airplanekid101
Where Do You Find Live ATC Commuication?
Fri Apr 14, 2006 10:40 am
Hey!!
i was just wondering.. what are some sights that you can go to to get live ATC commuication?
Thanks!!
NICK
Nick K. Appleton, Wisconsin KATW
ERJ170
RE: Where Do You Find Live ATC Commuication?
Fri Apr 14, 2006 10:45 am
Observation deck at RDU.. they play the ATC while you spot..
Aiming High and going far..
harrisair
Fri Apr 14, 2006 10:54 am
check out www.liveatc.net
futuresdpdcop
Fri Apr 14, 2006 12:30 pm
LAS (Vegas) has a spot on the south side of the field where you can pull up in a parking lot and set your radio to an FM station to listen in on live ATC.
As posted above, I use Liveatc.net also
[Edited 2006-04-14 05:50:50]
superhub
Fri Apr 14, 2006 12:34 pm
Quoting Airplanekid101 (Thread starter):
As a sidenote, you will not be able to get any ATC communications from any UK airports. Apparently it's illegal to broadcast them.
UAL747
Fri Apr 14, 2006 12:41 pm
All you have to do is a Google search for "Live ATC" and several sites will come up, including the afore mentioned, www.liveatc.com , which happens to be a really good one.
UAL
LH492
Fri Apr 14, 2006 5:12 pm
Book a flight with United Airlines and you will have live ATC on channel 9  bigthumbsup
Carpe Diem, Seize The Day
flyingfool
Fri Apr 14, 2006 5:23 pm
For The Netherlands:
http://www.atcbox.com
utapao
Fri Apr 14, 2006 8:57 pm
Quoting UAL747 (Reply 5):
www.liveatc.com
Just a slight correction... as HarrisAir mentioned, it is liveatc.NET. The .com site is just a search/link page.
Sawasdee khrab!
spikebe90
Fri Apr 14, 2006 11:53 pm
Try ATCMONITOR.com Covers ATL approach comm,radar,and center comm and radar
keep it in the middle of the road
boeingfanyyz
Sat Apr 15, 2006 12:07 am
As mentioned, you can use any of those sites. But, those are only for amateur spotters!
If you're a REAL spotter, you will have your own Air Band Reciever (scanner) which allows you to control which freq you go on, and it is very portable compared to a computer. BTW, could you just see someone pull up at a spotting place at an airport with their computer!?!?!?
Boeingfanyyz  airplane
"If it aint boeing, it aint going!", "Friends are like condoms...they protect you when things get hard!"
PVD757
Sat Apr 15, 2006 12:57 am
http://www.pvdairport.com/tower/tower.asx
PVD has this link to listen to the PVD tower...
lat41
Sat Apr 15, 2006 10:20 pm
To get the whole "picture" If you find, not only tower, but ground control, approach and departure control(s) you can follow the flight in or out. Just listen to the assigned frequencies as the flights are handed off and program them in. There will be several at an airport that is busy enough. You can even go as far as the in route center that they are handed off to (after appx. 10K ft), if you scanner is sensitive enough. Again there will be more than one. Eventually, you will have the whole thing built in.
