sw733
Fast Commercial Planes
Fri May 19, 2006 12:53 pm
Hey all, I'm really bored so I am just clicking "random flight" on FlyteComm, and came up with El Al flt. 2, a Boeing 747-400 from JFK-TLV which is currently in flight over the north Atlantic ocean. It is stating the speed at 703mph - I wasn't aware a plane could go this fast. Can the wind really push it to that high of a speed on eastbound trips, or is this an incorrect number? Thanks!
Zach
ComeAndGo
RE: Fast Commercial Planes
Fri May 19, 2006 1:23 pm
East bound on the North Atlantic yes, West bound no way.
When they fly east bound, they take advantage of the jet-stream.
When they fly west bound, they avoid the jet-stream.
LPLAspotter
Fri May 19, 2006 1:51 pm
flew TG NRT-LAX in 8 hours 30 minutes. GS was in excess of 700 mph.
LPLAspotter
Nuke the Gay Wales for Christ
superhub
Fri May 19, 2006 5:25 pm
Quoting SW733 (Thread starter):
Mind you...this is ground speed...not air speed.
sevenair
Fri May 19, 2006 5:39 pm
Yeah, the jetstreams can be up to 120kts on a pretty regular basis. But the TAS will still remain around the 580kt, so it will be possible. Pretty nippy tho, 703mph!  Smile
citationjet
Fri May 19, 2006 7:55 pm
Where does flightaware show mph? I have only seen kts.
If you want to see high ground speeds, check on Citation 750 aircraft (C750) going eastbound.
[Edited 2006-05-19 12:56:43]
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
sw733
Sat May 20, 2006 12:54 am
Thank you all for your answers. I just haven't been on a flight that has been that fast (at least that I have been aware from) so I was curious when I saw it.
Quoting CitationJet (Reply 5):
I've only seen it in mph. On ground speed it says ---mph. For instance, I just brought up a random flight (Air Comet flt. 901, a 742 from Madrid to Bogota) travelling over the Caribbean at 474mph.
411A
Sat May 20, 2006 7:27 am
The northern jet (stream) over Japan can, at times, exceed 200 knots.
Example.
One of my flights in an L15, FUK-NRT, at FL410, was whistling along at 728 knots ground speed...'round about 837 MPH.
The CAS was 490knots, M.85.
Coming back the same way 4 days later, was ah.....s l o w e r.
Ground speed 345 knots.
