dartland
Busiest Airports By Size
Tue Mar 21, 2006 6:44 am
I've had this theory for a while that while there are many busy airports in this world, it would be interesting to qualify their business by their size.
Now, there are a few ways to do this:
1) Square mileage / acres the airport sits on
2) Number and type of runways
3) Terminal square footage
4) Number of gates
and a load of other variables, obviously.
Personally, I think the most interesting is square mileage/acreage.
So -- what is the busiest airport per acre in the world? More people and/or flights per acre than any other.
I ran the analysis on the 3 major NY-area airports and here is what I got for full-year 2005:
LGA: 38K pax per acre; 596 flights per acre
JFK: 8K pax per acre; 71 flights per acre
EWR: 16K pax per acre; 215 flights per acre
HUGE discrepancy between the 3 airports. JFK handles the most passengers, but the fewest flights, but sits on almost 2.5x the acreage of EWR, which sits on 3x the acreage of LGA!!!
Just to show another "small" busy airport -- here's DCA's 2005 figures:
24K pax per acre; 379 flights per acre (counting the 733 above-ground acres only)
Or to show ATL, the worlds business in passenger volume:
19K pax per acre; 209 flights per acre
Still, nobody even comes close to LGA! Can anyone find an airport that does?
What about the LEAST busy per acre?
N1120A
RE: Busiest Airports By Size
Tue Mar 21, 2006 6:59 am
Quoting Dartland (Thread starter):
That would be DMM, which opened in 1999. Before that, most thought it was RUH, but it was actually YMX
DFW has 7 runways
HKG
BTW, LAX does 18K PAX per acre
PHX
Tue Mar 21, 2006 8:08 am
The "World's Busiest Square Mile"--Chicago Midway--does 29k pax/acre and 450 flights/acre.
Still can't beat LGA.
Coronado990
Tue Mar 21, 2006 8:43 am
SAN should be up there...
27K pax per acre; 321 flights per acre.
Uncle SAN at your service!
SLCUT2777
Tue Mar 21, 2006 9:03 am
Gotta be DEN, built to be the super-hub that never was. Couldn't keep CO and couldn't lure DL from SLC as was originally planned. 53 square miles, 36million PAX per year.
[Edited 2006-03-21 01:18:04]
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
steeler83
Tue Mar 21, 2006 9:12 am
Quoting SLCUT2777 (Reply 4):
Gotta be DEN
DEN actually is the world's largest airport by land coverage... DEN is somewhat similar in appearance to that of ATL... Several concourses in a linear fashion.
built to be the super-hub that never was. Couldn't keep CO and couldn't lure DL from SLC as was originally planned. 53 square miles, 36 PAX per year.
I take it that there is tons of unused space at DEN... Also sounds a bit like PIT, although that was at one point the super hub for US.
Do not bring stranger girt into your room. The stranger girt is dangerous, it will hurt your life.
dartland
Tue Mar 21, 2006 9:13 am
The numbers I get for DEN:
1.2K pax per acre
17 flights per acre
IAHFLYR
Tue Mar 21, 2006 11:52 am
IAH has 5 runways.......everyone always forgets the 4th largest city in the US and the 3rd largest HUB city of all US airlines! Whats up with that? No RESPECT
steeler83
Tue Mar 21, 2006 12:04 pm
Just for the hell of it... PIT has 4 runways, with one of them being one of the longest in the country at roughly 2.25 miles in length... The overall size of land that the airport sits on is considerably larger than that of downtown's central business district... I am sure that PIT is put to certain shame by other fields out there like DFW, DEN, ATL, ORD, JFK, IAH, LAX, BOS, and IAD...
Jet-lagged
Tue Mar 21, 2006 12:08 pm
Singapore doesn't make it that high, surprisingly. - 8K passengers/acre, and 50 flights per acre.
Haneda I would guess ranks high, but I cannot find its area.
On an old website I found mention of Kai Tak having been 380 acres, and handling 28 million passengers. That figures to 73.6K pax per acre!
N1120A
Tue Mar 21, 2006 12:12 pm
Quoting Steeler83 (Reply 5):
No it isn't, it is fourth. DMM, YMX and RUH are all larger
Actually, DEN did 43,387,513 passengers last year.
gunsontheroof
Tue Mar 21, 2006 12:44 pm
I can't find any information on it's size, but I'd imagine SEA's passengers per acre number is quite high...
Picked a hell of a week to quit sniffing glue.
steeler83
Tue Mar 21, 2006 1:31 pm
Quoting N1120A (Reply 10):
Curse you inaccurate sites!!!  banghead  Although, I should have said that it was the largest in the USA in that regard. That's probably what I meant to say but failed to do so...
HPRamper
Tue Mar 21, 2006 2:43 pm
Just for kicks.
SEA - 11.7K pax per acre
136 flights per acre
SNA 19.2K pax per acre
698 (!!) flights per acre
And my own spacious PDX: 4.6K pax per acre
87 flights per acre
dartland
Wed Mar 22, 2006 12:20 am
Quoting HPRamper (Reply 13):
Wow -- crazy. But if you look at commerical travel only, that drops to only 206 flights per acre. Over 60% of those movements are general aviation. (to be fair, all the other figures are total also, but SNA clearly has a much higher general aviation percentage)
fantasticflyer
Fri Mar 24, 2006 4:09 am
Theres a particular aviation mag I read (name slips me right now) and in one of the issues it had statistics on busiest Airports...and LGA was right up there. I leave out of LGA ALL the time...and to really think about it, they receive/depart a tremendous amount of flights daily for it to be such a "small" airport !
IBERIA747
Fri Mar 24, 2006 8:22 am
Quoting N1120A (Reply 1):
HKG
I guess that's wrong, depending on how we see it.
HKG is indeed the world's largest terminal building. However, if the question is about a whole terminal complex (i.e. LHR's T1+T2+T3+T4+T5 or MAD's T1+T2+T3+T4) then there are airports which are way bigger than HKG in terms of terminal square footage.
¡¡VIVA ESPAÑA!!
