atlaaron
Delta Flight ATL-LAX Full
Wed Apr 26, 2006 2:40 am
So I was thinking that Delta bookings would be sharply down as everyone was fearing the strike but I have a ticket to fly ATL-LAX on April 30 according to Delta's website the 767 going there is 100% full.
Anyone know if these flights are normally that full?
FlyDeltaJets
RE: Delta Flight ATL-LAX Full
Wed Apr 26, 2006 2:45 am
That flight along with the ATL-MCO flight have always had a large draw. I haven't noticed any lower than usual bookings on anything leaving JFK.
The only valid opinions are those based in facts
deltagator
Wed Apr 26, 2006 2:49 am
Quoting ATLAaron (Thread starter):
Yes, they are always packed to the gills. Even the redeye packs them in. As also said, the MCO flight is almost always packed and usually oversold.
worldtraveler
Wed Apr 26, 2006 10:38 am
If there was any book away, it would be significantly masked on the domestic system since DL pulled so much capacity there.
deltairlines
Wed Apr 26, 2006 10:42 am
Keep in mind that the seat maps aren't an accurate indicator. For example, on the 767, bulkheads and a few other rows are blocked out for airport use only, and then you might not be able to see the seats reserved Medallion/full fares only.
Jeff
boeingfanyyz
Wed Apr 26, 2006 10:08 pm
Seeing as ATL is DL's home-based and LAX is (arguably) a DL hub, it does not surprise me one bit.
I bet that flight is usually full all year-round.
Boeingfanyyz  airplane
"If it aint boeing, it aint going!", "Friends are like condoms...they protect you when things get hard!"
AlexPorter
Thu Apr 27, 2006 12:37 am
Quoting Boeingfanyyz (Reply 5):
Not to mention all the O&D.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
ClearedDirect
Thu Apr 27, 2006 1:12 am
I think they added a 777 to that route as well (ATL-LAX)
CD
atlaaron
Thu Apr 27, 2006 1:14 am
Quoting ClearedDirect (Reply 7):
Yeah, I believe it is the 10:40 am EST that flies a 777.
burnsie28
Thu Apr 27, 2006 1:15 am
Don't trust the websites, I have had it where I looked on the Delta website and then looked at the true loads thanks to a family member, the Delta website seat map thing showed the flight was 100% full. Then when we looked at the actual load it had 50 seats left open.
iowaman
Thu Apr 27, 2006 2:31 am
Those flights don't surprise me as full, those are large connecting destinations. Also it seems that ATL-LAS is the same way, huge O&D and connecting market.
DAL767400ER
Thu Apr 27, 2006 7:04 am
That is only temporary to keep the plane flying instead of sitting on the ground at ATL as just a backup aircraft. Soon the 777 will be off ATL-LAX again.
worldtraveler
Thu Apr 27, 2006 9:31 am
Quoting Burnsie28 (Reply 9):
if you are seeing a flight with every seat assigned and yet there are still seats available to sell, there is obviously a fairly high no-show rate on that flight so overbooking is occurring. However 20% on a 763 (just a hypothetical aircraft since you didn't mention the type) is rather high. There are blocked seats but there is also a no-show factor and thus overbooking to compensate. Given the relatively low fares to many LAX destinations, demand should be strong and the no-show rate is probably fairly high. Typically lower fares and walkup fares generate the highest no-show rates.
avconsultant
Thu Apr 27, 2006 1:51 pm
DL has been operating a +80% load factor. An airline never wants to operate a L/F this high because somewhere in the system you are leaving pax at the gate. LAX is the worlds Top 5 O&D airport, full flights make sense in this market.
PIA777
Thu Apr 27, 2006 4:02 pm
I flew DL (767) LAX-ATL several times in November 2005 and it was always full.
PIA777
GO CUBS!!
AV8AJET
Thu Apr 27, 2006 4:44 pm
Here are the loads for April 30th as of Thursday:
(F) (Y)
0110 ATL LAX 30APR 830A 1028A DELTA 757 9 (24) 27 (159)
0907 ATL LAX 30APR 930A 1126A DELTA 757 13 (24) 19 (159)
0171 ATL LAX 30APR 1040A 1211P DELTA 777 11 (50) 19 (218)
0541 ATL LAX 30APR 1140A 134P DELTA 763 10 (24) 19 (226)
0266 ATL LAX 30APR 104P 253P DELTA 764 8 (36) 31 (249)
0263 ATL LAX 30APR 211P 405P DELTA 764 16 (36) 7 (249)
1037 ATL LAX 30APR 433P 628P DELTA 757 6 (24) 19 (159)
1509 ATL LAX 30APR 555P 756P DELTA 757 4 (24) 3 (151)
1126 ATL LAX 30APR 740P 935P DELTA 764 9 (36) -9 (249)
0422 ATL LAX 30APR 931P 1133P DELTA 757 8 (24) 13 (159)
"To fly or not to fly there is no question!"
AlexPorter
Thu Apr 27, 2006 5:58 pm
I'm sorry, but I'm not sure how to interpret that table - are those loads, capacities, load percentages, or what?
panamair
Thu Apr 27, 2006 6:03 pm
Quoting AlexPorter (Reply 16):
#s in brackets are the seating capacity numbers; other numbers are the number of seats available. Therefore, pretty much all of the listed flights have seats available in both cabins except for DL1126 which is oversold by 9 in Y
USairways16BWI
Fri Apr 28, 2006 1:03 am
i flew on a 777 LAX-ATL back in march. It was a redeye flight. The gate agent said that it was one of the last times the 777 would be on that route. I was lucky to be on it.
Also, the flight was oversold by about 50 people. If the china southern flight had been ontime, all those standby pax would have been spending the night in LAX for the morning 764 flight back to ATL
Delta4eva
Fri Apr 28, 2006 1:25 am
Quoting AV8AJET (Reply 15):
The first # after the aircraft number (ie 757) is the first class available seats, followed by (#) which is the capacity. The second is coach seats available, followed by (#) which is also capacity.
FLY DELTA JETS
atlaaron
Fri Apr 28, 2006 1:28 am
Bummer, I tried rather hard to get on the 777 flight but it just did not work for the company travel. Instead I am on flight 263.
Delta4eva
Fri Apr 28, 2006 1:35 am
Quoting ATLAaron (Reply 20):
The 764 is still a great aircraft. No PTVs though, unless you are in First.
FLY DELTA JETS
