aircanada014
Did AC Increase The Range For A330-300?
Sat Apr 29, 2006 10:37 am
Hello all
I was browsing on AC fleet type and I've notice the range on A330-300 has increased to 6562 from just above 5600. Is this an error or did they really increased the range? I can't see it being an error cause it doesn't make sense if they were upgrading their site. Your comments are appreciate please.
I knew their range was just above 5600 miles but not at 6562miles. Here's the link to AC website fleet for A330-300.
http://www.aircanada.com/en/about/fleet/a330-300.html
aircanada014
RE: Did AC Increase The Range For A330-300?
Sat Apr 29, 2006 10:39 am
I just notice they did the same for A340-300 they increase the range from 7760miles to 8343miles. Here's the link to A340-300. http://www.aircanada.com/en/about/fleet/a340-300.html
thepilot
Sat Apr 29, 2006 11:19 am
Maybe AC added auxilary fuel tanks to increase their range. Maybe it has to do with the cold conditions of Canada. Just speculation, through.
From YVR
vega
Sat Apr 29, 2006 12:26 pm
Airbus lists the range of the - 300 at 10500 Km - which is about 5670 nm and the - 200 at 12500 Km.
[Edited 2006-04-29 05:31:08]
We are but a moment in this vast Universe and when gone we will never have existed.
chrisa330
Sat Apr 29, 2006 12:31 pm
The ranges that were listed before were probably Nautical miles, now they've changed it to Statute miles. Just a guess...
ikramerica
Sat Apr 29, 2006 12:41 pm
That's right. Since most flyers don't know what a nautical mile or a knot is, or at least know distances better in st. miles and speeds better in mph.
The km figures should be the same.
And the way they list range down to a precision of single miles is just stupid. Obviously a PR person and not an engineer did that calculation. No one who understands science would calculate the range like that.
milan320
Sat Apr 29, 2006 4:51 pm
Quoting ChrisA330 (Reply 4):
Why change from nautical miles to statute miles instead of kilometers? Most of the world, including Canada is metric. That said, wouldn't mind driving an American calibrated car (in miles) in Canada. I'd be going faster than I should  biggrin
-Milan320
I accept bribes ... :-)
ikramerica
Sat Apr 29, 2006 5:01 pm
Quoting Milan320 (Reply 6):
Website has both in the table.
I was curious why Metric was in parens (), while English was listed first for a canadian site.
N1120A
Sat Apr 29, 2006 5:25 pm
Quoting AirCanada014 (Thread starter):
It is done in Statute Miles
Nah, we have kms on the inner ring of the speedometer.
boysteve
Sat Apr 29, 2006 6:28 pm
Quoting Thepilot (Reply 2):
While Canada can be very cold places like YYZ can reach 38C/100F in summer so if this extra range was due to the weather then it certainly wouldn't be year round!
N1120A
Sat Apr 29, 2006 9:57 pm
Quoting Boysteve (Reply 9):
Toronto rarely goes above 30C and averages 27C at its highest in July.
sebring
Sun Apr 30, 2006 12:36 am
Quoting N1120A (Reply 10):
You obviously didn't visit us last summer. Most days, the temperature was above 30C and I have my electricity bill to prove it.
Toronto usually gets 14 days each summer with temperatives over 30. Last year, we had 41.
[Edited 2006-04-29 17:42:32]
beechnut
Sun Apr 30, 2006 1:42 am
Those range figures in the AC website were previously given as typical ranges with typical loads, or maximum range with maximum payload (I forget which).
It could very well be that they were changed to give maximum range with full fuel. However that would not be with full payload.
Olympus69
Sun Apr 30, 2006 2:22 am
The temperature in TO reaches 38 about once every 4 or 5 years. 35C is typically the warmest day of the year. However, this has absolutely nothing to do with the range of an aircraft that is cruising at 35 or 40 thousand feet. The temperature at that altitude is affected very little by the ground level temperature. ThePilot, being an A.netter, was obviously aware of this, so his comment in reply #2 was probably a tongue in cheek one  Smile
milan320
Sun Apr 30, 2006 3:11 am
Quoting N1120A (Reply 8):
That I know, I've driven in the US many times. Nice thing is that the kms are so small on the inner ring ... could work to my advantage  Smile
-Milan320
yyz717
Sun Apr 30, 2006 4:18 am
Quoting Sebring (Reply 11):
This comment is a complete contradiction in terms. The summer period (say June 1st to Sep 15) is about 105 days.....41 days of 105 is not "most".
Anyway, the 333 departures from YYZ are primarily in the 5pm to 10pm period when the temp is usually below 30C on days where it reached 30C. I would bet there were likely no 333 departures from YYZ at >30C.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
ManchesterMAN
Sun Apr 30, 2006 8:55 am
Well I was in Toronto/Montreal last year around Grand Prix time and it was HOT. GP qualifying was recorded at 38c air temp!!
Flown: A300,A319,A320,A321,A330,A340.A380,717,727,737,747,757,767,777,DC9,DC10,MD11,MD80,F100,F50,ERJ,E190,CRJ,BAe146,Da
beechnut
Sun Apr 30, 2006 10:43 am
Quoting Olympus69 (Reply 13):
Not so. Range will definitely be affected by surface temperature. As temperature starts to deviate from standard conditions (15C, 29.92" mercury, at sea level, with temp. reduced by the adiabatic lapse rate at higher altitudes), so does aircraft performance begin to deteriorate. At higher density altitudes (an increase in temperature, decrease in atmospheric pressure or increase in altitude), aircraft performance is worse.
In some conditions temperatures can be high enough to reduce takeoff performance for the available runway length, so that an aircraft will have to shed weight to be able to take off. Typically weight is shed in the form of payload, or fuel uplift.
Therefore very hot temperatures, very low atmospheric pressure or very high field elevations, or a combination of these, will either reduce range for a given payload, or reduce payload for a given range. Here's an example of a runway analysis for a DC-10 at Kingston, Jamaica, airport taken from my DC-10 Ops Manual: taking off from runway 29 at 60 deg F and zero wind, the max weight is 404,400 lbs. At 90 F, the permissible weight uplift from the same runway is 392,100 lbs (for a flaps 10 takeoff). So either payload, or fuel, will have to be limited at higher temperatures. If fuel is reduced, range is reduced as well.
The plane DOES have to get off the ground before it gets to cruising altitude.
Incidentally higher than normal temperatures at high altitudes will affect range as well.
Beech.
ikramerica
Sun Apr 30, 2006 10:58 am
Quoting Milan320 (Reply 14):
My car does NOT have that inner ring, and it's a freaking German car! Worse, I picked it up in Germany for the European delivery program, and it had no km markings.
Luckily, the onboard computer can be set to show your speed digitally, and then you can switch that system over to metric, so the cruise control and digital display was in km (and temp in C) while the "analog" dial was reading mph. Luckily, it didn't switch over to metric time, as I would have been too confused. "It's 9:83 on March the 35th."  Wink
First MB I've seen that didn't have metric on the dial. I have no clue why they did that.
Olympus69
Mon May 01, 2006 2:48 am
Quoting BeechNut (Reply 17):
I thought about some of that after I posted my message, which was badly constructed anyway. What I should have said was that none of those variables are taken into account in published performance figures, which are based on ISO conditions and that Canada being a cold country (only true in the winter) is irrelevant.
What was in my mind was that above a certain altitude temperature remains constant (I think), but that altitude is probable above where commercial aircraft operate.
