worldtraveler
AA A300's On Transatlantic Routes
Sun Apr 30, 2006 9:39 am
Can someone with specific knowledge tell me if AA had any operational issues (payload limitations, fuel limits) on its A300s when they flew transatlantic routes? What cities did they serve? And was the reason for pulling them off because the 777s became available or were there other reasons?
commavia
RE: AA A300's On Transatlantic Routes
Sun Apr 30, 2006 9:57 am
Quoting WorldTraveler (Thread starter):
I don't think AA really had any specific performance issues with the A300s short of the normal unreliability of the planes for AA. As for operational limitations, I doubt AA ever really had a problem, as the planes were never flown on any routes outside of the Northeast. They only really flew from four U.S. cities -- JFK, EWR, BOS and PHL -- to London and Paris, with perhaps a few exceptions, but not much.
I know they flew PHL-LHR at least at some point, along with BOS-ORY back when AA's Paris operations were at Orly. They also flew on EWR-LHR on and off as AA served the route, and were replaced on the route by a 777 only a few months before the route was cut altogether in 2003. However, the bulk of AA's A300 flying to Europe was on BOS-LHR and JFK-LHR. Both BOS-LHR flights operated with A300s for many years, and at some points, as much as half of AA's JFK-LHR schedule was comprised of A300s, with the other half being -- depending on season and the year -- a mix of 767-200s, 767-300s, or MD11s. (This was also back when AA had international 3-class configured 767-300s and international 767-200s.)
The A300s were never intended to fly the Atlantic forever. They were put in place because they were high-capacity, and could basically act as a placeholder until AA found something bigger and better to put on its premium Europe routes. The MD11 was supposed to take over, but was a failure. The 777, on the other hand, replace the A300s and AA has never looked back, having placed the A300s back on the Roach Coach runs in the Caribbean and Latin America where their high-density, uber-cargo-capacity configuration is more appropriate.
worldtraveler
Sun Apr 30, 2006 10:01 am
thanks Commavia. Based on the weight of the aircraft, it should have been capable of doing 8 hr transatlantic flights which all the routes you mention are. I take it the A300s had a 3 cabin configuration at the time? It still seems that AA would benefit from A330s for NE-Europe flights, esp. to London. The A300s were probably too small but the 777 is overkill compared to what it could be doing for AA on the Pacific.
airxliban
Sun Apr 30, 2006 9:31 pm
Look at this which I dug up from Tugmaster:
The A300's had a problem with carrying any decent load over the distances from LHR to BOS/JFK/EWR. They could carry loads of freight and not that many pax or vice versa ,but not both...and they always had there tanks topped up to the max. I remember pushing them and if it was a hot day the wing fuel vents used to piss out fuel as you were pushing as they needed to fill the thing up to the gills so it get to it's destination. Also have flown to JFK on it , the pax seating used to be 9F/30J/148Y and the morning I flew to Kennedy, the flight was limited to 102 pax total due to the holds being full of freight.(luckily there were only 99 fare paying and I managed to get the 102nd non rev seat. ) Also, the A300 would never dept LHR with 4 pallets in the forward hold as it just didn't have the guts to carry the weight back to the states...max was 2 pag's/pmc's and six bins on the westbound legs,........need more......? As with nearly all poor quality airbus products!
, the PDU's in the holds were utter crap....though this is not just an issue for the A300, the 330/340 also suffer from these poorly made/designed PDU's. So as you can see, the employees at LHR were indeed happy to see them go back to the states.
commavia
Sun Apr 30, 2006 9:59 pm
Quoting WorldTraveler (Reply 2):
Yes. There was a small subfleet of about 8-10 aircraft reconfigured for a 3-class FJY configuration. After the A300s were pulled off the Atlantic around 2002-2003, they reconfigured all of them back to the standard 2-class configuration for Latin America.
The 777s are not too small. These routes, at least for AA and BA, are very high-volume and very high-yielding, not to mention the large amount of cargo AA carries to Heathrow. The 777 is perfect for these routes, and AA bought the 777 with Heathrow specifically in mind.
kc135topboom
Sun Apr 30, 2006 10:10 pm
When the AA A-300-605Rs are gone, I doubt you will ever see another Airbus product in AA colors. These airplanes have been a disappointment, to say the least, for AA. While other airlines really like the A-300-600R, and other Airbus airplanes, AA just has not had very good luck with them.
