ATLIEN
Delta Connection To Fly Out Of Concourse B In ATL
Tue Apr 18, 2006 12:03 pm
Gate B-19 and B-20 are being converted to handle Delta Connection flights. The flights will begin next month and there will be roughly ten flights a day out of each gate. B-19 has been closed ever since the 727 went out of service, and B-20 currently only handles the 737-200.
deltagator
RE: Delta Connection To Fly Out Of Concourse B In ATL
Tue Apr 18, 2006 12:23 pm
These are both right by the Spine aren't they?
Quoting ATLIEN (Thread starter):
Really? Never paid attention to it in all the times I walk past it. You would think they could shoehorn something in there given the decent wingspan of the 727.
DeltaSFO
Tue Apr 18, 2006 12:25 pm
Quoting DeltaGator (Reply 1):
Yes.
It's a new day. Every moment matters. Now, more than ever.
deltairlines
Tue Apr 18, 2006 12:28 pm
Quoting DeltaSFO (Reply 2):
Never noticed B-19 wasn't used either...then again, I'm probably mixing it up with A-19, which I seem to use way too often (along with A-10 and D-36...I just arrived into A-19 last night). Still, it's going to be a little strange seeing the regionals mixed in with the big boys in ATL...will it be Chautauqua using these gates or the mix of Comair/ASA like in D?
Jeff
N1120A
Tue Apr 18, 2006 12:36 pm
Wing location and the larger rake helped the 727 fit into tight spots.
USPIT10L
Tue Apr 18, 2006 12:40 pm
They've got to be nuts! ATL's so crowded now, I'd hate to be able to remember what the OLD terminal was like!
It's a Great Day for Hockey!
ATLIEN
Tue Apr 18, 2006 12:57 pm
Quoting DeltAirlines (Reply 3):
I think it might be just Chautauqua as of right now.
AV8AJET
Tue Apr 18, 2006 2:30 pm
Or it could be Shuttle America with the E-170's. I think they are starting some flights out of ATL, hence the need for jetways which the C and D gates would not be able to accomadate.
"To fly or not to fly there is no question!"
DL763DFW
Tue Apr 18, 2006 2:54 pm
Talking to the supervisor in charge of the effected zones, he said it would be only Chatauqua as of right now. Also, it'll be DL employees working them... not ASA or anyone else. It ought to be interesting to see!
DAL767400ER
Tue Apr 18, 2006 5:28 pm
Will indeed be an unusual site, but if ATL has two empty gates that can't handle mainline planes but are idea for RJs, why not use them? After all, ATL is trying to do everything to add new gates (or in this case reactivate them) to increase capacity, seeing as how they won't be adding any new terminals soon.
dalb777
Wed Apr 19, 2006 12:17 am
Quoting N1120A (Reply 4):
Does an MD-88 have a greater wingspan than a 727?
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
FlyDeltaJets
Wed Apr 19, 2006 12:22 am
Quoting DL763DFW (Reply 8):
What's so interesting about that. Every where else with the exception of CVG and SLC, its DL employees that handle the DCI flights.
The only valid opinions are those based in facts
SESGDL
Wed Apr 19, 2006 1:49 am
Quoting Dalb777 (Reply 10):
No, the 727 has a larger wingspan than the MD-88.
Jeremy
Why can't the 73S use this gate, it has a smaller wingspan than the 727?
Jeremy
ATLIEN
Wed Apr 19, 2006 2:18 am
Quoting SESGDL (Reply 12):
I am not sure why B-19 was not converted to 737-200 service, it might have to do with B-21 only handling the 757-200 therefore it might not be enough space, B-17 only gets the 737-200 as well.
beertrucker
Wed Apr 19, 2006 2:28 am
Quoting ATLIEN (Reply 13):
I have seen why they do that a few times when i was in ATL. They over lap the wings. 757 over top the 737-200. not by much. but there is a little of an overlay of the wings.
Fly HI
dalb777
Wed Apr 19, 2006 3:39 am
Thats what I thought, but it makes me wonder why B-19 was only for the 727 and not for any other aircraft.
PSU.DTW.SCE
Wed Apr 19, 2006 4:17 am
Big version: Width: 625 Height: 474 File size: 41kb
There are the gates in discussion. There is a 737-200 in gate B-19 in the photo. B-20 as said, isn't being used at the time. It looks like B-20 has a really short jetbridge, hence why even the 737-200 can't fit in there. The 727-200 would be able to due to the wing position farther back on the fuselage.
ilikeyyc
Wed Apr 19, 2006 4:53 am
Quoting PSU.DTW.SCE (Reply 16):
Which one of you is correct? It also appears to me that the gate labled B20 in the above photo has more room than the one labled B19.
Fighting Absurdity with Absurdity!
DAL767400ER
Wed Apr 19, 2006 5:58 am
Quoting Ilikeyyc (Reply 17):
Definitely not. The northern 'boundary' of gate B20 are the two rows of baggage carts right to left of where B20 is written. Everything above that is already B22.
srbmod
Wed Apr 19, 2006 6:58 am
B-20 has been used as a mail/cargo staging area for a number of years now. Used to piss me off when my route with my previous employer was B Concourse, as they'd park mail carts where the vendors were supposed to park at.
