afrikaskyes
Embraer 145 Pushback By Hand.
Sat Apr 08, 2006 5:11 am
Me and 5 other rampers just pushed an ERJ back using some muscle. When a jetbridge fails and there is no towbar available, go get 5 other guys and you're good to go! Piece of cake!
KAUSpilot
RE: Embraer 145 Pushback By Hand.
Sat Apr 08, 2006 5:18 am
Out of curiosity, where did you grab it when you were pushing it back? The leadiing edge of the wings?
airtran737
Sat Apr 08, 2006 5:28 am
I've had to do that with a B1900 before. You have to be resourceful sometimes, and that was a good way to avoid taking a delay.
Nice Trip Report!!! Great Pics, thanks for posting!!!! B747Forever
sllevin
Sat Apr 08, 2006 5:35 am
That's a solid push, that's for sure. Three of us used to push a Citation 500 every once in a while (which is like 1/4 the weight) and it was a workout, especially against a slight incline!
Steve
SLUAviator
Sat Apr 08, 2006 6:30 am
I hand pushed a J-41 with a couple other guys once.
Nice work with the 145.
What do I know? I just fly 'em.......
N766UA
Sat Apr 08, 2006 6:33 am
You must work at a pretty small airport, huh?
This Website Censors Me
thegooddoctor
Sat Apr 08, 2006 6:35 am
Quoting Afrikaskyes (Thread starter):
That had to have been entertaining for the passengers! I'm assuming the pilot was nice enough not to spool the engines until after pushback?
-S
The GoodDoctor
DLX737200
Sat Apr 08, 2006 6:40 am
Is the ERJ-145 capable of reversing from the gate under its own power? I know this has been done on other aircraft like the DC-9 and MD-80.
-Justin
loggat
Sat Apr 08, 2006 6:51 am
Capable, yes....
Intelligent, NO
The engines are too low to the ground that FOD ingestion becomes a factor. Most operators prohibit it (well, at least the 2 airlines I've flown it with).
Nice job on the hand push, that's about 8000lbs per person.
There are 3 types of people in this world, those that can count, and those that can't.
ILOVEA340
Sat Apr 08, 2006 6:59 am
Quoting Loggat (Reply 11):
And using a relatively normal friction coefficient of Ruber on a relatively low friction surface (concrete) that still probably around 200-250lbs per person!
Well done!
Confuscius
Sat Apr 08, 2006 7:01 am
Which one are you in this picture?  Wink
Ain't I a stinker?
wannabe
Sat Apr 08, 2006 7:05 am
Which one of you wore the towbar?
BDL2DCA
Sat Apr 08, 2006 11:00 am
I want pics!
filler
filler
146,319,320,321,333,343,722,732,733,734,735,73G,738,744,752,762,763,772,ARJ,BE1,CRJ,D9S,D10,DH8,ERJ,E70,F100,S80
MGASJO
Sat Apr 08, 2006 11:05 am
I saw it once in SJO with a MX F100. It took about 8 guys. Very nice to see if you're not pushing!
C208B
works4boeing
Sat Apr 08, 2006 11:11 am
That's a positive, can do attitude. How many guys would it take to push back an A380?  Smile
airtran737
Sat Apr 08, 2006 11:14 am
Quoting DLX737200 (Reply 10):
I'm sure it is, but it may not be in the ops specs for the particular airline that this airplane belongs to.
LeonB1985
Sat Apr 08, 2006 11:33 am
I know of three guys who pushed a Dornier 328 once. Quite difficult, I believe, as obviously you can't grab the wings to push!
From the construction site that is better-known as London Heathrow Airport
raventom
Sat Apr 08, 2006 5:56 pm
Didn't some beef guy pull a 747 once? I'm sure i saw it on TV once. Once they get it rolling it should be easy.
I love the smell of burnt kerosene!!!!!!!!!!!!
pawsleykat
Sat Apr 08, 2006 6:36 pm
Quoting Raventom (Reply 17):
It was a Guinness World Record in the 2005 book. Some guy pulled Qantas' 'Wunala Dreaming' plane like 140m @ the QANTAS base in SYD. It was pretty cool, but he was like the world's 2nd strongest man and he looked like the HULK with all those muscles, but yes it did happen  Wow!
JG
AndersNilsson
Sat Apr 08, 2006 6:52 pm
I'm happy to have pushed an empty Swiss Learjet 35A at my local airport together with the planes two pilots in the nineties.
Anders
Airliner photography is not a crime.
raventom
Sat Apr 08, 2006 7:48 pm
Quoting Pawsleykat (Reply 18):
Imagine all the tow drivers and baggage handlers like that... lol
nwab787techops
Sat Apr 08, 2006 9:14 pm
Quoting AirTran737 (Reply 15):
If the emb 145 has T/R's, you can power back.