It was not really the AA B-777-200ERs that replaced the A-300-600R on Trans-Atlantic routes (I agree the B-777 is a lot more airplane capability than the A-300), but more of the B-767-300ER. This airplane is much closer in size, and load capacity, to the Airbus, but also has about 60% more range as well as a much lower CASM.
Cargo capacity is very important to AA, as that is where they make lots of money. I agree the A-300-605R has a very good cargo capacity, it's PDUs are an oddity for AA.
worldtraveler
Sun Apr 30, 2006 10:22 pm
thanks for the info.... what are PDUs?
airways45
Sun Apr 30, 2006 10:40 pm
PDUs are 'power drive units' - the electric cargo rollers that move the cargo containers inside the belly hold.
Check out http://www.cargo.goodrich.com/lowerdeck.shtml
Airways45
captaink
Sun Apr 30, 2006 10:48 pm
Does the A330-300 and A340-300 suffer from these problems? Secondly, it has been said that the A300 are used on Caribbean/Latin American routes for its cargo capacity. I assume that it serves well here cause the routes are much shorter? What would AA use on these routes when/if the A300 is phased out?
There is something special about planes....
commavia
Sun Apr 30, 2006 10:49 pm
Quoting KC135TopBoom (Reply 5):
I have to disagree with you here. The two main routes AA flew the A300s on for the longest time to Europe were BOS-LHR and JFK-LHR. Both are now 100% 777s. The 777s did, indeed, mostly replace the A300s on trans-Atlantic routes, but you are certainly right in saying that the 767-300 makes up the mantle of AA's overall network to Europe.
NW747-400
Sun Apr 30, 2006 11:50 pm
AA used the A300 on routes PHL-SJU in the 90's. Usually a 727 in long haul config (3-2 Y class instead of 3-3) was used but a few times I was lucky enough to catch the widebody.
AA777223
Mon May 01, 2006 12:48 am
Quoting Commavia (Reply 9):
One thing we all have to remember too, is that part of the reason AA uses 777s on their routes to london is they are one of 2 aircraft types they have left that have a 3 class configuration. The other is the 762, which they have to have all three classes because they signed a contract of sorts with hollywood that they would supply a first class product between New York and LA. I actually flew on an AA A300 once several years ago. I flew in the business cabin and I don't remember the route exactly. I assume it was either ORY-JFK or ORY-DFW. I remember being surprised when I got to the gate and there was an airbus there instead of the usual 767. It was an alright flight though. The international flagship product was identical to AA's 767s of the time.
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
commavia
Mon May 01, 2006 12:58 am
Quoting AA777223 (Reply 11):
Indeed. Again, AA's 777s were designed specifically to fly the Heathrow routes and take over for the A300s.
True. A lot of frequent flyers actually liked AA's 3-class A300s, as the planes had a bigger 'feel' to them because they were so wide and fat. Also, IINM, AA's 3-class A300s (again, only 8-10 of them) were equipped with PTVs, which was also popular with travelers back then.
AA777223
Mon May 01, 2006 1:32 am
Quoting Commavia (Reply 12):
I don't remember seeing PTVs on the A300. They had them in First I know, but back then in business you got this little mini video player that used these cassettes that were a little bigger than audio cassettes. They used those on the 767s also. They used them up until the advent of the 777 and they introduced a new business class product across the line, sans sheepskin seat covers. They now give out personal DVD players on the 767s and the T7s obviously have PTVs at every seat.
MAC100
Mon May 01, 2006 3:00 am
AA's A300s did have PTVs in Economy and very nice leather seats, too (at least on the BOS-LHR route).
qqflyboy
Mon May 01, 2006 6:37 am
The three class Bus at AA was one of the nicest aircraft we had. The configuration was fantastic as even coach felt intimate... I dont remember coach capacity but it wasn't very much. There were indeed PTVs in all cabins and was powered by the Matsushita 2000 or 3000 (can't remember the number) IFE system. There were even games... something not even the T7 at AA offers.
If there were any problems for that aircraft across the Atlantic it was the service ceiling. When fully loaded it took the plane a long time to burn off the necessary fuel to climb to higher altitudes and even then the ceiling is less than the 763 and 777. You would get tossed around a bit more in the Bus, but that probably has as much to do with it's rigid wing as it does with the service ceiling. I remember those planes fondly, however, and still enjoy working them to the Caribbean.
The views expressed are mine alone and do not necessarily reflect my employer’s views.
