KarlB737
FAA Blocks Runway Option At FLL, Reopening Debate
Sat Apr 08, 2006 4:22 am
Courtesy: South Florida Sun-Sentinel
FAA Blocks Runway Option At FLL, Reopening Controversy
http://www.airportbusiness.com/artic.../article.jsp?siteSection=1&id=6053
MaverickM11
RE: FAA Blocks Runway Option At FLL, Reopening Debate
Sat Apr 08, 2006 4:27 am
What's wrong with just widening and extending the southern runway a bit? It's a no-brainer, lawsuits aside.
E pur si muove -Galileo
dnl65
Sat Apr 08, 2006 4:47 am
as usual the press has it just a tiny bit wrong. The alternative that was rejected, was the bright idea of one of the county commissioners who fancy themselves experts in all subjects particularly aviation. The proposed alternate was vastly more expensive, would have required relocation of a power station that provides about 25% of the power to Broward County and would not have had any benefits from an aviation standpoint. The FAA is studyng a multitude of alternatives at FLL an no decision has yet been made on any of these.
jetpixx
Sat Apr 08, 2006 5:20 am
This is my home airport - even more so if I move from Delray Beach to Fort Lauderdale in July. Lately, I have found myself paying even a little bit more to fly out of PBI because the security lines have been increasingly worse and the wait in line getting ready to takeoff gets worse and worse at FLL. They desperately need a second runway to handle all of the traffic. Luckily, it will be summer and a lot of flights will end for the season, but the cruisers will still be coming.
I hope this issue is resolved soon. I realize that this cannot happen overnight, but they've been jerking around with this for years. That whole Melaleuca Gardens place needs to be destroyed. I am so tired of those whiners - who mostly moved in AFTER the place was built in the first place - complaining about noise. You moved near an airport - what did you expect?
lehpron
Sat Apr 08, 2006 5:36 am
From article:
In a memo sent to county commissioners Tuesday, the FAA said the option would have required the Florida East Coast railroad tracks to be realigned in a way that either reduced how fast trains could travel or required the destruction of a large portion of Dania Beach's business district.
While the latter seems to echo San Diego's problem, the forwards got me thinking. Which travel service will priority or can be more efficient when the "if you build it they will come" circumstances occur?
I mean, if the airport expanded, it could support more traffic. If the rail lines were left alone, while their traffic may not change, they will not loose any to a runway.
Maybe expanding the airport isn't the solution if most of the traffic that the airport is being expanded for domestic. Maybe some of the projected traffic can go through a rail system , not necessarily whatever exists now. But if it was a frieght line, forget it, they fly.  Wink
[Edited 2006-04-07 22:39:58]
KFLLCFII
Sat Apr 08, 2006 5:45 am
Apr. 5--The Federal Aviation Administration has ruled out an option for building a second major runway at Fort Lauderdale-Hollywood International Airport that some county officials had hoped could resolve years of turmoil over the airport's expansion.
FLL already has a second major runway, and it's called 13/31. If the county is seriously looking to resolve years of turmoil over the airport's expansion, then they'd get off the FAA's case for using it, as a start.
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
Boeing7E7
Sat Apr 08, 2006 5:53 am
Quoting Lehpron (Reply 4):
It's all about cost benefit, and you're right on the San Diego issue. Even if MCRD were to close, the capacity enhancment is so minimal that you can't effectively recoupe the cost of gaining that capacity. Same issue with a site that would be far too remote, like a desert. Or expansion of Lindberghs runway that would wipe out the NTC development, or expansion that would wipe out the Midway District.
[Edited 2006-04-07 22:59:48]
Slovacek747
Sat Apr 08, 2006 8:05 am
The stupid tree huggin hippies need to be thrown out of the FLL area so that the runway can be extended. Who gives a flying flip the "environmental issues".. People need to put those aside and build or extend a runway. People come BEFORE animals or anything else. Keep it real FLL
Slovacek747
lehpron
Sat Apr 08, 2006 6:03 pm
Quoting Boeing7E7 (Reply 6):
Except I don't think we can put research dollars in finding better ways of utilizing our railway system -- unless we invest in maglevs, then we might as well have our airport in the middle of nowhere.
I'd figure, forgive any ignorance since I've never been to Florida, buiding another concrete countryside in an environmentally protected area complicates things.
Quoting Slovacek747 (Reply 7):
I do.
USADreamliner
Sat Apr 08, 2006 11:39 pm
In that case, why don't we burn the everglades and build a mega-airport?Don't you think?
Who's going to complaint? the alligators?
USADreamliner
Just in case, that was sarcasm.
MAH4546
Sat Apr 08, 2006 11:54 pm
With MIA to the south and PBI to the north, both with arguably better security lines and less delays, and neither anywhere near capacity, there is no reason to do anything drastic. It isn't as if FLL is the only airport in town. If it were, then drastic measure shoudl be considered.
a.
par13del
Sun Apr 09, 2006 12:38 am
I admit FLL is getting much more traffic, presently its our gateway of choice into the MIA/FLL area. Loking at some google searches about runway 13/31, its shorter but just as wide. Anyone know what the FAA and local issues are with more utility of this runway?
