ba1978
A380 - Different Sized Flap Guides
Tue May 09, 2006 5:08 am
I was looking at some pictures of the A380 and noticed that the inboard flap guide on the left wing seems longer than that on the right. At first I thought it might be the angle of the picture, but looking at a few more photos you can definitely see that one is noticeably larger than the other. I've even managed to find one picture showing an unpainted A380 where you can seen the guide outline for the larger one on both wings.
Does anyone know why this may be and what, if any, purpose does it serve?
Photo © Jan Kertzscher
Photo © CL Kwek
Photo © Philippe Noret - AirTeamImages
Photo © Alex F.
There are other ways and there's British Airways
RichardPrice
RE: A380 - Different Sized Flap Guides
Tue May 09, 2006 5:12 am
Its to hide equipment, not sure what exactly but thats the purpose for the longer housing.
brendows
Tue May 09, 2006 5:16 am
Quoting BA1978 (Thread starter):
The RAT (Ram Air Turbine) is located here, that's why it's bigger.
ImperialAero
Tue May 09, 2006 5:20 am
This is total conjecture on my part, but i guess that it could possibly be due to the assymetrical airflow caused by the fact that all the engines turn in the same direction, hence causing slightly different airflow patterns over the bottom of each wing. On its own this would maybe not require the longer fairing on one side, but this could have some effect on the tail surfaces, hence the need to deflect the airflow back out more on one side than on the other to regain perfectly symmetrical airflow over the control surfaces on the tail.
Just an educated guess...
ICURFC - Who Is Sylvia?
solnabo
Tue May 09, 2006 5:24 am
What´s that bulky wart thing between the wings and tail?
Micke//SWE  Confused
Airbus SAS - Love them both
ImperialAero
Tue May 09, 2006 5:29 am
Tailskid me thinks...
Heres hoping i got that one right at least...
RichardPrice
Quoting Solnabo (Reply 4):
That would be an American passenger  Wink
Ok ok, give me a 10 second head start!
brendows
Tue May 09, 2006 5:33 am
What�s that bulky wart thing between the wings and tail?
I believe it's the tail strike protection used during the flight testing, for the minimum t/o-speed tests. Because of the much higher weight of the aircraft, it wasn't possible to use the same kind of protection that was used on the 777 and A340NG for the same kind of tests. Please correct me if I'm not correct.
