harrisair
AS 737 Combi Retirement Livery
Thu May 18, 2006 9:51 am
This airplane was at the hangar for 2 days, departed today at around 1315. Anyone know who picked this one up? N730AS
Harris
Big version: Width: 640 Height: 480 File size: 123kb
Jj
RE: AS 737 Combi Retirement Livery
Thu May 18, 2006 10:05 am
No idea who's picking it up... but can anyone tell me with what is AS replacing the 737 combis? I understand they were widely used in flights within alaska... are the 73G's doing them now?
dutchjet
Thu May 18, 2006 10:09 am
The 732 Combis will be replaced with 734 Combis (with a fixed partition between the cargo and pax areas instead of the variable partition which is no longer permitted under US regs) and, in addition, AS will be flying one 734F. The 734Combi/F aircraft will fly routes mainly within Alaska, just as the 732Combi fleet has done in recent years.
AirframeAS
Thu May 18, 2006 10:13 am
Quoting Jj (Reply 1):
734's will be doing them with 709AS the first ship as a full freighter as I understand it.
Jj
Thu May 18, 2006 10:15 am
Quoting Dutchjet (Reply 2):
Wow... I thought that some runways there were quite short for a 734! Are they going to be any limitations or they will perform just as well as the old combis?
alaska737
Thu May 18, 2006 10:38 am
Quoting Jj (Reply 4):
the only major airport that was a problem as far as runway lenght was Ducth Harbor but AS has since disposed of that route. the question is what kind of A/C will go on routes to Red Dog or other gravel strips, will the 400C be gravel fitted as well?
as739x
Thu May 18, 2006 10:40 am
Jj: N709AS should be arriving in Seattle around May 20th. This is the first -400C a/c.
ASLAX
CanadianNorth
Thu May 18, 2006 10:45 am
Quoting Alaska737 (Reply 5):
The vortex dicipators work quite nicely on the JT8D series, but just don't fit on the higher bypass engines featured on the 737-300 through 900; so they will not be fitted with gravel kits as far as I know.
CanadianNorth
HS-748, just like a 747 but better!
alaska737
Thu May 18, 2006 10:50 am
Quoting CanadianNorth (Reply 7):
so then will AS keep a 200? they cant fly them forever. they need some A/C to fly into gravel strips....or they could cough up a few million and have Red Dog paved
harrisair
Thu May 18, 2006 10:55 am
The gravel kit includes this huge guard on the nose gear. Can't picture them putting that on a 734.
Big version: Width: 640 Height: 480 File size: 124kb
Who else operates aircraft with a gravel kit any more? I know that ARCO/BP has the kit on at least one of the 732's they operate between ANC and the North Slope.
Harris
alaska737
Thu May 18, 2006 10:59 am
Quoting HarrisAir (Reply 9):
speaking of Arco/BP what will happen to those A/C will they be replaced or retired?
well im sure something could be figured out. they could have a larger advanced version of the EMB-120 gravel kit. or one similar to the C-130
BTW is Proudohe Bay/Deadhorse's runway paved?
Chugach
Thu May 18, 2006 11:03 am
Alaska737:
Every airport that AS flies into in Alaska is now paved, including Red Dog.
alaska737
Thu May 18, 2006 11:11 am
Quoting Chugach (Reply 11):
wow, how new is this? i read a recent airways aritcle that told of a flight to red dog and how it is a gravel runray.
Big version: Width: 432 Height: 329 File size: 22kb
NW747-400
Thu May 18, 2006 11:19 am
IIRC the newer high bypass turbofans can still be fitted with vortex dissipators; however, they are integrated into the engine nacelle/cowling rather than an external fitting as with the JT8's.
ANCFlyer
Thu May 18, 2006 12:05 pm
Quoting Alaska737 (Reply 12):
Red Dog was paved last summer.
Quoting Alaska737 (Reply 10):
Yes, Paved a way long time ago.
As has been mentioned in the other 15 threads about this AS 734 conversion, the gravel kits and other unique devices (vortex dissipators, etc) common to AS 732Cs is no longer necessary. The runways have all been paved.
The pint is moot, but why can't you picture it on a 734? Same gear, same fuselage, same
BP has three 732s, only two have the gravel kits. The third, a former US bird, does not. The runway at UUK is not paved, but does not see service from AS . .. only BP/Conoco-Philips. ARCO has no more stake in the Alaska Oil market by the by.
HikesWithEyes
Thu May 18, 2006 3:56 pm
Quoting HarrisAir (Thread starter):
It's going to the desert. No one bought it.
First, benzene in my Perrier, and now this!
Tod
Thu May 18, 2006 11:14 pm
N730AS
This one was delivered in 1981.
N745AS was delivered Air Zaire in 1974.
When will it be put out to pasture?
Tod (still scheduled to fly a 732Q SEA-JNU on 23June)
CanadianNorth
Thu May 18, 2006 11:31 pm
That part of the 737-400 is almost the same as on the earlier -200, so the "nosewheel ski" is the easy part.
Canadian North and First Air use several examples in the NWT and Nunavut
Quoting NW747-400 (Reply 13):
First I've heard of this, but it sounds interesting. Would you happen to have any further information on this setup?
CanadianNorth
AirframeAS
Fri May 19, 2006 7:26 am
You can't. That would be a huge HUGE alternation under F.A.R. Part 43 AND a new STC would be applied for under F.A.R. Part 21. It would involve cutting out a huge part of the structure for the gravel deflector and new nose gear type and more.... it would involve a HUGE sum of money, just not worth it.
Quoting CanadianNorth (Reply 17):
Not really. The nose gear on the 732's are shorter than the 734's. The fwd fuselage looks LOWER on the 732 than the fwd fuselage on a 734, hence the shorter nose gear.
