magic48
Birds Hit Boeing 767 Jet, Leave Hole In Main Wing
Wed May 17, 2006 3:03 am
Hokkaido International Airlines, the Sapporo-based carrier known as Air Do, said Tuesday that birds hit one of its Boeing 767 aircraft in midair Monday night, leaving a hole in one of the plane's main wings.
According to the airline, the two-engine jet, which had left Tokyo's Haneda airport, was about to land at Sapporo's New Chitose Airport around 8:45 p.m. when birds collided with its right wing, creating a hole about 30 centimeters wide.
No one was injured in the incident, but it caused Air Do to cancel a total of 15 flights between the two cities, the carrier said.
Source: http://asia.news.yahoo.com/060516/kyodo/d8hku82g0.html
A342
RE: Birds Hit Boeing 767 Jet, Leave Hole In Main Wing
Wed May 17, 2006 3:32 am
WTF ? 30 centimeters ?
Could you see through the hole, or was it just in one wing panel ? Any info on the bird species ? Could we assume that the hole is in the outer wing ?
Exceptions confirm the rule.
B6JFKH81
Wed May 17, 2006 3:50 am
Quoting A342 (Reply 1):
Ah, that's nothing...should be able to fix that with a little speed tape LOL! j/k
litz
Wed May 17, 2006 7:16 am
That's actually eerily similar in size to the big hole the foam caused in Columbia's leading edge ... speed of impact was probably similar as well.
Anyone know the species of bird? That had to be some amazing impact ...
- litz
Bicoastal
Wed May 17, 2006 7:25 am
Ummm.....uhhh....how's the bird's wing?  Sad
Airliners.net has many forums. It has spell check and search functions. Use them before posting!
md80fanatic
Wed May 17, 2006 7:26 am
You mean to tell me there is a bird that exerts more point force than structural steel? Tell me it isnt so.  duck
flyabunch
Wed May 17, 2006 7:29 am
I am sure glad it only hit the main wing and not the secondary one too!  Yeah sure
Mike
doug_or
Wed May 17, 2006 7:30 am
good thing it didn't hit the Aux wing.
When in doubt, one B pump off
Bobster2
Wed May 17, 2006 8:01 am
It has to be translation error. They must have meant 30 cm dent, not a hole.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
DLKAPA
Wed May 17, 2006 8:28 am
Quoting Litz (Reply 3):
If the speed of impact was the same then Columbia would have never made it out of the atmosphere. Earth's escape velocity = 11.2 km/s, or 1.12 x 10 4 m/s. The speed of a 767 flying at an altitude low enough to hit a bird is probably around 250KIAS, which works out to 0.138 km/s, or 1.38 x 10 2 m/s. Bit of a difference I think.  Wink
EMBQA
Wed May 17, 2006 8:34 am
Some where on the net is a series of pictures of an American 767 that hit some birds while departing out of LHR I think. One bird went clean through the radome, the pressure bulkhead, through the glareshield and ended up in the Captains lap.
prebennorholm
Wed May 17, 2006 8:58 am
Quoting DLKAPA (Reply 9):
Columbia never reached Earth's escape velocity. If it had done that, then it would never have crashed, but entered an eternal orbit around the sun.
It reached Earth low orbit velocity which is some 7.9 km/s.
But the speed when the foam hit the wing was much, much lower. It happened within the atmosphere. Columbia left the atmosphere (for all practical things) going around Mach 3 which is only 0.9 km/s at high altitude.
I don't know at what speed it happened, but it could easily have been at subsonic or low supersonic speed.
But then Columbia was a lot more fragile. Flying it on top of the B747 carrier at just 250 knots though a rain shower would totally destroy the thermal protection.
Alias1024
Wed May 17, 2006 11:41 am
Quoting Bobster2 (Reply 8):
Birds leave holes if they and the aircraft are going fast enough, or the bird hits in a weaker area. I've seen pictures of a Piper Seminole that had a run-in with a large bird (i think it was a turkey vulture) while in flight. The bird entered the top of the wing, and went clear through, leaving about an 24 inch diameter hole on the right wing.
penguinflies
Wed May 17, 2006 12:06 pm
maybe it was one of those infamous frozen chickens and a chicken cannon.
