od-bwh
Can An Aircraft Turn While Landing?
Fri Apr 14, 2006 8:05 pm
Hello,
I know (and correct me if i'm wrong) that the outermost airleron on the wing is used as a flap in landing!! If so, can an aircraft make hard turns while flaps are fully deployed? I guess aircraft make their final turn and align with the runway before deploying the flaps. Is it correct?
Thanks anyways
OD-BWH
A300, A319, A320, A321, A332, A333, A343, A346, A388, B734, B738, B744, B772, B773, B788, F70, MD11, CRJ7, CRJ2, Q400, MD82, MD83
fr8mech
RE: Can An Aircraft Turn While Landing?
Fri Apr 14, 2006 8:21 pm
Only certain aircraft have ailerons that deflect with the flaps. Those ailerons still act as ailerons. Most aircraft that have both outerboard and inboard ailerons restrict the travel and/or usage of the outboard ailerons at high speed and give full authority at low speed. So to answer your question, yes the aircraft can turn while landing.
RichardPrice
Fri Apr 14, 2006 8:25 pm
Quoting OD-BWH (Thread starter):
Hello,
Take a look at the Kunazi (sp?) approach to JFK, its a long sweeping curved approach to miss some noise abatement areas at the end of the runway, and involves very little straight flight during the approach.
ANCFlyer
Fri Apr 14, 2006 8:28 pm
Fly the River Visual approach into DCA for Rwy 19 and that'll answer it for you!
http://204.108.4.16/d-tpp/0603/00443RIVER_VIS19.PDF
TheSorcerer
Fri Apr 14, 2006 8:29 pm
Which A/C have ailerons that are used as flaps in landing?
thanks
Dominic
ALITALIA,All Landings In Torino, All Luggage In Athens ;)
NAV20
Fri Apr 14, 2006 8:31 pm
OD-BWH, all the control surfaces are in use all the time when landing. The aeroplane wouldn't stay on line (or on the correct glidepath) for a moment if they weren't.
"Once you have flown, you will walk the earth with your eyes turned skywards.." - Leonardo da Vinci
Sat Apr 15, 2006 3:04 am
What Type are you reffering to.
regds
MEL
fr8mech
Sat Apr 15, 2006 3:18 am
Quoting TheSorcerer (Reply 4):
They are not used as flaps. Their nuetral position is reset to a drooped condition which acts as a continuation of the flap. The aileron still acts as an aileron and responds to flight deck inputs appropriately.
The only 2 types I know about are the MD11 and A300. Though I'm sure juat about any of the newer airframe types have this feature.
nudelhirsch
Sat Apr 15, 2006 3:23 am
Quoting RichardPrice (Reply 2):
That would be the Canarsie one, or Parkway Visual for 13 L/R as the official name is.
Link:
http://www.myairplane.com/databases/...oach/pdfs/00610PARKWAY_VIS13LR.PDF
Putana da Seatbeltz!
Coronado990
Sat Apr 15, 2006 4:37 am
The old Kai Tak gave you full flap turns 9 seconds prior to landing every time...
Photo © Simon Wong
Uncle SAN at your service!
