sonic67
Strange Aircraft Accidents
Sat Apr 15, 2006 2:37 pm
The reason for this post is to discuses other things than the usual A vs B nonsense. The criteria for this post are unusual or strange civil aviation accidents that no one was killed. If you have any insight on the incident please tell. I have a few examples below.
Thanks in advance
Square peg
U-boat
Photo © Weimeng
Photo © Colin T. Ebert
Markhkg
Sat Apr 15, 2006 3:17 pm
Quoting Sonic67 (Thread starter):
Just so you know, the second picture...the "U-Boat"...was the crash of a Garuda Indonesia B737, registration PK-GWA, and a flight attendant actually drowned during the incident. So not actually an incident where no one was killed...
F9Animal
Sat Apr 15, 2006 6:35 pm
If you want to scratch your head..... Go to SEA and check out the ramp operation at Alaska. Menzies has a wonderful record of hitting planes out there. I think they have passed the 20 mark by now!
The Eskimo is rumored to be getting a helmet to protect his head from the impacts.
I Am A Different Animal!!
rolfen
Sat Apr 15, 2006 7:25 pm
Langing gear retracted while on ground:
Photo © Elizabeth
Loading in an improper way:
Photo © Dayot Jean-Charles
There was also a thread with pics of a jet that slammed into a jetway. There was damage to the airframe and the jet got totalled. I think it was being taxied by ground crew and they couldnt stop because they had not activated the right hydraulic circuits for the brakes or something like that. The jetway got damaged pretty bad too. I cant find this thread anymore, though.
rolf
cedarjet
Sat Apr 15, 2006 8:29 pm
My favourite (although it might be apocryphal) is the story of the tug driver who carefully backed a 727 into a hangar, the hangar doors were closed enough so that the tug could just fit through the opening, and the driver duly put it into forward gear and drove through the gap in the doors. Unfortunately the seven-two was still attached and both wings were ripped off.
Never seen a photo so I don't know if it's true but I've heard the story a couple of times and it's always a seven-two. So maybe it's bona fide.
TheSorcerer
Sat Apr 15, 2006 10:12 pm
ALITALIA,All Landings In Torino, All Luggage In Athens ;)
A319XFW
Sat Apr 15, 2006 10:23 pm
Quoting Piercey (Reply 7):
Yes, but there have been weird AC accidents. Can anyone say Gimli Glider?
Ah yes, Gimli. The last time I was at the Icelandic Festival there, they had at least 2 sand sculptures of the 767!
Another strange incident was IIRC a NW BAE146, where 2 mx guys were playing with the throttles and the aircraft went straight into the terminal. Apparently they were using the engines from which the brakes weren't fed off!
But perhaps someone with a better memory can confirm this?
northstardc4m
Sat Apr 15, 2006 10:27 pm
Quoting A319XFW (Reply 8):
Actually that was a Continental MD-80, and its was cleaning staff not mechs as i recall.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
A319XFW
Sat Apr 15, 2006 10:42 pm
Quoting NorthStarDC4M (Reply 9):
No, there was a NW 146 that had it too. I have the pics somewhere on my work computer.
747ENG
Sat Apr 15, 2006 10:50 pm
Another strange incident that I did not actually witness but occurred in The Haj season in Jeddah around Feb 2000 I am pretty sure.
An Iran Air 747SP had pushed back during start. In rather a rush to taxi, it is alleged the aircraft without getting clearance to taxi from the ground crew, applied a lot of power and taxied with some force into the tug, causing one of the main gears (presumably the wing) to shear completely off, leaving it on the remaining 3. Apparently the Boeing repair team said that it (the gear) behaved exactly as it should have done and doing little other than superficial damage to the airframe apart from needing to replacing the gear and no doubt landing gear doors, hydaulic and electical looms. A repair of some 10 days or so ensued. I dont now the reg of the aircraft involved, but was seen with tail out of the back of one of Saudia's hangars. I have no independent confirmation of these alleged events.
Apparently the gear are designed to shear off when in contact with any solid object on the ground (or flight) without doing major damage to the spar attachments points and fittings
Anybody help ?
boeingfanyyz
Sun Apr 16, 2006 12:37 am
This is a strange one. What's strange about it, in my opinion, is how nobody was killed in this accident.
http://photos.airliners.net/photos/photos/7/3/5/1030537.jpg
Boeingfanyyz  airplane
"If it aint boeing, it aint going!", "Friends are like condoms...they protect you when things get hard!"
cedarjet
Sun Apr 16, 2006 1:27 am
BoeingfanYYZ, perhaps it is lucky no-one was killed in the accident you illustrate. However the entire cockpit crew suffered broken backs. Sorry cos it's such depressing information, but it does follow up your question.
rolfen
Sun Apr 16, 2006 5:11 am
Quoting Cedarjet (Reply 5):
I dont think a tug would be strong enough and have enough traction to rip off wings. Maybe just damage them.
rolf
sonic67
Sun Apr 16, 2006 5:45 am
Quoting MarkHKG (Reply 2):
You are correct but the flight attendant didn't drown because the plane flooded but while trying to exit the plane. But you are Right I probably should have left it out.
jorge1812
Sun Apr 16, 2006 5:46 am
Quoting Rolfen (Reply 4):
Don't think it's possible to retract the gear on ground. Think it collapsed due to a technical fault.