CRGsFuture
Wed May 17, 2006 12:16 pm
Can I ask, why is it so tough to comprehend a hole produced by the bird? Laws of physics could easily tell you that this was to happen if the conditions are right.
Flying you to your destination; your girlfriend to her dreams.
B777fan
Wed May 17, 2006 12:19 pm
Quoting Prebennorholm (Reply 11):
Not only that, but the foam was moving at the seem speed until it detached.
The relative speed at impact was even lower. I don't recall exactly, but I think the relative impact speed was in the 500 to 600 mph range. I might be low, but that is still fast enough to have caused the damage.
N600RR
Wed May 17, 2006 12:51 pm
Quoting Penguinflies (Reply 13):
...Probably a case of that "Avian Flu" that's been all over the news recently...  sorry
"And the fluffy white lines that the airplane leaves behind are drifting right in front of the waning of the moon" -Cake
ckfred
Wed May 17, 2006 1:06 pm
In 1995, a very severe thunderstorm hit DFW, and a number of AA jets were grounded, due to baseball and even larger hail damaging planes on the ground. A common problem was hail going through composite surfaces on the wings and horizontal stabilizers.
On the other hand, the DC-10s and 727s on the ground only suffered dents, since they had more metal surfaces.
TinkerBelle
Wed May 17, 2006 1:14 pm
I thought Sapporro was a Japanese beer? Mmm-good when you drop some saki bombs in it.  stirthepot
If you are going through hell, keep going.
TWAtwaTWA
Wed May 17, 2006 1:40 pm
This comment relates to the above since it involves birds and planes...
I remember watching a documentary on the development of the B777, and it also featured the design and testing of the giant GE engine. There was a clip of the engine, mounted in test mode, at full power. In order to test the strength of the fanblades and ability of the engine to continue running in adverse situations, many items were chucked into the engine, including ice, small bushes, and even large (dead) birds. It was very entertaining to watch the engines easily consume multitudes of birds, while showcasing their impressive uninterupted function.
Does anyone have a weblink to this clip?
by the way, check out this amazing clip of a bird taking out a military aircraft....
http://www.yikers.com/video_bird_fly...e_causes_plane_to_malfunction.html
We're your kind of airline. Uh, I mean, We *were* your kind of airline.
3MilesToWRO
Wed May 17, 2006 2:57 pm
Quoting TinkerBelle (Reply 18):
Never heard about. However heard about Winter Olympic Games in Sapporo. You didn't?
Woosie
Wed May 17, 2006 3:34 pm
If the wing leaked fuel, then it was the main wing box.
It's very likely, though, that the bird penetrated an auxiliary structure in the wing (which is usually composite) or a slat/flap.
saintsman
Wed May 17, 2006 3:53 pm
Quoting MD80fanatic (Reply 5):
Type 'Bird Strike' into google images for the answer to that.
N160LH
Wed May 17, 2006 3:59 pm
Quoting Flyabunch (Reply 6):
Quoting Doug_Or (Reply 7):
I am so glad that somebody said that... main wing... hahah
-160
"I do alright up in the air, its down on the ground that I tend to mess up..."
Stealthz
Wed May 17, 2006 6:37 pm
Quoting Saintsman (Reply 22):
While you are there check with boeing.com and look for how much "structural steel" there is in the average B767!
AmericanB763ER
Wed May 17, 2006 6:58 pm
Quoting EMBQA (Reply 10):
Don't know if this is the incident that you mentioned but a very similiar one involving an AA 763 is to be found here
I flew on N376AN in 2005 I might add...  smile
Marco
bphendri
Wed May 17, 2006 8:30 pm
Was it a North Korean bird?
You gotta watch out for those things, they are from a secret anti aircraft bird breeding laboratory.
md80fanatic
Wed May 17, 2006 8:48 pm
Quoting StealthZ (Reply 24):
DING DING DING - We have two partial winners !!!!!
Firstly, I know very well how to use Google, thank you.
Secondly, I have a pretty good idea how much structural steel is in an airplane (most likely very little) but that isn't really the point.
Perhaps it was my choice of wording that threw so many off the mark? I was talking about the structural steel used in high-rise buildings.
I thought the  duck  would have given it away.
Motorhussy
Wed May 17, 2006 9:48 pm
Great headline, love it!
