ripcordd
Vanguard 737 At ORD
Sat Jun 10, 2000 2:50 am
Anyone know why a 737 vvanguard was at ORD on 6-8-00 at about 900pm....?????it was loaded with passengers......I seen it on a taxiway
Brick
RE: Vanguard 737 At ORD
Sat Jun 10, 2000 3:18 am
In flight emergency? Medical emergency on board? MDW diversion?
There are a number of possibilities...
Mark Abbott
Minneapolis, MN
A noble spirit embiggens the smallest man...
OPNLguy
Sat Jun 10, 2000 6:20 am
I looked at the weather from MDW yesterday, and as it was clear all day, it sure doesn't appear to be a weather diversion.
Most likely, it was some type of mechanical problem (hydraulic system failure, engine shutdown, unsafe gear indication, etc.) that was incompatabile with MDW's rather short runways. Some 737-200 mechanical problems require the use flaps-15 for landings, and that setting requires faster landings speeds, and thus more runway, which MDW doesn't have.
Another possibility is that (assuming Vanguard even serves ORD) was that a MDW flight "flag-stopped" ORD to pick-up passengers from another Vanguard flight that had mechanical problems. It does happen, but again, that assumes that in this case that Vanguard serves ORD.
goingboeing
Sat Jun 10, 2000 6:53 am
Vanguard doesn't serve ORD. But, it COULD have been a charter.
OPNLguy, just curious, do you work for LUV?
TWFirst
RE: OPNLguy
Sat Jun 10, 2000 6:55 am
Nope, Vanguard doesn't serve ORD. In fact, MDW is as big as MCI for them in terms of operations, so I'd bet on your first thoughts.
An unexamined life isn't worth living.
OPNLguy
Goingboeing
Sat Jun 10, 2000 10:50 pm
Yep, a charter is certainly another possibility...
I work for that airline HQ'd in Texas that flies 737s.
Houston? Ft. Worth? Dallas? Geez, I'm lost again...
