FLALEFTY
"Back To The Future" For B6
Tue Mar 21, 2006 12:01 am
http://www.thestreet.com/_yahoo/stoc...cm_ven=YAHOO&cm_cat=FREE&cm_ite=NA
I admire Neeleman for owning up to JetBlue's recent troubles and being proactive in trying to fix them. But I did not realize that the E190s were so troublesome. Perhaps they should have opted for the A318........
luv2fly
RE: "Back To The Future" For B6
Tue Mar 21, 2006 12:03 am
Quoting FLALEFTY (Thread starter):
It has been reported numerous times that the A318's are to heavy of a plane for what B6 needs.
FLALEFTY
Tue Mar 21, 2006 12:49 am
Quoting Luv2fly (Reply 1):
I know the 318 v.s. 190 debate is old news. But with the rough start of 190 service hurting B6's bottom line, it makes me wonder if the heavier-but-more-reliable 318 might have been a better fit, after all.
FLAIRPORT
Tue Mar 21, 2006 1:11 am
If I could pinpoint one day:
The massive snowfall in NYC last month caused massive delays and cancellations, leading to a lot of money lost and customers lost. I hope they learned from their mistakes.
However, Neeleman is very bright. I don't think he regrets (nor should regret) any decision he makes. If he had stayed along plan, B6 would not be a major player imho. So, maybe adding the origional plan, with the B6 name out there, and with Independence gone, will make it easier to succede in these areas. And the E190 should have all of thier kinks out soon, and I have no doubt that their reliablilty will increase as the year goes on. A lot of people are making this to be a major issues to B6...I call it a reality check: no airline is safe, not even WN...but those airlines are smart and still in a position to move out of the downward spiral if you can call it that, and move back to profitiblity.
NEXT FLIGHT: FLL-ATL-HPN on FL
ikramerica
Tue Mar 21, 2006 2:36 am
While I understand they had some teething pains, how do you get this statement from the article. The E190 is mentioned in passing, not as the main cause for the trouble. The main cause for the trouble is choosing the wrong routes. Interesting that the list of 44 original cities is still not filled. As per another thread, it's also interesting to me that they generally have left the "red" cities out of their plan and focused primarily on "blue" cities. All those cities he named that they failed to add are red leaning cities, after all...
FLALEFTY
Tue Mar 21, 2006 2:44 am
Quoting FLAIRPORT (Reply 3):
You are right, the weather that day was beyond B6's control, but all frustrated passengers will typically say is, "They (The airline that delayed them) are the worst airline in the world!" But eventually, memories of such unfortunate incidents will fade away.
Yeah, I did not mean to slight the E190, because every new jet has to go through teething problems, no matter who builds it. Eventually, the E190 will be a good, reliable performer for B6, it just surprised me that they chose to be a launch customer when they are also so new. Bigger, legacy airlines have the cushion of easing new jets into service and still having their older planes available for back-up until all of the dispatch reliability bugs are worked out. With the E190, B6 has no back up.
B6JFKH81
Tue Mar 21, 2006 2:54 am
While the E190 had (and still has) some teething pains, it is becoming more reliable. In fact I got an e-mail today indicating that friday didn't see many delays at all for the E190 which operated 20+% more on-time than the A320. Also, with most of the units flying the E190 not being interchangeable with the A320, big hits were taken on stocking up on the necessary parts for the a/c and then starting to chart what parts were failing...both time and money consuming. But things are leveling out a little now. I am curious how Air Canada and COPA are doing with their E190 fleet.
PHLBOS
Tue Mar 21, 2006 2:59 am
Quoting FLALEFTY (Reply 2):
Too bad B6 passed over the 717 when it decided to go with the E190. Had B6 opted for the 717:
1. Production would not be ending at Long Beach this May.
2. They wouldn't have encountered as many teething problems with the 717 because the type was already in production (when B6 started). FL & TW along w/Boeing already sorted any 717 teething problems that might've existed when it first rolled out.
[Edited 2006-03-20 19:00:02]
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
richierich
Tue Mar 21, 2006 5:06 am
Quoting Ikramerica (Reply 4):
Wrong routes? How so?
And who said the airline had to fly to the original 44 listed cities? I'm not sure, but I think they were examples of the types of cities the "new" airline could fly to - doesn't sound like any obligation to me. If I recall correctly, California didn't figure into JetBlue's original plan nearly as much as it does today. Hey, you go where the money is.
