1337Delta764
Which Concourses Will My Delta Flights Land In?
Fri May 12, 2006 5:05 am
I would like to know this because I plan to eat at Chili's in Concourse A in ATL.
My flights are on June 1. The flight to ATL is flight 646 from SLC on a 767-400ER. Every time I have flown the 767-400ER, they have always used Concourse T, but I cannot assume that. The next flight is 730 from ATL-SJU.
I would like it if at least one of my flights are in Concourse T, A, or B. If both flights are in Concourse D or E, is there a possible chance that I would still have time to eat at Chili's? Note that there is also the possible chance that my brother may want to eat somewhere else.
Does anyone working for Delta have this information?
[Edited 2006-05-11 22:06:21]
OttoPylit
RE: Which Concourses Will My Delta Flights Land In?
Fri May 12, 2006 5:17 am
Well, if your arriving on a 764, then its a pretty good bet that your flight will land at T, A, or E Concourse, as those are the most commonly used/or capable of handling the 764 wingspan. I do not know of any gates on B that are capable of it. Being that your second flight is on a 757, that could be departing from just about any gate in ATL, except for a few gates that are modified only for small narrowbodies.
As far as knowing in advance, no one will know until day of departure. Lots of things can happen between that time and now.
OttoPylit
I don't have a microwave, but I do have a clock that occasionally cooks shit.
litz
Fri May 12, 2006 6:41 am
Your SLC-ATL flight was T1 yesterday, and E3 today.
Your ATL-SJC flight was A9 both yesterday and today.
Nice thing is, however, no part of the airport is more than 15mins or so away.
So even if you come in on E, a trip to A won't take all that long, maybe 5mins.
646 arrives at 3:59pm, 730 leaves at 6:19pm
Even if both flighs were on E, you could still easily make it from from E to A, eat, and back in that time period ... Heck, you could probably WALK the distance and still have time to eat.  Smile
- litz
1337Delta764
Fri May 12, 2006 6:43 am
Quoting Litz (Reply 2):
It's SJU, not SJC.
jbmitt
Fri May 12, 2006 7:22 am
Well then.. go look it up yourself. Delta.com under flight status and you can check it on your own.
airlinelover
Fri May 12, 2006 7:26 am
Quoting 1337Delta764 (Thread starter):
Hopefully they won't land in the concourse. Hopefully they'll land on the runway..
Chris
Lets do some sexy math. We add you, subtract your clothes, divide your legs and multiply
litz
Fri May 12, 2006 10:10 am
Quoting 1337Delta764 (Reply 3):
It's SJU, not SJC.
My mistake ... the gate info is correct, however - I typed in the right airport code when looking them up ...  Smile
Does that Puerto Rico seem to "live" at A9? Most flights I've been on (sometimes same flight for several weeks in a row, a few times the same flight the next day) are rarely, if EVER the same gate ...
- litz
Users browsing this forum: airpearl, airplaneboy, Baidu [Spider], blooBirdie, col, f4f3a, Google [Bot], juliuswong, KarelXWB, keesje, konkret, Mani87, N14AZ, Noshow, PEET7G, stratocruiser, SyeaphanR, Theseus, TWA767, WiktorWWW, yyztpa, Zaf, ZeeZoo and 14 guests
