siromega
Could There Ever Be A 777-400?
Mon Apr 03, 2006 2:51 am
I was thinking with the demise of the 772 (at the hands if the 7810), would Boeing look at lengthening the 777 any more to a 777-400 model. The list of questions/problems I can think of are a mile long though...
Would it...
compete too closely with the 748?
end up like the 767-400 (not a lot of orders)?
be flyable (its looooong - structural strengthening, tailstrike issues, etc)?
DfwRevolution
RE: Could There Ever Be A 777-400?
Mon Apr 03, 2006 2:59 am
Quoting Siromega (Thread starter):
Yes, a purely conceptual trade study by Boeing showed an additional, minor stretch of the B777 is possible. Anything beyond a few meters though and logistic problems like ground manuvering become a challenge.
Would it...compete too closely with the 748?
Probably not, capacity of a B774 would likely be smaller than the B744, not to mention, Boeing would lose some payload/range.
Yes, which is why it's very unlikely such a model will be offered.
Consider that the thinner A346 is longer than the wider B773ER. The B777 tube is already more structurally efficent at these lengths than the Airbus fuselage, so weight would be manageable. "Flyability" wouldn't likely be impared, the B777LR has electronic FBW tail-strike protection.
All in all, Boeing only considered a B777 double stretch as a trade study. Almost no likelyhood of being launched in the next decade. Put it in the category of the B777-100, just not going to happen.
EMBQA
Mon Apr 03, 2006 3:09 am
Just because there is a 777-400.. dosn't mean it has to go longer. The 737-500 is shorter then the 737-300, -400..!!
flydreamliner
Mon Apr 03, 2006 4:01 am
Yeah, because the 777-200 is small enough it's little brother 787-10 is killing it off, so they should make a smaller 777?
a 255ft long 777 could happen. The 748f is 250ft long, they could do it. I don't know how much demand there is for it. The 777-300ER already has good capacity, range, and economics. It's not like they're under any pressure from A346.
"Let the world change you, and you can change the world"
kaitak744
Mon Apr 03, 2006 5:10 am
Well, isn't the 777 wing already maxed out on the 777-300ER? Aso, a heavier 777 would demand more wheels on the landing gear.
flydreamliner
Mon Apr 03, 2006 5:52 am
Quoting Kaitak744 (Reply 4):
Speaking purely hypothetically (because we all know no one wants 777-400), they could keep MTOW static between 777-300ER and a larger 777-400. They would lose range, and would have to find some weight saving measures, but then they wouldn't need stronger gear (just taller) and could keep the same wings and GE90's.
IcelandairMSP
Mon Apr 03, 2006 12:03 pm
As has been stated before, a further derivation of the current 777 is unlikely so I won't rehash that.
I think the 777-400 possible model that could see the light of day would be along the line of the 737NG line or each progressive 747. If, down the line, Boeing sees demand for replacement of, say, 773ERs, 772LRs, etc. I would guess it would be entirely possible to redesign the plane considerably without making a new plane altogether. I don't want to speculate because that's at least ten or twelve years down the road.
For now, I think Boeing has finalized its current lines and won't be working on any other derivations of the 747, 777, or 787. They have pretty much all of their bases covered as far as twin-aisle aircraft go. If you say twenty years is a pretty average lifespan for an aircraft to remain in a modern airline's fleet (obviously this isn't the exact average, but it's about that) then by the time most airlines have most of their 787s (2012-2015) then around 2030 it would be smart to have a new aircraft or derivative ready to replace them. As we all know, the enormous market for 737 size aircraft will be Boeing's main concern after the 787 is on the assembly line and will preoccupy their engineers for many years.
It's always fun to speculate about future aircraft, but I think any major widebody developments will come from Airbus. After all the uncertainty about the A350 and the future of the A340, there could be some major changes. But otherwise I don't expect much as I am SUCH an expert on aircraft design and economics.
Oykie
Mon Apr 03, 2006 5:57 pm
If you got the OEW down, by using more light weight material, you could achive more payload without a higher MTOW.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
DeltaWings
Mon Apr 03, 2006 11:27 pm
The next step up from the 773 in pax capacity is the 748. Anything else in between makes really no sense, as the slight increase/decrease in passengers will hardly make much of a difference, as these wide bodies are normally configured in a 2/3 class layout.
Remember, with wide bodies the gaps between each a/c size are alot bigger then with narrow bodies, since narrow bodies are quite often just configured in a one class layout. (The more pitch and first class/lie flat beds you have, the more you have to stretch the plane, to get a reasonable pax load difference)
Homer: Marge, it takes two to lie. One to lie and one to listen.
Johnny
Tue Apr 04, 2006 12:15 am
I think the B777-400 is only possible if the B748i will have NO sales.
This could happen because nearly all airlines which are looking to replace their B744´s are B777-customers or A346/388-customers.
It is not a must order situation for Boeing.All airlines which are looking to replace their B744-fleet have far more options than 20 years ago when the B744 was the only replacement for the B743 and B742.
Probably at years end we all know more about the B748i´s airlines acceptance.
I am VERY,VERY surprised that there are still no orders for the pax-versions...
Probably time to develope someting new - not only warmed up!!!
zvezda
Tue Apr 04, 2006 12:34 am
The other option is to increase the diameter of the wheels and tyres. Eight wheel bogeys are probably not a good option. Adding additional bogeys would require a significant wing redesign.
Anyway, Boeing considered a B777-400X and the B747-8 as either/or choices. The launch of the latter probably foreclosed forever any possibility of the former. A B787-11X is far, far more likely than a B777-400X.