WDBRR
Wed Apr 19, 2006 7:23 am
Were B19 and B20 the former Eastern gates?
I know DL had one side and EA had the other side.
ilikeyyc
Wed Apr 19, 2006 7:33 am
Quoting DAL767400ER (Reply 18):
Then appearances are deceiving. So back to my original post, are the gates labled correctly in the photo? Because the thread starter and photo contradict eachother. One says b19 is not in use the other says b20 is not in use.
tu154m
Wed Apr 19, 2006 9:46 am
Actually you have the gates labeled backwards. B-20 takes 732s all day long and all even gates are on the west side of the terminals in ATL. The view you have is looking North. B-19 has been shoved into the corner like in the pic for awhile. I think the tires are flat!!!
CEOs should swim with cement flippers!
DAL767400ER
Wed Apr 19, 2006 4:57 pm
Hadn't even realised the gates were designated the wrong way, my mistake on the worngly drawn conclusion.
Quoting Tu154m (Reply 22):
Considering the gate will now be used, that shouldn't be a problem. Just put some stairs to the jetway and have the pax board via the apron, as is standard for DCI at ATL. Unless of course DL actually wants pax to board pax on an RJ via a jetway.
DL763DFW
Thu Apr 20, 2006 1:47 am
Considering I worked in Zone 7 for about a year, I can tell you that it's backwards on the picture. As someone said above, B-20 takes 732's all day long. It's kind of a bitch to work that gate because you have no room to stage cargo or bags, and its very tight to even load and unload.
Quoting Srbmod (Reply 19):
It's piss us off too when the vendors would park there because it'd make things that much more difficult. In fact, a while ago, somone was parking a 732 and didnt pay attention to a large box truck hanging over in the gate, and the wing went right thru the truck.
B-19 has been used as an area to park airstarts, lav trucks, and offloaded freight. The jetway has been pushed against the spine wall. My only problem with the whole RJ thing is that it's going to be REALLY tight trying to squeeze one in when there is a 757 next door at B-21. When B-19 was closed, they moved all the gates down a little bit to give more room to the gates. It'll be interesting to see how they fit them all in there. Just glad I'm on Int'l!
gr8slvrflt
Thu Apr 20, 2006 1:56 am
Eastern had B-19 through B-36 on the north end of the concourse and a lone B-18 on the south end. You'll still notice the concourse floor slopes down quite a bit on the south end of B. I assume it's because Delta was operating a higher percentage of DC-9s than Eastern when the Midfield Terminal was designed. Eastern had plenty of Nines but way more 727s.
I work for Southwest, but the views expressed are my own and do not necessarily represent those of Southwest.
PSU.DTW.SCE
Thu Apr 20, 2006 2:10 am
I apologize, I did end up mislabeling the picture. At least we are all on the same page now. But, as you can see, we are talking about some very tight gates here.
ATLIEN
Thu Apr 20, 2006 4:49 am
Quoting DL763DFW (Reply 24):
Hey, when did you work in zone 7 because I worked there for quite awhile myself before moving down to 8.
delta767
Thu Apr 20, 2006 6:37 am
Do the same gate agents usually work from the same area of gates? or could they be in A one day, B the next, E, and so on...?
ATLIEN
Thu Apr 20, 2006 7:14 am
Quoting Delta767 (Reply 28):
Yes, currently I work in zone 8 which is gates B-25 thru 33 and B-30 thru 34, A and B concourses are seperated into four zones within each concourse with the exception of T Concourse which is one zone. One will usually work in the same area for a number of months until you bid again.
DL763DFW
Thu Apr 20, 2006 7:29 am
Quoting ATLIEN (Reply 27):
I worked there last bid as an ALA...from around April 05 til Dec 05. Before that I was at DN Bagpoint, and before that I was in DFW. Now I'm an ALA in Area 31 on the Int'l E Gates. As I write this, things are trying to calm down after all the security SNAFU and the weather! Thank God it's my Friday
[Edited 2006-04-20 00:31:55]
ATLIEN
Thu Apr 20, 2006 7:46 am
Oh I know you, a big fan of country music right?
DL763DFW
Thu Apr 20, 2006 7:59 am
Haha, well I like all kinds of music... but yeah country is at the top.
peachair
Thu Apr 20, 2006 10:06 pm
Your photo is wrong, B19 is the one on the right with the Jetway against the Building. B-19's jetway hasn't been used in 9 years ... B20 is the one on the left.
peachair
Thu Apr 20, 2006 10:11 pm
Quoting DAL767400ER (Reply 23):
Right now it will be Chautauqua only. DL will be boarding passengers via the stairs from the jetway and a walkway to the aircraft on the apron level, not the jetway bridge itself. The jetway bridge will be blocked off. The ramp striping has been modified to increase the real estate on the B-19 ramp.
