widebodysrule
Int'l Flights To/From RDU
Thu Mar 30, 2006 4:29 pm
Why isn't it that United or Lufthansa have a flt to from rdu-fra?
[Edited 2006-03-30 08:30:25]
SA7700
Thu Mar 30, 2006 9:51 pm
Quoting Widebodysrule (Thread starter):
Why should there be a direct non-stop flight between RDU-FRA-RDU if there is not sufficient demand for such a service? United has a hub at IAD (224 miles away from RDU) and there are at least 6x daily United Express flights (CR7) between RDU-IAD-RDU that can feed pax onto-and from at least 5x daily services (United and LH) between IAD-FRA-IAD.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
bond007
Thu Mar 30, 2006 10:12 pm
It might be an idea to ask your question - giving detailed reasoning about why you are asking it.
A one line question like that could easily be asked for hundreds or airlines and airports in the US, or anywhere in the world.
Jimbo
ERJ170
Fri Mar 31, 2006 3:14 am
My first question is.. United? Of all airlines? United doesn't even have mainline to RDU.. let alone an international flight.
My statement is that RDU wouldn't be able to support the contemporary equipment utilized for such an internantional flight. There just isn't the numbers to support 763/777/330 service to FRA...
However, should an airline decide to utilize Boeings new 737-700ER aircraft, then RDU-FRA could be feasible and definitely profitable considering the business traffic that would utilize the service..
Aiming High and going far..
RAFVC10
Fri Mar 31, 2006 3:28 am
But AA is flying all year an LGW-RDU flight with 777 equipment. If the american airlines uses this aircraft, the loads, supposing, are high.
Why not to prove to start new flights from Raleigh to Germany??
El dia que los gilipollas vuelen, no podremos ver la luz del sol!
Womack17
Fri Mar 31, 2006 4:34 am
Quoting RAFVC10 (Reply 4):
Even though the RDU-LGW service does adequate business, it would not be in existence if it weren't for the corporate subsidies that guarantee that AA will make a profit on the route. I love RDU and am glad the service exists, but the facts are the facts.
Oh how I miss Midway Airlines. A class act right to then end.
cltguy
Fri Mar 31, 2006 7:00 am
Quoting SA7700 (Reply 1):
And don't forget that RDU is only 120 miles away from CLT which has service to both FRA and MUC on Star Alliance carriers US and LH.
SA7700
RE: Int'l Flights To/From RDU
Fri Mar 31, 2006 7:32 am
Quoting Cltguy (Reply 6):
Thanks for that Cltguy, with your input I thus rest my case.  Smile
SA7700
FlightShadow
Fri Mar 31, 2006 7:41 am
5X from ORD and 5X from IAD?!  eyepopping
"When the tide goes out, you can tell who was skinnydipping."
widebodysrule
Fri Mar 31, 2006 9:06 am
simple enough that there is hundreds of conx aday in rdu to fra and most either military or lh senators and that in itself is enough for at least 1 flt aday.....right  Wink
ewmahle
Fri Mar 31, 2006 11:37 am
You also have to concider, and this has been stated before about the
RDU-LGW flight, is that AA operates that flight and makes a lot of its profit from it with cargo alone, not always passenger loads.
bond007
Fri Mar 31, 2006 11:48 am
Quoting Womack17 (Reply 5):
Correct. The AA flight to LGW is not there because there is demand from your 'average' Raleigh area passenger market. It's only there because of one (or more) RDU companies guarantee a certain number of seats with employees that travel to Europe. These pax would connect in CLT, PHL etc., or even drive, if their company didn't have that deal with AA. Certainly AA wouldn't be doing it otherwise.
Jimbo
2travel2know
Fri Mar 31, 2006 11:57 am
In the subject of International flights to/from RDU, RDU does get quite a number of Latinamerican destinations via ATL, any Latinamerican airline must get a good O/D traffic of passengers connecting @ their hub to/from RDU before even think of flying to RDU.
CM E190 does have the range, but had the U.S. Armed Forces remained in Panama, such a PTY-RDU flight (even thirce weekly) could have been attractive; There are major U.S. Defense sites in North Carolina.
I don't work for COPA Airlines!
Rookinla
Fri Mar 31, 2006 12:08 pm
Quoting 2travel2know (Reply 12):
Maybe but I think that there are several cities that would be up first even considering the above statement. No doubt that CLT would be a higher priority in North Carolina. CM could probably get some feed from the US hub here to make it worthwhile.
Tornado82
Fri Mar 31, 2006 12:58 pm
Quoting Rookinla (Reply 13):
Isn't CM in Skyteam though?
Rookinla
Fri Mar 31, 2006 1:13 pm
Quoting Tornado82 (Reply 14):
They are in fact an associate member of Skyteam. CLT may or may not be on their short list of future detinations. I was just making an example of the potential traffic for them at CLT versus that of RDU. They will probably look at hooking up with Skyteam hubs and focus cities during their expansion. I wouldn't think that ATL would be high on their priority list because of DL. But CLT could be interesting though...CM couldn't survive there purely on O/D, but they could probably "creatively borrow" decent feed from the US Airways hub. Probably won't happen but it's interesting to think about...
Tornado82
Fri Mar 31, 2006 1:16 pm
Quoting Rookinla (Reply 15):
The thing with "borrowing" from the US hub is that US will likely be charging their fares as if the pax were O&D-ing to CLT, which are pretty high. Then till CM adds their fare on top of that, no pax can afford to do that when DL/ATL aren't that much longer of a flight, and there's still more connectivity in Atlanta than Charlotte. Just ask most residents of the Central Time zone who USAirways is.
boeingfever777
Fri Mar 31, 2006 3:50 pm
AA has a contract with GlaxoSmithKline to ferry their employees to/from England to their Triangle Park HQ in North Carolina.