Gr8Circle
Sat Apr 08, 2006 9:53 pm
Quoting AndersNilsson (Reply 19):
Both the pilots were over 90 years old ?? Big grin
peachair
Sat Apr 08, 2006 10:18 pm
We had to do this at MCO with a B727 back in the mid-1990's. We had acquired some ex-Eastern 727's for the Shuttle and they required a non-standard towbar head which usually traveled with the aircraft. The aircraft arrived without the towbar head and nobody noticed until the aircraft was ready to push. It was a weekend flight going back to LGA.
I recall it took about 16 ramp agents to push the aircraft back. - main gears, fuselage gear doors. It was a sight to behold. I would have photographed it if I could have.
Devilfish
Sat Apr 08, 2006 10:22 pm
Quoting Gr8Circle (Reply 22):
That one is funny!!!  Big grin
pilotaydin
Sat Apr 08, 2006 10:29 pm
Quoting KAUSpilot (Reply 1):
almost sounds erotic lol
The only time there is too much fuel onboard, is when you're on fire!
airtran737
Sat Apr 08, 2006 11:49 pm
Quoting Nwab787techops (Reply 21):
Just because an airplane has something doesn't mean you can use it. Take NW, YX and FL for example. The all have members of the MD-80/717 family. NW and FL have a set powerback procedure in their ops manual that has been approved by the FAA. YX has the same type of of aircraft, but since they have not gotten powerbacks approved by the FAA they are not allowed to do them. Doing a non approved procedure is a good way to lose your job, and also get a sizable fine for the company. So once again, just because this airline has T/R's on their 145's it doesn't mean that they are allowed to do a powerback.
Also, some airports have a strict policy that may forbid powerbacks.
AviationAddict
Sat Apr 08, 2006 11:57 pm
Let's be serious now! What's your idea of easy?!? I imagine that dude was sore after that little adventure, even if he was the Hulk!
SkyexRamper
Sun Apr 09, 2006 12:22 am
Quoting AirTran737 (Reply 2):
Me too AT737.  Big grin Spot 14 had a Mx delay blocking spot 12 from leaving.
Good Luck to all Skyway Pilots! It's been great working with you!
aogdesk
Sun Apr 09, 2006 12:35 am
Yeah, well this one time at band camp I had to tow a B757 all by myself by hand across the active.  Wink
Georgetown
Sun Apr 09, 2006 12:57 am
Quoting Wannabe (Reply 11):
Best A.net quote in a while!
Let's go Hoyas!
AviationAddict
Sun Apr 09, 2006 1:24 am
Quoting Aogdesk (Reply 29):
You might have an idea for another sequel "American Airport"
litz
Sun Apr 09, 2006 2:18 am
Quoting AirTran737 (Reply 26):
Also - an EMB145 (like any regional jet) has engines very low to the ground, compared to a 727, DC9, MD80, or 717 ... this vastly increases your FOD danger.
They could well be fully licensed and approved for powerbacks, but didn't want to take the chance on FOD. Much safer to just get a bunch of guys to push you.
- litz
Gilligan
Sun Apr 09, 2006 2:29 am
A friend of mine that works at SAT told me that on occasion they have had to pushback several types of aircraft, Boeing, MD's, and ERJ's. Evidently the ramp slopes away from the terminal at a very slight grade so once they get it going it's not too tough to keep the momentum up.
Warm winds blowing, heating blue skies, and a road that goes forever, I'm going to Texas!
Sun Apr 09, 2006 5:15 am
Quoting DLX737200 (Reply 7):
Many ERJs are not equipped with R/T. But if they are I suppose it's theoretically possible.
Quoting Works4boeing (Reply 14):
Unlike the ERJ, you can't push against the wings, but I suppose there are plenty of wheels to grab.
raventom
Sun Apr 09, 2006 5:37 am
Quoting AviationAddict (Reply 27):
Momentum :S Let me rephrase just for you... easier.
PGV
Sun Apr 09, 2006 5:54 am
Yup. Biggest reason for no powerback allowed is because of debris that can be picked up and thrown into pitot, static ports, etc. which can make life real interesting about halfway through a T/O roll. It's common on the rear engines because they are high and less likely to pick ground debris up. If you notice, they'll never do powerback on the 9's at DTW when there is snow on the ground.
I did see a 742 execute a 3-point turn one time...but that was at Kuwait during Gulf War I when a scud had just hit the city. The tower told him to get out of that end of the airport. Unfortunately they were boxed in...so the boys wasted no time doing what needed to be done, and got the hell out fast!
"To hell with a Ferrari...give me a Super 70!"
