Georgetown
RJ Landing Gear Not Retracted At DCA Today?
Thu Mar 30, 2006 7:08 am
Hey all,
I was walking along the waterfront in Georgetown today around noon and noticed an RJ departing from DCA up the Potomac with its landing gear down (long after it should have been retracted). As it was well past Rosslyn, I couldn't tell if it was an ERJ or CRJ, nor the airline. There's no way that its gear should have still been down at that point unless something was wrong. Did anyone else see this or hear anything about it? Thanks!
Let's go Hoyas!
OPNLguy
RE: RJ Landing Gear Not Retracted At DCA Today?
Thu Mar 30, 2006 7:15 am
Landing gear is sometimes left extended for a period of time, but it's much more common to see that with longhaul widebodies than it is for a RJ.
Another possibility, somewhat remote, is that the aircraft was a gear down maintenance ferry, going from DCA to the airline's facility...
SkyexRamper
Thu Mar 30, 2006 9:39 am
I once watched one of our B1900Ds depart MKE and climb out of sight (well over 5000') with its gear down, this was a revenue flight...crew forgot to raise the gear..oopps...
Good Luck to all Skyway Pilots! It's been great working with you!
B6JFKH81
Thu Mar 30, 2006 9:46 am
Quoting OPNLguy (Reply 1):
I saw a 747 depart JFK yesterday and it didn't bring up its gear all the way until it was out of sight..then I am hoping it retracted its gear!
KELPkid
Thu Mar 30, 2006 9:49 am
Quoting Skyexramper (Reply 2):
Should be readily apparent when they trim out for cruise and can't reach the correct indicated airspeed...
 Wink
avconsultant
I now the CRJ has a problem if the towbar is not disconnected properly. The nose gear will not retract. Then agian, it could have been a "gear-down" maintenance ferry.
jsposaune
Thu Mar 30, 2006 11:15 am
I suppose it could also have been a "go-around". (missed approach) In that airspace, I could see how a crew could be distracted and forget the gear until a bit later.
There are no stupid questions....only stupid people!!!
UAL Bagsmasher
Thu Mar 30, 2006 11:34 am
The BTMS may have been MEL'd, requiring the gear to be left down for a bit before retraction to ensure cool brakes.
L1329II
Thu Mar 30, 2006 2:11 pm
Quoting AvConsultant (Reply 5):
This has to do with not removing the nose gear pin. This particular pin is about 1/4 in diameter and about 8" long.
Having worked at an FBO I saw a VERY embarrassed CL-600 pilot taxi back to the ramp after getting a call from the tower that another A/C noticed the red remove before flight flag flapping in the wind.
"By the way, is there anyone on board who knows how to fly a plane?"
erjdrvr
Thu Mar 30, 2006 3:05 pm
sometimes we leave the gear down when the brakes are hot, once they cool the gear is retracted. we don't like hot things near the fuel tanks. why do you guys always asume we are screwing up  Smile
erj 170 Capt. Shuttle America
MrMcCoy
Thu Mar 30, 2006 3:13 pm
Quoting Erjdrvr (Reply 9):
Welcome to a.net.. It's one of the unfortunate sides of a forum like this, but the benefits outweigh the drawbacks.  Smile
It only takes five years to go from rumor to standard operating procedure.
2H4
Thu Mar 30, 2006 3:15 pm
Just taking the FAA's lead....  Wink
2H4
Intentionally Left Blank
erjdrvr
Thu Mar 30, 2006 3:24 pm
and here to help, right?
2H4
Thu Mar 30, 2006 3:28 pm
Quoting Erjdrvr (Reply 12):
Of course! Fast, friendly, streamlined efficiency...
Anyway, welcome to a.net, and thanks for bringing some flight deck insight to the forums.  Smile
2H4
Georgetown
Thu Mar 30, 2006 4:56 pm
I'll take hot brakes as an answer....I didn't even consider a screw up as an option, I'd trust a pilot more than a brain surgeon as his/her life is as much on the line as mine is!
Let's go Hoyas!
SkyexRamper
Fri Mar 31, 2006 12:35 am
Quoting KELPkid (Reply 4):
Damn it F/O why aren't we excelerating past 120kts...what the heck! Since when did the 1900 fly like a J31.  airplane   Silly
[Edited 2006-03-30 16:37:33]
lapper
Fri Mar 31, 2006 12:40 am
Quoting UAL Bagsmasher (Reply 7):
Can I get a translation on that please?
Goldenshield
Fri Mar 31, 2006 12:52 am
Quoting Lapper (Reply 16):
Brake Tempurature Monitoring System.
The MEL (A deferred maintainance item per the Minimum Equipment List) in question requires that the landing gear be left in the down position for 10 minutes after departure—regardless of time on the ground— and the aircraft must be able to fly in clear air (no visible moisture, to prevent ice build up) in order to facilitate the proper cooling of the braking elements on the wheels prior to being retracted into the wheel well. This is done due to the possibility of the wheels catching fire due to overheating. If the BTMS is inoperative, then the crew would have no way of knowing that the wheels are indeed too hot to retract into the wheel well, and this alternate procedure is applied to meet the requirements of that MEL.
Fri Mar 31, 2006 12:54 am
I'd vouch for Hot brakes too.Cooling using Relative Wind  Smile
regds
MEL
FlyDeltaJets
Fri Mar 31, 2006 1:25 am
Quoting L1329II (Reply 8):
I only can speak for Delta COnnection, and we don't use steering bypass pins for CRJ's they disconnect something in the back (I don't know what because I have never done it before) and when pushback is finished they reconnect it.
The only valid opinions are those based in facts
lapper
Fri Mar 31, 2006 1:27 am
Thanks Goldenshield. Does that mean then on a wet day, the plane has to be taken above the clouds before the landing gear can be retracted?
lapper
Fri Mar 31, 2006 1:33 am
apodino
Fri Mar 31, 2006 1:43 am
Quoting Lapper (Reply 21):
No, what it means is on a wet day the plane is parked until the problem is fixed.
If it was from DCA there was a good chance it was a ZW plane. IIRC, we had one plane with the main landing gear bay overheat mel, which also requires the gear to be down for ten minutes after takeoff.
L1329II
Fri Mar 31, 2006 1:59 am
Quoting FlyDeltaJets (Reply 19):
Interesting. Of course I was referring to the corporate version of the CL-600. 600, 601, 604 etc.
Thanks for the info.
Goldenshield
Fri Mar 31, 2006 2:01 am
After reviewing the MEL's, the Gear bay overheat is the most likely cause, and not the BTMS (I never said that it was in my originaly post. I was just clarifying.) If GBOH and BTMS are inop, then the flight must be flown gear down the whole flight, which means a slower airspeed and low altidude, and there are few carriers that I know of willing to provide that high of a fuel burn to get the customers to their destination.
A10WARTHOG
Fri Mar 31, 2006 2:40 am
On the CRJ's the torque links are disconnected. On ERJ's there is a switch that can be used on the outside of the aircraft to disable the steering or you can pull the E20 CB.
IAHFLYR
Fri Mar 31, 2006 2:48 am
Quoting 2H4 (Reply 11):
You want to be leading the FAA?  Smile mmmm