"Leave Hole in Main Wing." as opposed to the Boeing 767's not so main wing or lesser known and carefully concealed other wing.
Mirthfully yours
MH
come visit the south pacific
Stealthz
Wed May 17, 2006 10:03 pm
Quoting MD80fanatic (Reply 27):
Ah, doesn't take long for someone to bring sad day back into the story.
Making a hole in the skin of a wing is hardly the same as the structural part of the wing taking on a building skeleton. Sad really!!
MADtoCAE
Wed May 17, 2006 11:21 pm
And wich one is the main wing?
Operator!!! Give me the number for 911!!
md80fanatic
Thu May 18, 2006 12:43 am
Sorry for the tone of my last post. The other thread is wearing on me.
Still though the comparison does not deserve to be glossed over and forgotten. All here should keenly understand just how fragile these wings really are. They are designed to fly through air, not birds.
jetflyer
Thu May 18, 2006 12:52 am
Except that the 767 doesn't go into space nor has to re-enter the earth's atmosphere at thousands of miles an hour.
miamiair
Thu May 18, 2006 12:56 am
Had a DC-10 slat that got punctured by a bird two weeks ago. Hole was 19" X 13". Swapped the slat out at is would take too long to repair. A few bird incidents:
B763F, bird strike punctured leading edge access panel. Panel made of fiberglass.
About 20 yrs. back, an Ecuatoriana 707 took a bird strike over the Andes. Flight continued to MIA on 3 engines. Totaled the nose cowl, damaged fan and side cowls. The worst part is the smell...
A bird will do all sorts of damage to the structure. I am not surprised anymore by the damage they cause.
linco22
Thu May 18, 2006 1:56 am
Big Bird from Sesame Street by the sounds of it.....
dizzy8
Thu May 18, 2006 2:26 am
Do we classify this as a "near miss", a "near hit", or "loss of separation with an avian projectile?"
(We'd better check those orange black boxes.)
[Edited 2006-05-17 19:28:34]
dizzy8
Thu May 18, 2006 2:44 am
Presume it would be the Leading Edge Slat area.
The report does not state which part of the Right wing.
regds
MEL
MOW
Thu May 18, 2006 3:04 am
Here, have a look.
According to Japanese TV several birds hit the aircraft.
Big version: Width: 624 Height: 470 File size: 323kb
A342
Thu May 18, 2006 4:29 am
Quoting N160LH (Reply 23):
Quoting MotorHussy (Reply 28):
Quoting MADtoCAE (Reply 30):
The main wing is the wing, and the other wing they could have meant is the horizontal stabilizer. End of story.
Quoting Linco22 (Reply 34):
??? I'm not sure I get what you wanted to say ?
N160LH
Thu May 18, 2006 8:11 am
Quoting A342 (Reply 38):
Thanks I was very confused...
-160
ComeAndGo
Thu May 18, 2006 9:18 am
Some migratory birds fly at cruising altitude.
At 600 mph they'll do plenty of damage.
bphendri
Fri May 19, 2006 4:36 pm
When will those darned birds ever learn RVSM!!!
Just goes to show, you can't teach old birds new tricks!
And it could not have been a goose, otherwise it would have been squaking..
[Edited 2006-05-19 09:37:22]
PurdueAv2003
Fri May 19, 2006 6:24 pm
Quoting Magic48 (Thread starter):
I had this discussion with my sister, a DVM, this weekend: Why do we refer to "birds hitting the aircraft" when in reality it is the aircraft hitting the bird?!
BTW, I've seen several instances of birds (or at least what's left of them) ending up embedded in the leading edge of aircraft. Believe me, it is a mess, both the bird and the plane.
Ptu = Ftu X Anet (not to be confused with a.net)
scouseflyer
Fri May 19, 2006 6:42 pm
I remember as a teenager I was a member of the RAF cadets and on camp one year helped out at the RAF Hawk (sub-sonic jet trainer) maintenance facity in Devon. We helped to dismantle the nose of a Hawk that had suffered a bird-strike - there was a hole in the nose about 20 cms accross and a series of smaller holes in 3 or 4 of the internal structural pieces of the plane - and nothing remaining of the bird other than a sort of pate substance splattered all over the inside of the nose!