None shall pass!!!!
mariner
Tue Mar 21, 2006 5:28 am
By his own admission, he regrets becoming "enamoured" of the trans-cons. That's a fairly alarming statement.
There must be days when he wonders if he should have swapped a few A320 orders (by his own admission, they may have too many coming) for some A319's for the trans-cons - or even a few A318's?
Surely, he has to have some concerns about staking his LA claim at LGB, with its considerable limitations.
We know he is having second thoughts (if not actual "regrets") about ordering quite so many aircraft to be delivered quite so soon.
And if the chosen routes are problematic, maybe it's time they did something about the route planning department.
You are right in one sense - no one should "regret" their decisions - but it would seem there needs to be an overhaul of thinking at JetBlue.
cheers
mariner
aeternum nauta
airfrnt
Tue Mar 21, 2006 6:21 am
In general, I still maintain that there is a a ideal zone for larger carriers. Simply put, don't fly anything with under 100 seats, or anything with more then 250 seats. While F9 and FL have shown that it is possible to efficently run a LCC with two types of planes (F9 - A318 and A319 and FL with the 717 and 737) and southwest has juggled more then four types at once, the trouble B6 has had introducting the E190 strongly suggests that running more then one aircraft vendor is problimatic at best.
Quoting Mariner (Reply 9):
The transcon markets used to be the same money maker that the international market is now. When fragementation hit first using 767 and 757s and then even smaller planes hit the profit margins and the transcons really became a bloody mess.
I think the lessons are pretty obvious. You either have to have extremly low costs, or extremly high servers. Dumping capacity on the market will kill you. Expecting loyalty on these flights will also kill you.
International carriers: Take note. This will happen to you
I think it proves that F9 got the fleet sourcing and location right. Part of that is just the advantage of DEN, it's the largest capacity airport in the middle of the country, but part of that is their mix of A319 and A318 have been right on the money for their markets. In their case DEN also makes it possible to add A320 on certain markets without the huge penalties that B6 has been seeing but I think that F9 is on the "right size" here.
I think this also emphasizes something that Neeleman ought to look at. Having his hubs in New York and Long Beach mean a ton of transcons. He should (imho) look somewhere in the middle of the country for another hub that would let him split his traffic a bit more efficently (given his operating restrictions with the A320s). JFK <-> LGB should be a non-stop, other desitinations on the west coast would be better served by a better hubbing structure.
PHLBOS
Tue Mar 21, 2006 6:42 am
Quoting AirFrnt (Reply 10):
A few comments about the above-comparisons:
1. IIRC, the 318/319 are essentially the same plane type; one's just a shortened version (actually, the 318 is a double-shrink of the 320 whereas the 319 is only a single shrink). Therefore F9's mainline fleet maintains fleet commonality.
2. While WN, at on time, flew as many as 4 types of 737s (-200, -300, -500 & -700); the fact remains that all the planes are still one basic type, just several versions depending on vintage.
3. While FL's fleet of 717s & 737s are truly indeed 2 different types (FL originally did not want to go this route but Boeing was not going to offer either a stretched or a longer-range 717 unless there were additional takers); one needs to keep in mind that FL's original fleet (pre-J7 merger) was all 732s. So in essence, many FL pilots already had 737 experience when the newer 73Gs came on line. That's an advantage that B6 did not have when the E190s came on line.
[Edited 2006-03-20 22:44:11]
lightsaber
Crew
Tue Mar 21, 2006 7:32 am
Quoting PHLBOS (Reply 11):
Interesting point. While I'm aware IFR landings have stricter guidelines if the pilot has < 100 hours in that type, how long does the experience stay in the pilots record before it expires? For example, from the FL 732's, would that experience still translate to the 73G's expire after two years, five, ten, or indefinitely? I'm just curious.
Note: When will B6 start promoting E190 co-pilots to pilot? IIRC it was at 9 months, but notice I'm asking. By the end of 60 days with the type, I would think that a pilot would understand the quirks of the aircraft. What I'm getting at is when will B6 have enough pilots familiar with the E190 that pilot experience with the type is no longer a contributing factor to the delays and shortened daily flight times.
Second question, I notice on June 30th a lot more E190 flights on their routemap. Is this due to B6 booking greater duty cycles on the E190's or just the arrival of more aircraft?
