TWA902fly
United Summer European Schedules - Too Much Fun?
Sat Mar 25, 2006 11:43 am
I noticed that all United flights to Europe have a block time ending in 8 minutes. For example:
UA 941 FRA-ORD 9 hours 08 minutes
UA 959 LHR-ORD 8 hours 38 minutes
UA 949 LHR-ORD 8 hours 38 minutes
UA 909 AMS-ORD 9 hours 08 minutes
UA 947 AMS-IAD 8 hours 18 minutes
UA 935 LHR-LAX 11 hours 18 minutes
UA 943 CDG-ORD 9 hours 28 minutes
UA 901 FRA-SFO 11 hours 28 minutes
UA 951 BRU-IAD 8 hours 38 minutes
SFO-LHR, MUC-ORD flights seem to end in 3 minutes
UA 955 LHR-SFO 10 hours 53 minutes
UA 931 LHR-SFO 11 hours 03 minutes
UA 907 MUC-ORD 9 hours 53 minutes
Somebody in the scheduling department having a bit too much fun?
(yes i know i have too much time on my hands)
'902
life wasn't worth the balance, or the crumpled paper it was written on
nosedive
RE: United Summer European Schedules - Too Much Fun?
Sat Mar 25, 2006 12:08 pm
Wow, boredom for $100, Alex!
swank300
Sat Mar 25, 2006 12:19 pm
Hey can someone explain why it takes almost the same amount of time to go from LHR-LAX and from Fra-SFO? Shouldn't the london-lax route be shorter?
BA
Sat Mar 25, 2006 12:30 pm
Quoting Swank300 (Reply 2):
Los Angeles is more to the south and that's why they are about the same despite Frankfurt being further east than London.
It's a bit difficult to explain, it's because the earth is a globe (specifically an oblate sphere). My suggestion is to get a globe of the earth, get a string and hold one end of the string over Frankfurt and the other over San Francisco, then do the same for London and Los Angeles.
It'll make sense then.
Also, check out this website:
http://gc.kls2.com
You get these numbers:
LHR-LAX 4741 nm
FRA-SFO 4952 nm
The distances as you can see are pretty similar.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
AeroWesty
Sat Mar 25, 2006 12:54 pm
Quoting BA (Reply 3):
That really doesn't make a whole lot of sense, I don't think, since LAX is also about 200 miles east of SFO (draw a line due north from downtown LA, and it'll hit Reno, NV). This is why SF is closer to Hawaii than LA, because SF is so much further west, even though it's north of LA.
The major differences in block times have to do with traffic on the ground and taxi time relative to the time of day and departure point, routing, and plane type. If you notice, UA955 and UA901 are 747's, UA931 and UA935 are 777's, and when UA939 comes onto the schedule with a 767, the block time increases by 20 minutes over the 777 flight.
A lot of variables there.
International Homo of Mystery
BA
Sat Mar 25, 2006 1:18 pm
Quoting AeroWesty (Reply 4):
I'm glad you are thinking, but you are making this more complicated than it has to be. To make it simple, ask yourself. Is Los Angeles more to the east of San Francisco or is it more to the south of San Francisco?
It is more to the south than it is east, so for the sake of simplicity, consider it south.
Because it is further to the south, Los Angeles is farther from Europe than San Francisco is.
Take a look at this map and you will see what I mean:
AeroWesty
Sat Mar 25, 2006 1:37 pm
Quoting BA (Reply 5):
Nah, don't think I am. Remember, you're comparing a 211-mile and 10 minute difference between FRA-SFO (on a 747) and LHR-LAX (on a 777), and trying to justify the difference being due to LA being more southerly, without taking into consideration that there's a 90-mile and 15 minute difference when comparing the same aircraft for LHR-SFO and LHR-LAX.
The difference isn't solely due to LAX being more southerly, is my point.
BA
Sat Mar 25, 2006 2:27 pm
Quoting AeroWesty (Reply 6):
If LAX wasn't as far south as it is, than the difference in distance would actually be more than 211 nautical miles.
To put this in perspective, compare FRA-SFO with LHR-SFO. The difference is 288 nautical miles.
The reason why there is a 77 nautical mile difference is because of Los Angeles' more southern location.
LHR-LAX is farther than LHR-SFO.
Yes, again... that's because of Los Angeles' more southern location, therefore LHR-LAX is a longer distance than LHR-SFO.
Yes, there are many other variables that could be included. Both LHR and FRA are heavily congested airports and thats why there are many delays and long taxi times. However, I am here talking about distance.
LAX's more southern location makes its proximity from LHR/FRA farther than SFO's proximity from LHR/FRA.
NorthstarBoy
Sat Mar 25, 2006 3:35 pm
so why is it then that sfo-syd is actually shorter than Lax Syd, one would thank that since LA is further south, that is it closer to Australia, yet, Sfo-syd is a shorter flight, distance wise
Yes, I'd like to see airbus go under so Boeing can have their customers!
TWA902fly
Sat Mar 25, 2006 3:54 pm
you guys start your own topic about why cant you move LA closer to Frankfurt, while my question was light hearted i was sort of actually wondering if theres a reasoning behind the 3 and 8 minute schedules?
'902
BA
Sat Mar 25, 2006 4:42 pm
I must retract a previous statement I made.
LAX is actually approximately 0.3 degrees more to the east of SFO than it is south.
I just ooked up the longitude and latitude coordinates of both and compared them.
Sorry for any misunderstanding or confusion caused.
Mir
Sat Mar 25, 2006 5:01 pm
You missed the JFK-LHR flights, which are 7:18 going eastbound, and 7:48 going westbound.
That is interesting, I have no idea why they do that.
-Mir
BA
Sat Mar 25, 2006 5:10 pm
Quoting Mir (Reply 12):
My guess is standardization.
They're trying to keep things simple by going with specific intervals ending in 8.
It's easier to read and interpret this way.
Not sure why SFO-LHR and MUC-ORD are exceptions ending in 3 as TWA902fly found out however...
bistro1200
Sun Mar 26, 2006 2:14 am
Quoting TWA902fly (Reply 9):
Actually the reason is that the block time is now computed to the minute, instead of rounding to the nearest 5 minute mark. This used to give "pretty" departure times (1430, 1805, etc). Most airports are slot-controlled outside the US, and the departure or arrival time in those airports cannot change, thus the US-side of the times changes since most US airports that support UA's international service don't have slots or are not as restrictive. The fact that they all end in :03 or :08 is coincidence.
It is a cost-saving move, since now it has the effect of shortening the block time. Remember the additional minutes were added just make the times end on a :00 or :05. It also has the benefit of a few minutes of additional connecting time.
Measure to the millimeter, mark with a crayon, cut with an axe.
TWA902fly
Sun Mar 26, 2006 2:18 am
Quoting Bistro1200 (Reply 13):
You know thats a pretty big freakin coincidence. Plus BRU, MUC etc are not slot controlled. I am not sure i'll go with your answer. LHR i would believe... but the other ones?
'902
