cpos
LaGuardia Rwy 31 Approach Question
Wed Mar 29, 2006 12:10 am
Just landed at Laguardia this morning on DL1907 from BOS. I've done this trip about 50 times in the last 15 months and always had the same question when landing on rwy 31. Never got a chance to ask the flight crew.
Is 31 visual only or is it ILS? It seems like the gear go down around 1800ft but then there is a sweeping left turn at about 1000 or so. If it is an ILS approach, when do you actually hit the localizer? Prior to, during, or after the turn?
Alitalia744
RE: LaGuardia Rwy 31 Approach Question
Wed Mar 29, 2006 12:48 am
i think you're talking about the expressway visual.
when they're using the localizer, you usually fly right over LGA and make a series of right turns over the sound and line-up for a straight-in 31 approach.
i could be wrong tho
Some see lines, others see between the lines.
FlyHoss
Wed Mar 29, 2006 12:56 am
The approach you're describing sounds like the "Expressway Visual" to runway 31. Runway 31 also has an instrument approach; it's a localizer approach (an ILS without the glideslope component).
When flying the Expressway Visual to 31, I always to tune in the localizer to 31 as a back-up reference to the final portion of the approach, but rarely notice it, as the approach often demands nearly full visual attention outside (to line up with the runway centerline and to (visually) acquire the VASI (Visual Approach Slope Indicator lights)).
A little bit louder now, a lil bit louder now...
OPNLguy
Wed Mar 29, 2006 1:14 am
jumbojet
Wed Mar 29, 2006 2:34 am
Quoting Alitalia744 (Reply 1):
thats exactly right. it seems the localizer is used when the winds are above a certain speed
VEEREF
Wed Mar 29, 2006 2:48 am
Quoting Jumbojet (Reply 4):
Generally more to do with ceiling and visibility than windspeed. Done both with winds gusting to the 30's.
Airplanes are cool. Aviation sucks.
jfklganyc
Wed Mar 29, 2006 3:51 am
Yeh, localizer is used for wind only.
They hate , repeat, absolutely hate using it.
As for delays, the minute the switch to the Rwy 31 LOC, you are looking at an EDCT (Expect Dep Clearance Time) wherever ur coming from.
If the winds are strong enough and they switch to LOC 31 and departures of 31 as well, you are looking at 2-4 hr delays!! Minimum!
Now if they are using Exp Visual 31, and the visibility drops, they will switch to the ILS 4 circle to land 31.
Basically the same thing. When u hit the tanks u hang a right until Flushing Meadows . . . the a diving left.
Love the Expwy Visual Approach.
'LaGuardia Tower, Eagle 4801 over the Tanks'
 Smile
PJ
N864DA
Wed Mar 29, 2006 4:08 am
As mentioned, there are two approaches to 31. The first is the the Expressway visual, which is used when the winds are not that strong (or else the approach is too dangerous). It follows the LGA VOR at R-225 degrees until the DIALS intersection then turns in the direction of the Long Island Expressway (hence the name) at about 85 degrees, then over the little inlet starts turning left to line up with the runway. By the time the runway heading is reached, the plane is almost at the touchdown point. It is a strictly visual approach.
The second approach is used when the crosswinds are too strong for the first approach to be safe, but runway 31 is the only option to land. It follows the sound, then makes a series of right turns, the last one a very steep 180-degree turn to line up with the runway, about 11nm away. I experienced that approach this month and I can see why pilots hate using it. The winds combined with the steep turns make it unpleasant to anyone on board.
N864DA
jumbojet
Wed Mar 29, 2006 6:05 am
Quoting JFKLGANYC (Reply 6):
if your lucky enough to be on the left side of the plane and have a window seat you get great overviews of JFK airport on the localizer apprch.
you can say that again, it gets me excited  Smile
firstclasser
Wed Mar 29, 2006 7:48 am
I noticed an approach over the Cross-Island Expressway, in which the aircraft went north (just to the East of JFK), and then turned left to land on 31 left. Is this a derivative of the Expwy Visual?
SoBe
Wed Mar 29, 2006 7:50 am
I've only been on it once. It was awesome.
Sorry for plugging my own photo.
Photo © Michael Lowing
beertrucker
Wed Mar 29, 2006 8:03 am
here u go i will see if i can find a better one while i post this one.
http://www.flightlevel350.com/video_streaming.php?id=4604
here is a wild one of a 737. they had to make a s- turn to avoid departing traffic.
http://www.flightlevel350.com/video_streaming.php?id=1851
[Edited 2006-03-29 00:07:52]
[Edited 2006-03-29 00:08:57]
Fly HI
spikebe90
Wed Mar 29, 2006 8:44 am
IT's even fun in a King Air!!!!!!
keep it in the middle of the road
dallas74
Wed Mar 29, 2006 10:53 am
Quoting SoBe (Reply 10):
That is a great photo! Plug away!  Smile
dallas74
Wed Mar 29, 2006 10:55 am
Quoting Beertrucker (Reply 11):
Thank you for sharing those videos. They are great. I was on a flight that did one of those S-turns. It is quite a ride! The pilots who go in and out of LGA really do earn their pay.
jfklganyc
Wed Mar 29, 2006 11:25 am
"The pilots who go in and out of LGA really do earn their pay."
Do we? Thank you sir!
Now being LGA based, can you please tell management that?!?!?!?
hahahah  Smile
PJ
Users browsing this forum: b377, B757Forever, Bing [Bot], BRADWHO, col, cpd, gatibosgru, Google [Bot], hoons90, hunterboy, Indy, intotheair, IPFreely, jagraham, knope2001, PanzerPowner, PJ01, Prost, Shrimpo7, tilerchin, xcltflyboy, zkncj and 254 guests