Also, what is the start day of the most junior B6 pilots? For the A320? E190? Airline pilot central hasn't updated their Jetblue page for quite a few months! Obviously, that sort of data goes stale quick. Or did I miss an update and this is accurate (Jan 2004, with the most junior pilot on an A320!?!)
http://www.airlinepilotcentral.com/a...ational-lcc/jetblue-2005030451.htm
Lightsaber
dacman
Tue Mar 21, 2006 7:58 am
Yep, it would have made more sense to go with the MD-95 (717-200) but you can't give airplanes away either and when an airline wants birds for next to nothing what can you do.
Then again maybe the airline won't be around for to many more years either with the way things seem to be going......stay tuned.
Mike
dacman
LGB/LAX Local
"Airliner Photography is not a crime"
PHLBOS
Wed Mar 22, 2006 12:20 am
Unfortunately Lightsaber,
I do not have answer(s) to your questions, since that's not the line of work I'm employed in.
The information on my posts was based on simple deductive reasoning(s). While there probably is some transitional training that a 732 (or 733) pilot might have to undergo in order to be certified to fly a 73G (can any pilots on A.net confirm this?); I believe it's a fairly safe assumption that the amount of time (& money) spent on that training/recertifications (if any) pales in comparision to training a pilot on a totally different make & type of airplane.
Another point worth mentioning would be, how many FL pilots (who weren't w/the original FL) that joined the airline already had 737 experience w/another airline? Compare that to how many B6 pilots having E190 (or even E170) experience before joining them. Mind you, this is not necessarily a knock on B6 (any airline that chose the type may have faced a similar experience); this is just pointing out the potential risk associated with choosing a completely new type of plane.
sllevin
Wed Mar 22, 2006 7:09 am
Quoting PHLBOS (Reply 7):
True, they just would have been stuck with the high operating costs of the 717.
The only reason it works for FL is because Boeing sold every airplane they bought at a loss (because they were committed to 150 shipsets).
Steve
WMUPilot
Wed Mar 22, 2006 7:38 am
Quoting B6JFKH81 (Reply 6):
I too got the email and am glad to see the E190 is starting to come out of the "teething" stage. I haven't gotten a chance to fly a leg on the new planes yet but I can't wait to do so. I was talking with a mechanic in the van one day and he was saying the same as the email. A lot of the original problems are getting worked out and the plane is really starting to show it's potiential!!
JetBlue - Bringing humanity back to air travel
WesternA318
Wed Mar 22, 2006 7:43 am
It may well could have been, F9 is having a great time flying them.
Is SLC in the blue or red?
Don't forget the DC-9-32's!
Quoting Dacman (Reply 13):
For me, B6 is to be avoided as much as DL.
Check out my blog at fl310travel.blogspot.com!
PHLBOS
Wed Mar 22, 2006 8:16 am
Quoting Sllevin (Reply 15):
 confused  You must be joking on the high operating costs part; at least as far as fuel burn is concerned. Both FL & HA reported significant fuel savings w/the 717 compared the DC-9s they had before. HA only used 4 supplemental fuel tanks for the Long Beach-HNL ferry flights as opposed to either 6 or 8 tanks w/their old DC-9-50s.
A few years back FL terminated the Air Wisconsin/Jet Connect CRJ services they offered for a short time because they (FL) discovered that it was cheaper for them to use their 717s instead of someone else's CRJs.
If by high operating costs you mean due to the choosing a different type of plane (no commonality with their existing fleet) altogether; how much more costly would a 717 be vs. the E190 for B6?
It was reported that Boeing only needed to sell 200 airframes to break even (the final production count will be 156); had TW's original order survived (whether through them or AA), the 200 mark would've easily been obtainable.
Quoting WesternA318 (Reply 17):
I'm well aware of FL's/J7's old DC-9-32s, thank you. The point to my earlier above-post was focusing on FL adding a newer type (the 73G) to their existing young fleet of 717s as it relates to B6's adding E190s to their fleet of A320s.
Last time I checked, the focus of this thread is supposed to be B6Big grin
WesternA318
Wed Mar 22, 2006 8:24 am
Quoting PHLBOS (Reply 18):
Last time I checked, the focus of this thread is supposed to be B6.
LOL, but Airtran is MUCH more fun to talk about, and fly!
PHLBOS
Wed Mar 22, 2006 8:35 am
Quoting WesternA318 (Reply 19):
Since B6 doesn't serve anywhere near PHL, I haven't had a chance to fly them; so I can't make a personal experience comparison.
