757lgw
Flybe Check-in Times?
Sat May 06, 2006 5:31 am
On flybe's website under FAQ's it says the following:
The absolute minimum check-in times are listed below. If you arrive just outside these times, you will be denied boarding.
Domestic flights: 30 minutes with luggage or 20 minutes with hand baggage only.
YET!!! after having booked my flight in my conformation e-mail it says the following
Outbound: Main Terminal / FlyBE. / Passengers must check-in a minimum of 45 minutes before scheduled departure.
Return: Terminal 1 / FlyBE. / Passengers must check-in a minimum of 45 minutes before scheduled
so can i check in 20miniutes before or do i have to check in 45miniutes before??? flybe clearly needs to sort this problem as its very unclear
