musapapaya
CX 255 Returns To HKG Due To Broken Down A/c
Sat May 13, 2006 3:15 am
CX255 departing HKG on 9th May was forced to return back to HKG after the a/c broken down. It was 2.5 hours in flight when the captain made the decision.
The local news in HK says that the a/c was not working well before take off and that passengers were complaning about this situation. Some passengers were reported to be sick.
I wonder why the captain decided to take off if the situation was known before that. Why not just find a replacement aircraft or something? The passengers were later put on another aircraft and departed 9 hours after schedule.
In chinese http://hk.news.yahoo.com/060511/12/1nqr4.html
Lufthansa Group of Airlines
TK787
RE: CX 255 Returns To HKG Due To Broken Down A/c
Sat May 13, 2006 3:21 am
4 years ago, on a flight from San Jose, Costa Rica an AA757 had the same problem while still on the ground, but the captain apologized and we continued on, it was a very uncomfortable flight. Good thing nobody got sick.
cloudyapple
Sat May 13, 2006 10:04 am
By a/c Musapapaya meant air conditioning, not aircraft. No danger to the passengers at any time. It was a comfort issue that forced the aircraft back to Hong Kong.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
cwldude
Sat May 13, 2006 10:10 am
Was going to say then if a/c meant aircraft that pilot needs seeing to!
Air Conditioning sort of excuses him from decided to take off eventually - granted it would have been very uncomfortable, I'd rather fan myself for a few hours than endure a 9 hour delay!
Thomson Airways - The UKs premier charter airline // now flown : BY -AA -AJ -AE -AT; OO -AX -AU -RA -BG; BRIG; OBYD
CX Flyboy
Sat May 13, 2006 10:32 am
Temperatures reached 40 degrees celcius, so anything other than a turnback was impossible. However it is not uncommon for a 744 to have a warm cabin on the ground because the APU is not good enough to cool the cabin in the tropical heat. After departure it became evident that one pack which had supposedly been locked out had not been done properly, and the captain in conjunction with engineering started to trouble shoot to see if they could fix the problem. After a while they decided the best thing would be to return which they did.
Musapapaya, please do not think that the crew were happily just sitting there for 2.5 hours before they suddenly noticed that it was warm and decided to turn back. This is not the case, and no-one knew before departure that the aircraft had this problem. No-one would willingly take an aircraft into the air with this fault.
TK787
Sat May 13, 2006 10:53 am
Quoting CX flyboy (Reply 4):
Like I said, on my AA flight they did, and I am telling you fanning doesn't do a whole lot after a while, it was toasty on that flight.
SInGAPORE_AIR
Sat May 13, 2006 5:26 pm
Excerpts from the South China Morning Post - 11 May 2006:
"There was hot air coming out of the vents," she said. "The captain announced that it might be because the engine was off and that it should cool down once we were up in the air."
The plane, carrying 222 passengers, took off 22 minutes late.
"After two hours in the air, I felt really claustrophobic and had an anxiety attack. I told my husband I felt like I couldn't breathe," frequent flier Mrs Hira said. "An air hostess noticed and they were fanning me, getting me napkins with ice every 10 to 15 minutes to calm me down.
"My driver in economy class told me the situation was even worse there, with at least two people lying down in the walkway."
A Cathay Pacific spokeswoman said a valve in one of the plane's air-conditioning systems was faulty.
However, Mrs Hira asked why passengers were made to put up with such difficult conditions for four hours when the problem was apparent from the outset.
"If your parts are faulty, you should not take off to begin with. If they thought it would get better but it didn't, it shouldn't have taken them so long to decide to turn around - it was a 12-hour flight."
musapapaya
Sat May 13, 2006 11:20 pm
Quoting Singapore_Air (Reply 6):
Hi Singapore Air
I have to second this. They should have known that one of the pack was not working properly. This is quite a shame how CX handles this case.
Best regards
William
CX Flyboy
Sun May 14, 2006 11:50 am
Actually, having one pack unserviceable is not a big problem. You just shut it off and rely on the other two. Aircraft often depart with unserviceabilities. Redundancy is built into aircraft so this sort of thing does not ground an aircraft and disrupt operations.
They knew the pack was unserviceable. It was shut off and written in the tech log. No problems there.
musapapaya
Sun May 14, 2006 6:55 pm
Hi CXflyboy
Thanks for your comments. Then may I ask if you have any clue why they are forced to return? You said that the other two were functioning properly.
William
CX Flyboy
Sun May 14, 2006 8:15 pm
The problem was that the pack was not isolated properly, and a valve which runs hot air from the engine was not closed and ran very hot air into the cabin. This the crew did not know about until its effects started showing.
musapapaya
Mon May 15, 2006 3:16 am
Thanks for your clarification CX Flyboy! You really helped understand more on this case! Welcome to my respected user list!
William
CX Flyboy
Mon May 15, 2006 11:33 am
Thanks !
Red Panda
Tue May 16, 2006 5:52 am
In many cases, being too hot on ground is not a problem. This is probably the APU is not working. As CX flyboy says, many unserviceables are Acceptable Deferred Defects that can be fixed later on. However, as a crew member, we would rather to have these problems fixed for our convenience.
Regarding the above case in particular, I am sorry I know nothing about it.
Brgds,
R Panda
musapapaya
Tue May 16, 2006 6:03 am
Oh yes this reminds me of a trip from HKG - LHR last september.
We boarded the BA 747 and the captain also annouced that due to some reasons the aircon was not working on the ground, the situation improved when we took off.
Why would the APU be not working? Does that mean it is broken down or just the captain did not turn it on?
Thanks again
William
CX Flyboy
Tue May 16, 2006 3:12 pm
It is not at all uncommon for an APU to be broken. If it is available to be used, then we always use it.