N160LH
Thu Apr 20, 2006 10:30 pm
Its been awhile... But for some reason I want to say that B-21 was used as a widebody gate and because of this they shut down B-19..? I used to date a girl that worked in B-north and I think I remember her telling that was the reason that B-19 was nonoperational. On a side note... Do they still sell those slushies on the B-Spine..? Those thing were hard to pass up when I was out stealing stuff from the domestic gates... hahah ohh the memories...!
N160LH
DL763DFW check your messages...
[Edited 2006-04-20 15:48:59]
"I do alright up in the air, its down on the ground that I tend to mess up..."
DAL767400ER
Thu Apr 20, 2006 10:37 pm
Quoting N160LH (Reply 35):
If it was, it was probably long ago. From what I remember, the only gate that regularly sees widebodies at Concourse B is B1, the rest are at T, A and E. Though I gotta say, from personal experience, B1 always appeared to be THE gate for 767 flights to JAX. Have departed and arrived on that gate quite a few times.
N160LH
Thu Apr 20, 2006 10:54 pm
Quoting DAL767400ER (Reply 36):
I think B has widebody gates at B-1, B-21, B-23, B-25, and maybe B-27.... We used to have steal LD-2 and Transportors from Domestic all the time and remember getting stuff off B-north... But I can not really remember where...
-160
DAL767400ER
Thu Apr 20, 2006 10:58 pm
Quoting N160LH (Reply 37):
Could very well be, though with all the reduction in domestic widebody flying, it is doubtful that any of those gates except B1 will see widebodies again too soon  Sad .
DL763DFW
Fri Apr 21, 2006 1:28 am
B-21 was never a widebody gate. At one time it could take 727s, MD88s, and DC-9s. B-19 was the same way. When B-19 was closed, everything was shifted slightly to the south and B-21 became a 757 only gate. B-23 is a 767-200 and L-1011 capable gate...along with any narrowbody. B-25, 27, and 29 are capable of 767-300s... and maybe MD-11s. But don't flame me if I'm wrong on the MD-11.
DL763DFW
Fri Apr 21, 2006 3:17 am
I forgot to add that things have changed within the last few months in ATL with regard to where wide-bodies can park. Delta management has said they want to keep all wide-bodies in one certain area, as to keep all GSE equipment in one area and because so many 767s have gone to Int'l. Wide-bodies are no longer allowed to operate out of B concourse. In case of emergency, B-1 may be utilized, and the occasional terminating flight might come into B-25, 27, or 29. As far as scheduled service though, you'll only see the wide-rides on T,A, and E.
FutureFO
Wed Apr 26, 2006 4:28 am
Actually B19/20 are more than likely going to be used for S5 when the E170 starts coming in next month. Not for CHQ. We will still be using the D concourse.
Sean from MCO and SDF
I Don't know where I am anymore
deltagator
Wed Apr 26, 2006 4:43 am
Quoting FutureFO (Reply 41):
Speaking of Concourse D when did mainline pull out of there and DCI take it over?
CIDFlyer
Wed Apr 26, 2006 7:10 am
When, or IF, does DL/ATL plan on having jet bridges for regional jets? I am really surprised they don't do this (same is true for CVG). The thing I like about AA and NWA is that at all their hubs the regional jets are boarded with the jet bridges. Its really a nice thing, especially in bad weather.
deltairlines
Wed Apr 26, 2006 9:05 am
Quoting CIDflyer (Reply 43):
I doubt RJs would get jetways at ATL...the way they pack those planes in, I don't really see them being able to add jetways in and still handle the amount of capacity they do handle.
Jeff
FutureFO
Wed Apr 26, 2006 5:08 pm
D20 over to D35 is all DCI flights. It has been that way for about 4-5 months now. At least as long as we have been flying into ATL.
peachair
Mon May 01, 2006 10:55 pm
Quoting DeltAirlines (Reply 44):
Check out Gate B-17 and B-20, Starting today, CHQ EMB-145 will start parking at these gates AND using jetway bridge adapters.
Quoting DeltaGator (Reply 42):
This was done late last year, around Dec.
We had the first EMB145 arrive at Gate B-19 and 20 at about 8:45AM this morning arriving from TRI and departing to FWA. B-19's jetway is not operational, so RP will be using the old stairs on the side of the jetway to board passengers. These stairs were just modified painted, and have had anti-skid added to the paint. There is an elevator for WC customers right under the gate. The S5 EMB-170 will be here in June with service to JFK, SAT, IND, CLE
deltagator
Tue May 02, 2006 1:20 am
Quoting PeachAir (Reply 46):
Ah, I see. I never seem to have flights out of any concourse other than A. Every now and then I get something in B or arrive there and just take the train to the end and go home.
N1120A
Tue May 02, 2006 1:29 am
Quoting Beertrucker (Reply 14):
The 757 sits significantly higher than the 737, so it shouldn't be a real issue.
positiverate
Mon May 08, 2006 11:19 am
When taxiing out of ATL today there was a DCI ERJ parked at B19.