C133
Mon May 01, 2006 8:59 am
Quoting Commavia (Reply 4):
Would you care to share with us your source for this statement?
Fine: Tax for doing wrong. Tax: Fine for doing well.
1337Delta764
Mon May 01, 2006 9:06 am
Quoting Captaink (Reply 8):
AA is a likely candidate to order the 787. The 787-3 is an ideal replacement for the A300s, where the 787-8's range is not needed.
commavia
Mon May 01, 2006 9:11 am
Quoting C133 (Reply 16):
While I don't have a specific press release to refer you to, AA has always said that its 777s would be reserved for only its most premium routes. AA's first route with its 777 was DFW-Gatwick, and the planes were flying on AA's routes to Heathrow from Chicago, L.A. and Miami within 18 months of taking delivery. Again, I don't have a specific source to point you to, but I assure you -- you could ask just about any executive at AA and they would readily tell you that AA bought the 777s specifically thinking they would be serving LHR. It is just the way it was.
captaink
Mon May 01, 2006 9:13 am
Quoting Qqflyboy (Reply 15):
Are any of these A300s around still? What did AA do with them? I am talking about the leather seat/PTV equipped buses. I get the opportunity to fly the A300 alot between MIA/SJU and i did it twive MIA/MEX but i hear that the airplane is no longer used on the route. I like the A300 quite a fun airplane to fly on.
Alitalia744
Mon May 01, 2006 9:15 am
AA is god's gift to humanity WorldTraveler - don't you know? They have no operational issues. Ask Commavia and he'll confirm
[Edited 2006-05-01 02:32:35]
Some see lines, others see between the lines.
isitsafenow
Mon May 01, 2006 9:19 am
Quoting Commavia (Reply 18):
Are you showing us "your cards"?
safe  wave
If two people agree on EVERYTHING, then one isn't necessary.
commavia
Mon May 01, 2006 9:25 am
Quoting Isitsafenow (Reply 21):
safe
Very funny.  Smile
Just simply stating that anyone at AA -- doesn't even have to be an executive! -- would readily tell you that AA bought the 777s specifically with the Heathrow market in mind. Heathrow is the end all be all of premium markets, and the 777 is the most premium-oriented airplane AA has.
isitsafenow
Mon May 01, 2006 10:06 am
Quoting Commavia (Reply 22):
AA ALWAYS had premium equipment as long as I can remember and the 777 just puts the iceing on the cake. I'm disappointed my old company, NW went with the A330 instead of the triple seven. But now I'm just an armchair airline CEO, like a
lot of people at A-net.
Thx for the grin.
take care.
safe
phllax
Mon May 01, 2006 10:23 am
Quoting Commavia (Reply 1):
PHL-LHR was a 767 for the entire time it was online.
The only A300's in PHL were used for the SJU runs. It flew the outbound leg in the morning and was the RON on the return.
qqflyboy
Tue May 02, 2006 1:54 am
Quoting Captaink (Reply 19):
Yes, they are. The only way you could recognize them now is the drop down screen in the middle of the overhead bins are flat, not the old style TVs. And, the seats have blue leather headrests in coach. It was misleading to say before that coach had leather seats. They never did, but they did have leather headrests. The seats are the same except they have AA's new dark blue seat covers.
airxliban
Tue May 02, 2006 2:10 am
Quoting QQflyboy (Reply 25):
What about having AA's 767 and 777 lookalike C-Class seats? It seems as though some of the A300's have the blue business class seats and the rest have the old 757 style seats.
ikramerica
Tue May 02, 2006 2:34 am
And NRT. That was and is also a very important premium market, now with 6 777s a day most days of the year.
commavia
Tue May 02, 2006 3:09 am
Quoting Ikramerica (Reply 27):
Absolutely. NRT was also a market AA had in mind when buying the 777s.
C133
Tue May 02, 2006 3:46 am
Wouldn't it be fair to say that AA wanted to replace the MD-11s with a right sized (to them) airplane for the important international routes, and when the 777 came along it fit the bill?
I toured the Everett Boeing plant when only the walls were up on the 777 assembly building, and the rep who was our guide told us that AA would buy the 777, but not right away. Somehow he turned out to be correct.
