1337Delta764
Delta 767-400 In SJU?
Sun May 21, 2006 4:08 am
I came across this image:
Photo © Carlos Aleman - SJU Aviation Photography
Apparently, this is a 767-400ER in SJU. Normally only 737-800s (from CVG) 757s (from ATL and JFK) and domestic 767-300s (from ATL) land there. Could it have been an equipment substitution for a 767-300 on the ATL-SJU route? If so, how often do these substitutions occur?
FoxBravo
RE: Delta 767-400 In SJU?
Sun May 21, 2006 4:12 am
I could be wrong, and I don't know whether this was the case when that particular photo was taken, but I believe DL has scheduled 764s on ATL-SJU in the past during peak season.
Common sense is not so common. -Voltaire
1337Delta764
Sun May 21, 2006 4:15 am
The photo was taken last March, and I do believe that the peak season is in the summner.
panamair
Sun May 21, 2006 4:29 am
Quoting 1337Delta764 (Reply 2):
March is also sort of peak due to spring break and school holidays...
1337Delta764
Sun May 21, 2006 4:32 am
Quoting Panamair (Reply 3):
Spring break can vary where you are. When I used to live in Virginia Beach, Virginia, Spring Break was always on the week of Easter.
I went through the June schedules, and could not find a 767-400.
[Edited 2006-05-20 21:36:50]
DeltaMIA
Sun May 21, 2006 5:37 am
It was an equipment substitution. The date is wrong though. On 03/25 this aircraft operated as DL318 SJU-ATL.
It's a big building with patients, but that's not important right now.
AlitaliaMD11
Sun May 21, 2006 5:50 am
When I was in Puerto Rico in the middle of March one of the daily ATL flights was a 767-400 instead of the regular 767-300.
No Vueling No Party
FoxBravo
Sun May 21, 2006 6:02 am
Summer may be busy too, but December through March is definitely a peak season for the Caribbean.
SLCUT2777
Sun May 21, 2006 6:29 am
Quoting FoxBravo (Reply 7):
December-March is also peak time for Hawaii. May through October usually brings the numbers to the Europe flights. Will DL shift their 764s from Hawaii to Europe for the summer and put the 763ERs on the Hawaii routes?
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
1337Delta764
Sun May 21, 2006 6:34 am
Quoting SLCUT2777 (Reply 8):
The schedules still show 767-400s. You should know that only five 767-400ERs are being converted to international ops.
N160LH
Sun May 21, 2006 8:41 am
Which ships are the five being converted..?
-160
"I do alright up in the air, its down on the ground that I tend to mess up..."
1337Delta764
Sun May 21, 2006 11:34 am
Quoting N160LH (Reply 10):
It has not been decided yet, the conversions will be done over the winter. For the time being, the 767-400ERs on international routes are being sold as all coach.
SESGDL
Sun May 21, 2006 4:03 pm
DL currenly flies ATL-OGG with an internationally-configured 767-300ER.
Quoting 1337Delta764 (Reply 9):
Actually 8 aircraft are being converted for international service, not 5.
Jeremy
dalb777
Sun May 21, 2006 5:17 pm
Quoting SESGDL (Reply 12):
Nope, it's 5. Origionally, either it was going to be eight or there was some confusion on the number; but after it is all said and done, five 767-400ER's will be converted to international configurations. Read here in the article from Delta:
http://news.delta.com/article_display.cfm?article_id=10140
In addition to the eight Boeing 767-300ER and five Boeing 767-400 aircraft being redeployed from domestic to international service to support growth across the Atlantic this summer
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
DAL767400ER
Sun May 21, 2006 7:34 pm
Indeed, but only because a 764 couldn't make it nonstop OGG-ATL out of the relatively short runway at OGG.