NADC10Fan
Sun Apr 09, 2006 4:09 am
While I certainly agree that the environmental concerns which have been thrown up as a roadblock to FLL's expansion are waaaaaaaaaay overblown, still, there are limits.
I remember Dade-Collier, and its scotching wasn't unreasonable considering it was an attempt to do just exactly what USADreamliner suggested - raze a portion of the Everglades for a big airport. Considering their importance to the existence of any community on the east coast of Florida, the Everglades do need to be preserved from that sort of thing. Meaning I for one will never support putting an airport out there.
So environmental issues are of concern. But this is an entirely and drastically different thing from what's happening at FLL.
Quoting MAH4546 (Reply 10):
No, FLL isn't the only airport in the area ... but MIA is ridiculously overcrowded and expensive and no fun to travel out of, and PBI is 80 miles north - quite the haul with no good rail link other than Tri-Rail (which is not an option I'm terribly enamoured of trying to use to get to the airport - although I may be staring at that very prospect).
Also, I've dealt with FLL's security a good deal over the past year, and it's been very reasonable - even more so if you travel smart. People talk about nightmares, but I have never seen that to be the case. Of course, I'm also not showing up for my flight only a half hour before it departs, either ...  razz
Also, the level of flight delays has decreased significantly thanks to excellent work done by the FAA in redesigning routings into and out of FLL. While by no means a perfect situation, one cannot argue the improvements travel in and out has seen.
Quoting Par13del (Reply 11):
I admit FLL is getting much more traffic, presently its our gateway of choice into the MIA/FLL area. Looking at some google searches about runway 13/31, its shorter but just as wide. Anyone know what the FAA and local issues are with more utility of this runway?
The city of Dania Beach, specifically, is the overwhelming problem.  hissyfit  Takeoffs lift right over the top of the city, and they want nothing to do with that. There are already issues with the operation of the southern runway just as it is, and the neighborhoods there and Dania Beach in general have a loud history of reacting to that. OK'ing expanded use of 13/31 would probably put them through the ceiling.  hot
Of course, I don't much sympathize with those complaints. That airport's been in existance well previous to most parts of all the communities surrounding it, and it doesn't take knowledge of rocket science to realize that an airport is not and never will be a 'good' neighbor for that sort of thing. If you purchase by it, for whatever reason, you had better be willing to put up with the incoveniences that will attend. IMO the south runway is the only truly viable option, and should be expanded and lengthened. Unfortunately, politics of stupidity will likely prevent it from happening the way it needs to.  knockout
TANSTAAFL!
MAH4546
Mon Apr 10, 2006 4:23 am
Quoting NADC10Fan (Reply 12):
Overcrowded? Since when? The airport has the capacity to handle about 50% more traffic then it currently does. It is far from overcrowded, especially if you aren't fly AA, since the non-AA terminals are lightly used.
And the air fare difference is nothing what it used to, as AA frequently matches fares from FLL on jetBlue and Southwest (intra-Florida) and implenented a new, simpler, more affordable domestic airfare structure in 2004.
80 miles north of Key Largo. It is about 45 miles from Dania Beach and in normal traffic less than an hour drive.
a.
Boeing7E7
Mon Apr 10, 2006 4:52 am
Airport planning went green several years ago. Where have you been?
Quoting Lehpron (Reply 8):
It's going to be Miramar. Not if, but when. Maybe not this year, but give it 10 when congestion at Lindbergh is visible and the Military can't justify the cost of keeping it. It'll come. The desert it simply far too remote, and has even greater airspace issues. Approach lineups would start near Phoenix to avoid the MOA around Yuma. Here's the deal on the military... They suggested they'd give up their Yuma operation and move it all to Miramar to support a Desert airport with Maglev running from Yuma to San Diego. Someone needs to stop smoking crack in the Department of the Navy.
Quoting MAH4546 (Reply 13):
False. They operate at or near their IFR peak most of the day. This leaves little to no room for margin of error.
[Edited 2006-04-09 22:01:57]
NADC10Fan
Mon Apr 10, 2006 10:39 am
Okay ...
Hm. I also see what 7E7 had to say, which was my experience.
Did a quick search and MIA was more expensive in roughly 70% of them. The largest difference was roughly $50. Most, granted, were closer. But even if airlines only match fares, when you combine that with the FLL's convenience locality-wise for most Broward residents, MIA doesn't compete well.
Should've Google Local'ed it to begin with. My bad, and I apologize.
Even so, I'll split the difference with you. It's roughly 60 miles from where I live (western burbs of Fort Lauderdale) to PBI, whereas FLL is 17. (50 from Dania Beach to PBI, btw ... and 129 from Key Largo!)
But we're also talking SoFla. Normal traffic is 'good' and travel fairly reasonable only at the best of times. That's a fairly narrow range of hours. If you have to go to PBI you need to book at least 60-90 minutes - try to do it in less and you're only courting disaster.
Again, it's an issue of convenience. And from Central Broward County, PBI has to fight to be that way with FLL right there.
TANSTAAFL!