Faire du ciel le plus bel endroit de la terre.
ERJ170
Fri Mar 31, 2006 3:58 pm
Hahahaha...
I definitely don't think that RDU will see CM any time soon. If anything south of the borders, I would think we would see AM/MX or perhaps one of their regional airlines.
Interesting fact, though.. that RDU actually does have a somewhat decent (uhmm.. sort of) O&D to Panama. Why? I"m not sure.. but we do.. But I think a flight to somewhere in Mexico would probably be much, MUCH more useful.
Quoting BoeingFever777 (Reply 17):
So here is my qeustion.. AA is contemplating axing that route. Which airline do you think would be willing to pick up the subsidized route? Perhaps BA could pick it up from the British side? I dont' think any US airline would have the spare 777.. unless DL got one of there's from off order for the route.. any thoughts?
SA7700
Fri Mar 31, 2006 4:27 pm
Quoting FlightShadow (Reply 8):
Take April 30, 2006 as a hypothetical date. From IAD-FRA the following flights are generated via Amadeus and Worldspan:
LH417 16h20-06h05 (A343)
UA916 17h13-07h10 (B744)
LH419 18h10-07h55 (B744)
UA952 18h38-09h10 (B763)
UA932 21h43-11h45 (B777)
Take May 21, 2006; FRA-IAD:
LH416 10h25-13h15 (A343)
UA953 11h00-13h59 (B763)
UA917 12h20-14h49 (B744)
LH418 13h25-15h55 (B744)
UA933 17h00-19h34 (B777)
There is 4x daily services between ORD-FRA-ORD on LH and UA. The 5th daily service is on AA.
SA7700
bond007
Fri Mar 31, 2006 11:02 pm
Quoting ERJ170 (Reply 18):
My question is why are they considering stopping it?
Presumably because it's not making money? In which case why would we expect somebody else to pick it up? If it's making money, then why stop it?
Personally I think those lucky people will have to connect in CLT, PHL etc. like everbody else, or SmithKline buy a shuttle aircraft it there demand is so high.
IMO, if companies such as these, just simply have to ship so many people to/from London (enough to justify a daily B777!!!), then they have their business model wrong  Wink
Jimbo
2travel2know
Fri Mar 31, 2006 11:26 pm
I definitely don't think that RDU will see CM any time soon....
Decent O&D traffic between RDU and PTY! I would have agreed with that before mid 1999, but now? I don't have enough info to agree or disagree on that.
The only way CM in RDU could work - if ever - is if
(1) RDU does have a good O&D traffic to CM destinations (but MEX via PTY is silly),
(2) those passengers don't wish to travel via ATL, IAD or MIA to those destinations avoiding the Port-of-Entry hassle at those airports, and
(3) don't mind that's a once a day only service.
But to many passengers disapproval, it would surely have to be on a E190.
I would add that this criteria would also apply if CM is to fly to MSY, just change IAD for IAH.
ERJ170
Fri Mar 31, 2006 11:29 pm
Quoting Bond007 (Reply 20):
They not only ship people, they ship cargo.. True the flight doesn't make as much money now as it did earlier, but I think the reason for that is because prices have risen. I'm pretty sure the subsidy amount has not decreased and though the cargo may have decreased some, I don't think it has decreased much. And with the glut of new International companies coming into RDU, I can see the cargo rebounding.
But it would be great is GSK had a hanger beside SAS's with a 777 or 767 in it. That would be cool.. with the big orange GSK pill on it.. Big grin
bond007
Fri Mar 31, 2006 11:34 pm
Quoting ERJ170 (Reply 22):
Perhaps, but again that doesn't justify a daily passenger B777 (obviosuly since AA may stop it). It might justify an extra Fedex/UPS flight.
Jimbo
ERJ170
Sat Apr 01, 2006 12:49 am
Quoting Bond007 (Reply 23):
Okay okay.. here ya go.
the Subsidy used to basically pay for the front of the plane. I think now, that the subsidy pays for most of it, with the change due to higher fuel cost and the such. The cargo basically pays for the rest. AA also uses the RDU flight as a back-up for their other LON flights. So therefore both above and below the floor are a part of the deal.
Quoting 2travel2know (Reply 21):
Beats me.. I checked the BTS data and it looked okay. I mean, it's not like 1,000/day or even 500/day.. Hell, it might not even be 200/day.. but it's more than most other Central/South American destinations (save probably Mexico).
No no.. I wasn't saying PTY via Mex. I wasn't even saying PTY. I wasn't even saying Copa..
I was saying either AM/MX regional airline or perhaps one of the start-ups could do a Mexico run..
ERJ170
Sat Apr 01, 2006 2:29 am
On another Note..
Actual Terminal Construction starts today! 2 years and counting before utilization...
I'm heading to RDU probably tomorrow to look at the big a' apron area since nothing is there right now.. Big grin
2travel2know
Mon Apr 03, 2006 9:16 am
Quoting ERJ170 (Reply 24):
What a pleasant surprise, RDU could probably support a daily E190 flight to CM's Hub of The Americas!
ERJ170
Mon Apr 03, 2006 9:26 am
Quoting 2travel2know (Reply 26):
LOL.. like I said.. I think RDU would do better with a flight to somewhere in Mexico first and foremost..
fxramper
Mon Apr 03, 2006 9:40 am
What kind of pax numbers are we gonna need to see at RDU to give them a international flight from LH or UA to FRA? I know the AA flight is charging GlaxoSmithKline a premium to send their employees back and forth.
2travel2know
Mon Apr 03, 2006 11:37 am
Quoting ERJ170 (Reply 27):
Yes, to CUN.
MAH4546
Mon Apr 03, 2006 5:58 pm
No, they most likely, make that most definitley, could not.
a.