Georg
ua777222
Sun Apr 16, 2006 5:53 am
Quoting Jorge1812 (Reply 16):
Of course it is. Don't put the pins in the gear and you pull up you get a retracting gear. Now it probably wasn't a streight drop rather a tug forward due to the gear falling back and the aircraft falling forward.
Matt
Edit due to spelling error
[Edited 2006-04-15 23:08:25]
"It wasn't raining when Noah built the ark."
jorge1812
Sun Apr 16, 2006 5:57 am
Quoting UA777222 (Reply 17):
Of course it is. Don't put the pins in the gear and you pull up you get a reclining gear. Now it probably wasn't a streight drop rather a tug forward due to the gear falling back and the aircraft falling forward.
Matt
I learn some thing new every day.
Georg
sonic67
Sun Apr 16, 2006 6:11 am
Passengers aboard a flight from Cyprus said they thought their aircraft was about to crash as it was battered by giant hailstones in a freak weather pocket.
Link:
http://www.strangedangers.com/content/item/10136.html
boeingfanyyz
Sun Apr 16, 2006 7:00 am
Quoting Boeingfanyyz (Reply 12):
Umm, where's the question....?  wink
YYZflyer
Sun Apr 16, 2006 7:01 am
Photo © Chuck Slusarczyk Jr. - OPShots
Photo © Jeffwell
Photo © Jeffwell
 airplane
Avoid hangovers, stay drunk.
LPLAspotter
Sun Apr 16, 2006 7:40 am
I remember when living in PNI Air Nauru had to cease operations for 1 month as a loader rammed the infamous VH-RON with a forklift. Pilots from Australia had to ferry the aircraft unpressurized to Oz to have it fixed. Air Nauru's has had only one plane (now zero) for a long time.
LPLAspotter
Nuke the Gay Wales for Christ
amciver
RE: Strange Aircraft Accidents
Sun Apr 16, 2006 9:38 am
QF1 in 1999 managed a near hole in one, I had been on the flight a week earlier:
http://www.airdisaster.com/photos/qf1/3.shtml
TheRedBaron
Sun Apr 16, 2006 9:48 am
A varig Cargo MD 11 or DC10 was inproperly unloded last week at MEX and the tail struck the pavement..... darn I cant find a pic....
The best seat in a Plane is the Jumpseat.
jbguller
Sun Apr 16, 2006 10:26 am
Quoting Amciver (Reply 21):
Oh and what luck to see the emergency slide on a tree!! Hopefully noone tried to use that exit - long way down!
litz
Sun Apr 16, 2006 10:50 am
Quoting Jbguller (Reply 23):
Check out the 2nd picture in that series ... if there's a piece of metal on that wing that can stick into the wind for stopping purposes - it is ...
TR's aren't deployed though, maybe they were stowed during shutdown, dunno.
Amazing that thing's in as good shape as it is, considering it basically went sledding down a golf course ...
- litz
Markhkg
Sun Apr 16, 2006 11:51 am
The door wasn't used during the evacuation. They were opened by gound crew after the evacuation sequence.
GG604CGAUN
Sun Apr 16, 2006 1:07 pm
I was near when this bird landed never seen one land quite so quiet again AC 604 C-GAUN still in the air today!!  wave
Big version: Width: 1280 Height: 960 File size: 331kb
Air Canada 604 C-GAUN AKA GIMLI GLIDER still flying today!
thirty thousand feet is where I go to get High!!
Gatorman96
Sun Apr 16, 2006 1:17 pm
http://photos.airliners.net/photos/photos/8/6/9/0841968.jpg
Lost nosewheel turning capabilities due to hydraulic failure...
sonic67
Sun Apr 16, 2006 3:44 pm
Some more Photos:
I stumble across this photo by accident anyone have any info on why the door was opene and who the Carrier is?
http://home.pacbell.net/gjstreit//greg/oops8.jpg
Photo © Jacques Lienard
Stork struck this aircraft
Photo © Daniel R. D'herbe - Iberian Spotters
Did the tail actually strike the runway?
Photo © Thomas Luethi
jorge1812
Sun Apr 16, 2006 7:26 pm
Quoting Sonic67 (Reply 28):
who the Carrier is
Tampa I think.
Yes.
Georg
FlySSC
Sun Apr 16, 2006 7:57 pm
AF A320 F-GFKB. Gear colapsed at CDG
Photo © Philippe Noret - AirTeamimages
SU IL-62 "meeting" Asiana B744 at ANC
Photo © Jack D. Glover
AC B744M at ORY ...
Cameroon Airline B747, ending its landing in the mud at CDG
Photo © Marc Delarue
AF A342 F-GNIA, destroyed by fire in a hangar during maintenance.
Photo © Guido Latz
tribird1011
Mon Apr 17, 2006 9:27 am
Quoting FlySSC (Reply 30):
I believe that it should be "Asiana B744 meets IL-62" as I believe the B744 was actually taxiing away, while the IL-62 was just parked.
I know I read that somewhere- not too sure where though...
Mon Apr 17, 2006 2:10 pm
Photo © JetPix
regds
MEL
FlySSC
Mon Apr 17, 2006 4:26 pm
Quoting Tribird1011 (Reply 31):
You are right. The Il-62 was parked.
http://www.airdisaster.com/cgi-bin/v...te=11111998®=HL7414&airline=Asiana