AA777223
Tue May 02, 2006 3:51 am
I know AA still has a few triple 7s that don't have the international flagship suites in F. Does anyone know what routes these fly? I have flown AA triple sevens to CDG and Frankfurt (back when they used the T7 on those routes), as well as LGW all to DFW and they always had the suite product. I even glot to fly in one once from MIA to DFW. I was connecting from a flight from europe and usually that route is covered by a 757, so when they put the upgrade from the flight from CDG through it listed it as first, since the CDG flight only has business, and not first. It was a very pleasant experience.
kc135topboom
Tue May 02, 2006 4:00 am
AA has never flown the A-300-605R into DFW, except for the maintenance tours. The A-300-600R has a range of 3800nm, the distance between DFW and ORY is 4302nm.
qqflyboy
Tue May 02, 2006 4:03 am
Quoting AirxLiban (Reply 26):
There are new seats in business class too, at least on the former 3-class Busses. I didn't mention it before because unless your sitting in that cabin, you may not see them if boarding through the 2L door. The new business class seats on those planes are unlike any other in the AA fleet.
Quoting AA777223 (Reply 30):
The T7s have been standardized in both business class and coach and are flown throughout the system. There is no longer a 777A and 777P fleet, therefore, the different aircraft are no longer relegated to specific destinations. The aircraft that do not have Flagship Suites will get them starting in 2007 when AA adds the new j-class seat to the T7s.
commavia
Tue May 02, 2006 4:17 am
Quoting C133 (Reply 29):
Size wasn't the issue. It was a premium product AA wanted for premium markets like LHR, EZE and NRT. The 777 was is a superb aircraft, very well regarded by employees and customer alike, and was bought by AA specifically for premium markets, namely LHR. I single out LHR only because AA's daily LHR schedule alone (not even counted LGW) accounts for nearly AA's entire 777 fleet.
AA wanted to wait and see how the plane performed in regular service. AA does not really like investing money into new things, and is happy to let others bare the upfront expense and burden of putting new planes into service. AA waited four years after United's first 777 to take delivery of its first plane, and as such, all of AA's aircraft today are later-version, more advanced, longer-range 777-200IGW aircraft that are designed with the benefit of all that was learned from United's early 'A-market' 777s.
The non-Flagship Suite aircraft are all over the place. They used to fly mainly on the Asia routes, but are also quite common on Europe/South America runs. The only 777 market in the entire system that is virtually guaranteed to get the Flagship Suite is AA136/137 LAX-LHR-LAX. That route is nearly always a Flagship Suite because it is so reliably premium. I have flown DFW-LGW on AA at least five times, and can only recall once that it wasn't a Flagship Suite aircraft. Generally, though, the Flasghip Suite aircraft continue to be utilized more and more all over, and as QQ said, all of the non-Flagship 777s will be converted by 2007.
TUGMASTER
Tue May 02, 2006 5:27 am
Quoting Commavia (Reply 33):
At present AA has 45 777's plus 1 on lease to Boeing...each day at LHR you will see 19 different ships....
Quoting QQflyboy (Reply 32):
They brought back the different designations 772A & 772P due to popular request from pax who wanted to know if they'd have the Flagship or Coffin seat in first.
At LHR we see both, and although we do try to keep route specific types, 772P to JFK & ORD as these can turn to a pacific route...there is no gaurentee, on any route....including the 2 LAX flights...
As the topic was originally about the A300's across the pond , let me just thank Airxliban, who dug up some old comments on the aircraft(reply 4).
As already mention the A300's were absolutley crap for performance/payload across the pond.
As for the inside ...no difference to the F/J/Y product on the atlantic routes at the time.
The 777's weren't brought to replace the A300's but to replace the MD-11's.
The now known as CRAP A300's were a stand in as AA didn't have the metal to continue it's South American expansion...EZE/GRU/GIG...therefore the 767's were sent south as the scud's went to Fedex and the CRAP A300 covered the JFK/BOS-LHR routes till the 777 arrived.
BTW, think the PHL-LHR flight may not always been a 767, seem to remember AA142 being a MD11 a one point....
rgds
TUGMASTER
AA777223
Tue May 02, 2006 5:49 am
I always wondered why they even bothered to use two different configurations, and why they used the triple 7s for all the european markets, only to take them away from us later to go back to the 767. I know they need them for thier asian expansion, but other than India and China, they still have alot of 777s. It just doesn't seem that they have started enough new routes to justify pulling the T7 from all the major european routes except LHR. I just may be a little bitter because I hate flying through london, so I never get to fly on the much loved 777, except when i go to south america. Isn't one of the biggest maintenance bases for the 777 in DFW? Because we don't get very many of them anymore. They all go to Chicago  Sad
