaving very little rest time (less than 8hrs). DH had a few of those between IAD and EWR, CLT, and PIT. Therefore, though they are technically overnighting, it's considered a day trip, and they are paid block time for the entire time they're gone. Again, I don't know if B6 has any of those in their schedule, but I'm sure I'll find out soon.
jfklganyc
Sun Mar 19, 2006 11:46 am
"A standup is where a crew works the last flight in, then the first flight out, leaving very little rest time (less than 8hrs). DH had a few of those between IAD and EWR, CLT, and PIT. Therefore, though they are technically overnighting, it's considered a day trip, and they are paid block time for the entire time they're gone. Again, I don't know if B6 has any of those in their schedule, but I'm sure I'll find out soon."
That is sort of incorrect. The crew IS NOT overnighting. It is continuous on duty time, thus duty limitations apply. The crew never goes into rest.
PJ
NASBWI
Sun Mar 19, 2006 5:08 pm
Perhaps I should've clarified; they're not "overnighting" but rather spending the night. They do stay at a hotel, but if anything should come up (such as a ferry flight), they are obligated to respond immediately. So yes, they are on continuous duty.
rjpieces
Mon Mar 20, 2006 12:30 am
Quoting NASBWI (Reply 17):
Off topic, but how does it work when you are a reserve pilot or F/A? Do you spend your shift at JFK, or at your home in the vicinity, or what? How often are reserves called up?
NASBWI
Mon Mar 27, 2006 8:27 am
Quoting RJpieces (Reply 18):
Heya RJ...I'm not sure about the pilots, but as for F/A's, on reserve duty you should always be within 2 hours of your base airport (whether it's home or a crashpad, etc). If they call you when you're on duty, and you can't make it to the airport within the specified time, you can get into trouble.
As for how often they're called, it varies. I just completed my first week of reserve at B6, and I'm excited to report that I was used every day (six days of reserve, and got scheduled for a 4-day and 2-day trip - A320 F3). It's not always the case though, and it usually depends on what's available, and where you "sit" in the buckets (how many are with you on reserve, and how legal they are to fly certain trips). So I guess I really just lucked out. Cheers!
rjpieces
Mon Mar 27, 2006 9:11 am
Quoting NASBWI (Reply 19):
Congrats!
Cool, now is that because an F/A called in sick or what? So were you a sub in the crew or was the whole crew reserve?
What trips did you take?
But you are paid when you are on reserve, right?
Jeff G
Tue Mar 28, 2006 2:31 am
JetBlue doesn't have any high speeds, standups, CDO's or whatever you want to call them. Generally, for a situation like JAX, there are two crews overnighting and one plane. One crew brings in an afternoon flight and departs first thing in the morning. The other crew brings in the last flight and departs the next afternoon.
